Question about LG Televison & Video
I have an LG-GR151R mini fridge. It doesn't seem cold enough and the temp dial goes from 1 to 10...What is the coldest temp?
5 Suggested Answers
  • 1462 Answers
SOURCE: On the dial setting between
5 is coldest and 1 is warmest
Posted on Oct 13, 2008
  • 317 Answers
SOURCE: I have a very old
You could try
operatingguides.com
if you need a user manual
or
servicemanuals.co.uk
if you want the schematics etc
We've used them in the past and found them very good.
Also if it is not listed then ask via the link and they
will probably be able to get it for you.
Posted on Jul 14, 2011
sekjr
  • 3 Answers
SOURCE: Freezer cold not frozen, fridge cool but not cold enough.
Is the refrig running constantly? and still can't get to 0deg???
You say it's 30deg in there! I assume you are using a thermometer IN the freezer. Is the fan in there running (you can hear it). If it is, and you say you aren't cold enough, you lost freon...
Posted on Aug 16, 2012
  • 1680 Answers
SOURCE: My refrigerator and freezer not cold enough.
are the side hot ? Refrigerator Not Cooling Repair
Posted on May 23, 2016
Igloo mini fridge not getting cold
The compressor may be frozen. Turn off the fridge for 6-8 hours, then turn it back on. Don't turn the temp to the coldest setting. If it will still not get cold, the compressor is probably bad.
Jan 22, 2014 | Igloo Cooler Igloo 4.6 cu. ft....
Hi, I have a Bosch intelligent frost free 44 which I bought second hand a few days ago. Manufacture date appears to be 2006 and was told it works fine but I am not sure. When I first turn fridge on the...
I think it's the freezer fan that stopped working,open the freezer and see if it goes you should hear it running and even see.This fan allows the cold air into the fridge compartment,without it it takes ages for the fridge to get cold.I've got the same problem if you find the motor online let me know on alvalen31@hotmail.com
Nov 03, 2010 | Bosch Refrigerators
Fridge not keeping things cold enough
fridge coldest setting is 1
freezer warmest setting is 1
Dec 08, 2017 | Fisher and Paykel E522BLXEZ EZKleen...
I have a Kenmore bottom freezer fridge. Can't find the manual. Is 7 the coldest setting or 1? We keep the fridge in our garage and with the artic temps we are having we need to adjust it.
most refr's dont so well when the ambiant temps fall below 50 degrees. you should not need to adjust the controls must past the "midpoint" usually 4. but 7 is the coldest setting.
the best thing you can do is check what the actual temps are in your garage and if you can warm it up to above 50, then the unit should run properly again.
if the ambiant temps are too cold, the freezer wont be cold enough and the refr section will freeze things.
Jan 06, 2010 | Refrigerators
The fridge side is not cold enough, but the freezer seems to work fine
Make sure that the climate controls on the fridge side are set towards "coldest". If they already are, you might have a bad thermistor, which should be located behind the temp controls at the top of the fridge side.Fairly easy to replace.
Nov 02, 2009 | Whirlpool ED2FHEXN Side by Side...
Fridge gets cold then shuts off
Feel the motor temp. after letting it do its thing for a reasonable period. If motor is extreemly hot then it means motor is switching off on internal protection.(has to be replaced then.). Set temp to its coldest then see if it still switches off as it is. if the same, board is more likely to be a problem. Very seldom if ever does one have to replave sensors. (assuming it has an electronic board). If using a th/stat, replace it if temp does improve but still eratic.
Sep 16, 2009 | LG Refrigerators
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Dial goes from 1 to 5 in fridge, what is correct setting
1 is warmest and 5 is coldest. set to 3 and just see if that gives you a reasonable temperature. fridge temp should be about +4degC and freezer temp about -18degC
Sep 05, 2008 | Refrigerators
Televison & Video Logo
142 people viewed this question
Computer Repairing
Computer Repairing
