Question about Sony Televison & Video
Tape damaged by VCR - Sony Televison & Video
  • Sony Master
  • 5,126 Answers
Tape damage can occur anywhere in the VCR. If the edge of the tape is crinkled, then the cause is a worn capstain roller. Bad chewing is often caused by the tape not being pulled back inside the tape before being ejected, which has a wide range of causes.
Without more detail, we can't help with anymore than just general comments.
Posted on Sep 15, 2010
  • 1 more comment
  • Demonic-2011
    Demonic-2011 Feb 24, 2011
    There are many factors as to how or why a tape gets damaged in VCRs. The most likely cause would be a glazed pinch roller - once these wear down, they become shiny - causing the tape to 'ride' either up or down the capstan shaft during operation. Cleaning these is NOT a viable option; they MUST be replaced, and this is easy enough to do with the recent models. Once you replace the roller, you must clean up the tape path - including take up levers, loading arms, reel tables, the heads (the erase head/CTL and drum cylinder - do these carefully), capstan shaft and both guide posts. More information would have been helpful though as to the exact problem.
  • Demonic-2011
    As the worn roller causes the tape riding - up or down, the tape becomes snagged on the edges of the exit guide - which is where some of the chewing comes from, since this guide is nearer the pinch roller and capstan. Guide post units in VCRs consist of a small nylon roller which rotates over a metal bearing (the tops of both guides are adjustable but you should not need to touch that part) - hence the term 'guide roller' - these seldom fail as they are not made of rubber.
  • DMAllen Oct 21, 2012
    Do these comments hold true for Betamax machines? Where can I find guidance on fixing a Betamax machine?
Unit will not stay on. Turn power on unit with no tape. After several seconds cycles off. I am using the aux. to monitor a cctv camera.
VCR's with faulty mechanisms will power down to prevent tape damage. Checking inside might reveal damage to the tape mechanism. Even if the mechanism isn't damaged the VCR has a device called the mode switch. These tell the electronics what position the mechanism is in. If that goes faulty the electronics can think that mechanism is in say playback mode, even when it's in eject mode. So when it detects no tape tries to stop and eject the tape. Since it can't carry out this it shuts the entire video down to be on the safe side and prevent further damage.
Mar 15, 2015 | Emerson EWV404 VCR
Vcr has sound but no picture
Usually this means the video heads in the unit are blocked with tape debris----all you need is one damaged tape inserted and heads get instantly blocked.
Heads can be manually cleaned but you need to know how or you can try a cleaning tape----most shops charge very little to clean the heads but then you have to find the damaged tape--clean them and get picture back and if the damaged tape gets put back you are back where you started.
Dec 02, 2012 | GE VG4040 VCR
Err message
There could well be some damage inside the VCR that is causing the system to go out of sync. Also the mode switch might need replacing.
Nov 21, 2012 | RCA VR546 S-VHS VCR
VCR won't load tape all the way
Best to check the tape by comparing it with another tape. There could be damage to the case. Check that you can lift the flap at the front. If all else fails or you find damage on the case of the tape, the tape can be removed and placed inside a new blank tape case. The new tape reels would have to be removed first. It's a bit tricky, but as long as you dont touch the tape itself it should work fine.
Jun 07, 2012 | Televison & Video
How to repair my vcr I have a faulty tape in the machine and unable to remove it
I hope your vcr is not built in with TV. It is separate from TV. If it is not then you have to call a technician to open the vcr and remove the faulty tape. If it is separate then open the top cover by unscrewing the screws on the side. These can be located very easily. Remove the top cover gently. Look for the gear toothed wheels which load/eject the tape. You can do so by switching the power button on and off. Switch of the power to vcr. Move the toothed wheels by hand to bring the tape up if you do not want the tape to get damaged. When the tape comes up then give it a gentle push so that it can eject itself. If not, repeat the process again. If you see the magnetic tape is stuck or entangled with moving wheel the cut it,remove it gently. Make sure that you do not touch or damage the video head. Once removed, you can fix the top cover.
Apr 04, 2011 | Televison & Video
VCR tape won't eject
The reason your tape wont eject is either because, it is stuck or the tape run loose inside of it.
To remove the tape, unplug the VCR, then unscrew it open, you will have direct access to the tape, so try to plug it back and press eject, when it gets stuck, apply a little force in pushing the tape up, to the height where it is to pass out, and it will eject your tape.
If you are not familiar with such activities, i will advice you get a repairman to get this done for you, in order for you not to damage any other part inside the VCR.
Take cacre and good luck
Oct 14, 2010 | Sylvania LV448HG VCR
Sony SlV-SE730 VCR video inserted wrong way
Unplug the VCR.
Take the cover off by taking out the small screws on the sides and on the back that hold the cover on.
With the cover off you should be able to gently move the tape back out.
Things could be damaged......after the tape is out, you should try it first with a tape that could possibly be damaged during testing and do not touch anything inside while plugged in to power during testing with the cover off!
Now......if it is not a working VCR anymore......you are in luck.
There are garage sales every weekend...and almost every one has a VCR for almost nothing....some like new.....and boxes and boxes of tapes/movies for very little money too.
Sep 06, 2009 | Sony SLV-SE730 VHS VCR
How do I repair a VCR tape? My vcr chewed a special video taken in Ireland and I can't replace it.
You could cut of the damaged part and use thin clear office tape to mend it.
Place the ends overlapping and cut with sharp carpet knife or with scissors.
I have repaired quite a few tapes succesfully.
You will lose the damaged section of the content on the tape.
Sep 30, 2008 | Televison & Video
Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Feb 04, 2008 | Televison & Video
Televison & Video Logo
370 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
