Question about Fuji FinePix A805 Digital Camera
Memory card is protected how do i unprotect it ?
  • Fuji Master
  • 3,289 Answers
Remove the card from the camera and look along the long edges of the card for a small tab. Slide the tab to the "Unlock" position (closest to the contacts of the card), and return to the camera. You should be good to go!
Posted on Sep 15, 2010
Unprotect a card
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 23, 2012 | Nikon COOLPIX L18 Digital Camera
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
PROTECTED CARD
Most SD memory cards have a small slide switch on the edge off the card. This switch is used to write ptotect the data on the SD card - you can lock or unlock the SD card be sliding this switch.
Jun 18, 2010 | SanDisk 2GB microSD Memory Card
Hello! I have a problem with my cam. When I put the memorycard into the cam, it says - memory protect! What does it mean and what should I do? Thanks in advance!!
Actually your memory card is 'memory-protected' ! You cannot use it without making it 'unprotected'.
Try these steps to unprotect it :
1. Remove the memory card from the camera.
2. On the down-end (which faces outside when it's inside the camera) of the card, you will find a small sliding switch.
3. Move the switch to the opposite direction (left or right) of the present position.
4. Now, it is unprotected and you can use it!
please rate me if it helps....tc! :)
Jan 08, 2010 | Fuji FinePix A800 Digital Camera
My memory card is write Protected how slove this problem
You can see the write protected button on your memory card just move it slight to unprotect your memory card.
Rate my answer.
Thanks..
Jan 03, 2009 | iLO (2 GB) MP3 Player
How to unprotect the memory card
On most sd cards there is a physical (tiny) sliding switch on the memory card. Here is a picture of a standard SD card. On the left you can see the gray switch in the unlocked position. Hope that helps. -WN
4bfc547.jpg.
Jul 27, 2008 | Nikon Coolpix 4600 Digital Camera
If I understand correctly what your asking what is the brand and size of the memory card. If I were to take a stab at it right now I would assume there is a lock/unlock switch on the card. Have you had this problem with the card before?
Good luck,
Lee
Jun 13, 2008 | Polaroid I533P Digital Camera
the problem isnt with your camera, its your memory card, and it isnt a problem at all. simple solution- take out your memory card, and on the side there is a tiny switch. all you gotta do is flip the switch. quick and easy. hope that helps anyone.
May 18, 2008 | Microtek Take-it MV320 Digital Camera
Memory card has a slider switch which prevents write access. Move switch to other position.
May 15, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
i am having lg 6600 it is showing protected how to un proected it?
Nov 18, 2007 | Panasonic Lumix DMC-FZ30 Digital Camera
Fuji FinePix A805 Digital Camera Logo
140 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
