Question about Ovens
I have a Kitchen Aid oven and somehow it ended up on "Control Lock". The door will open and close but none of the control panel buttons will operate now.
Hold down the control lock button for 10 seconds
Posted on Sep 15, 2010
  • rattiegirl Sep 24, 2010
    Thanks! We have a Dacor in our new house, and this tip worked to unlock the display (which was reading "off" for some reason, making the buttons not work).
My oven has a "key shape" appearing and I cannot do anything (the door can open though) HELP
Sounds like the control panel is locked out. Look close at all the buttons. One of them should say press here (for a listed number of seconds) to lock or unlock controls. If none of the buttons are marked, try pressing the KEY for 5 to 10 seconds and see if it unlocks.
Mar 26, 2015 | Ovens
We a kitchen aid oven the door was accidentally lock. Can you find out how to open it? Whirlpool owns kitchen aid
  • Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3
    Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4
    Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
  • Nov 18, 2012 | Ovens
    My daughter-in-law just moved in to a newer home with a stainless steel Kitchen Aid ceramic top stove. It has a warming oven, a convect feature etc. However, with options etc. it is very confusing to...
    Kitchen Aid manuals are available from their support site: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . The model number is needed to locate the manual. For ranges, the plaque with the model number is inside the oven door.
    The KitchenAid ovens that I know will turn off when you press Off (unless the control lock is on - then you need to disable the control lock). The Warming Drawer will have a separate Off button. Dual oven units require you to select which oven and then press off.
    See http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KESS907XSP_Use%20and%20Care_EN.pdf for a similar range. (ceramic glass cooktop, convection feature and warming drawer)
    I hope this helps.
    Jul 02, 2011 | KitchenAid Ovens
    Kitchen aid wall oven Model YKEBS2780B1 SHOWS
    Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
    2. Test relay contact operation
    3. High resistance in oven temperature sensor F3
    Thanks
    May 26, 2010 | Ovens
    Kebs208d THE DOOR WILL NOT UNLOCK
    HI, this is a major control fault. you will need to replace the Oven control asap if possible. It has failed.
    Possible causes--
    *Power surge
    *Failed logic(IC)
    *Oven Temp Sensor failuer that has resulted in extreme temps that has overheated the board.
    Jun 07, 2009 | KitchenAid KEBC207 Electric Double Oven
    Kitchenaid Superba microwave oven combo close door error
    turn off the main power outlet it will work.
    Feb 09, 2009 | Ovens
    GE Double Oven doors locked and circuit not responding
    Hi, well this is a brain tester!! I think you need really to look at this in a simple way. Check to see where the door lock wires come from first? Find where the mains power comes into? then if it goes directly to the main control board then check to see if there is any power getting through the board to the otherside where the wires disapear into the cooker. I would consider checking the control board for any signs of burn damage and then look at the clock unit to as these are normally the main components in the cooker that will stop it from working.
    Good luck,,,,,,,,,,,,,,,
    Jan 02, 2009 | GE Profile JTP56 Electric Double Oven
    KITCHEN AID KEBC107KSS03 DOOR. REMOVE INNER PANEL. CLEAN GLASS
    LOOK WHERE THE HINGE METS THE OVEN DOOR FACING..you will see on the hinge a tab with the door open pull these forward this will lock the hinges do this on both sides then closed the door slightly and lift up the door will come off then you can unscrew the bottom scres to access glass
    Feb 22, 2008 | KitchenAid Architect Series KEBC107KSS...
    Our GE Profile JTP18 keeps flashing "door lock" since we ran a self clean
    most of the time a simple fix.... http://www.geappliances.com/search/fast/infobase/10004586.htm
    you have to trick the door lock mech into cycling through the cleaning process (takes about 20 seconds)
    Print Range - “LOCKED DOOR” flashes in the display
    If “LOCKED DOOR” is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
    Motorized Switch
      1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
      2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
      3. While you hold the door jamb switch in this position, complete the following steps.
      4. Press the Clean pad, wait 10 seconds.
      5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
      6. Wait 10 seconds for the display to clear.
      7. The door should unlock and there should not be a need for service.
    Manual Switch
      1. Press the Clean pad.
      2. Close the door.
      3. Slide the latch to lock the door.
      4. Hit the cancel button immediately.
      5. Unlock the door.
    If the above does not correct the situation, a service technician will need to check your cooking product. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
    Sep 14, 2007 | GE Profile JTP18 Electric Single Oven
    Ovens Logo
    129 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
