Question about HP Office Equipment & Supplies
Hp deskjet560c wont load the paper when the feed rollers turn. the paper is too low for the feed rollers to catch.i put about 1/16 inch tape above the cork on the paper tray,but the rollers wont pick it up. i have tried using 1 sheet and 25 sheets on the tray. the paper tray seems to be about 1/16 inch low with one sheet on it. i am thinking of getting into the cabnet and putting a spring under the tray. since the thing is obsolete,i request down loading a service manuel.i can go to the ebr parish library to use their computer printer set up.
    President:
  • 2,712 Answers
I think its time to say goodbye to this model and get something newer. There are loads of decent printers in the $50-100 price range.
Posted on May 16, 2008
  • Swilin Sampson
    Swilin Sampson May 16, 2008
    1. The mechanism that lifts the IN tray up to the paper wheels may either be jammed or broken.
      1. To release the paper feed mechanism:
      2. Remove the OUT tray and load or have at least 20 sheets of paper in the IN tray
      3. Press the FF (Form Feed) button for the HP Deskjet, Plus, or 500
        printer. Press the LOAD/EJECT button for the HP Deskjet 500C printer.
      4. If the paper is not lifting up to the three black wheels, but the wheels spin, the paper load mechanism is the problem.
      5. The paper load mechanism is an ear shaped black piece located on the
        right side of the IN tray. As this piece turns, the paper is lifted up
        to the rollers. This same piece is shaped differently on the HP Deskjet
        520 and 560 printers, but is the only clear piece on the left side of
        the IN tray.
      6. If the load mechanism is jammed, turning the black piece to the right and to the left a few times may clear the problem.
      7. If the problem remains, or if the paper load mechanism continues to
        jam, contact HP technical support to send the printer in for repair.
    Genius:
  • 3,422 Answers
I am sorry to say this but i don't think there is any service manual available for this model.But please CLICK HERE and contact these people they may help you out.
Goodluck,
Please don't forget to rate the solution
    Genius:
  • 1,665 Answers
I have an hp p3005 with the jam code 13.01.00. It has had the feed rollers and sep pads replaced. When it runs it appears to catch on the separation pad itself since it shows a small buckle in the middle...
Replaced seperation pad?. separation pad work is to block multiple paper feeding,but in yourcase paper not at all feeding means paper pickup roller not picking up the papers.replace both 2 & 3 paper pickup rollers..
See the snap shot,view from under.
Pickup roller( red)
Un lock to remove pick up roller(blue),observe the angle of the roller & same way insert new one other wise it wont fix..
Bee care full while removing roller, paper sensor flag should not distubed(yellow)
bee pateince dont do harsh..best of luck.
Oct 11, 2011 | HP LaserJet P3005 Printer
Paper won't feed through. goes about 2-4 inches the stops no matter how many times i clear the jam.
Hi If you remove the toner/drum unit and look into the back of the printer you will see the paper feed roller and just above it a long thin foam covered roller. Clean this foam covered roller with a damp cloth, it will be covered in toner and too slippy to feed the paper. Turn it and clean until it feels sticky again, all should now work !
Aug 31, 2010 | Samsung ML-2240 Laser Printer
Same problem. Printer runs but wont feed in any
observe if pick up mechanism function as when you send printing job. if yes, may pick up roller already worn out and need replacement.
Jun 02, 2010 | HP Officejet 5510 All-In-One Thermal...
I am printing postcards which get stuck in the printer during the last 2 inches of printing. What can I do to fix this? The printer is HP officejet 6110 all-in-one.
How stiff is the card stock? Some cards cannot feed if the printer rolls the card to print on it. (This one does)
I have taped cards to a full size sheet of paper and run that through.
Usually this means the paper is too stiff.
You can try cleaning the paper feedroller with a rag with a bit of windex on it. (This roller is above the paper tray where the paper loads in.)
Apr 02, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Wont grip paper on feed, keeps 'saying' paperjam
I have had this problem after printing a large batch of sheets on a heavy matte photo paper. The roller picks up a 'polish' from the surface coating and then fails to grip. I have tried cleaning the roller, with some sucess, but the best solution I have found is to feed through several blank sheets (just page throws in a Word document) of a ordinary 80 gram paper. Doing this between smaller batches of the photo printing seems to keep things flowing.
Jun 24, 2009 | HP Photosmart 2575 All-In-One InkJet...
Paper won't feed
No guarantee on this just an idea. Can you put a piece of sticky tape(the matt one not hi gloss) just across the feed in edge. Or some other thin tape that would have a "grip" to it? Good Luck!
Apr 30, 2009 | HP Photosmart C6180 All-In-One InkJet...
Not grabing paper to print Seem as though the roller feed is not
This will happens when the paper feeder sensor fails. Due to this when give any print or copy it wont feeds the paper you may get the error please load the paper. For this you need to contact HP Customer Support for a service if it is under warranty.
Thanks & Regards Nandu :)
Mar 14, 2009 | HP Photosmart 2610 All-In-One InkJet...
Hp 1350 all-in one psc
your paper feed problem may be due to the feed rollers or due to the fact the mecanism that raise the paper doesn't function properly. Normally if you clean the rollers that should work
Jan 25, 2009 | HP PSC 1350 All-In-One Thermal Printer
HP fax 1020
try cleaning with alcohol if it doesn't work then yes it needs to be replaced
Aug 12, 2008 | HP 1020 Plain Paper Thermal transfer Fax
Paper feed
If the print-out is an 'alien-like' one, the problem is on the sensor of the printer. The sensor is on the opposite side of the gears. Under the black cover.
Oct 11, 2007 | Office Equipment & Supplies
48 people viewed this question
Ben Johnson
