Question about Kenmore Elite 45986 Front Load Washer
My washer it's says SUD AND THEN f35 .what does it means
    President:
  • 1,430 Answers
This indicates that the pressure switch or also called the analog pressure sensor has failed. First you will need to remove the top lid. Usually 2 or 3 screws on the back and the top comes right off. The pressure switch has a clear hose and a clump of wires going to it. Then unplug the hose and blow thru it it should be clear. Check the hose for leaks or obstructions. Also in the back of the washer on the left hand side is a air dome this is where it gets it pressure reading from, make sure it is not obstructed. If all is clear the pressure switch will need to be replaced. For help accessing the pressure switch try this link http://appliancehelponline.com/washerpressureswitch.html also if you need diagrams or illustrations of your particular model.
Posted on Sep 15, 2010
I have a Whirlpool Duet Washer, washer starts and then stops code F35
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Nov 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet steam WFW9600TW00 code F35
Kevin
Oct 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washing machine displays code F35 and won't complete the washing cycle.
Kevin
Apr 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does f35 mean
Hello there
F35 found in this link
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
F35 means ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Dec 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sud/F35
if your using more than 2 tbl spoons of HE detergent, you WILL have the same problem with your new washer." sud "stands for TOO MUCH SOAP
Jul 24, 2009 | Kenmore Elite 45986 Front Load Washer
F35 flashing
if it is less than one year old call for service it should be covered. if not take the kick panel off and locate the tech sheet it is either in the kick panel or in the cabinet to the right. it will give you a list of error codes find out what it means and let me know thanks
Jun 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
143 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
