Question about Grundig S350 AM/FM/SW Radio
S350 will nor turn on - Grundig S350 AM/FM/SW Radio
My s350 will not turn on
Posted on Sep 28, 2010
Dewalt service center
The Grundig S350 (DL) runs on one of three power sources: electrical outlet, DD batteries, and AA batteries. There is a switch in the battery compartment that permits to change battery type. I do not know how different the S350 and the S350 DL are, but you should try to find out if it works with any of the two battery types before having it serviced. Clean all contacts of any acid corrosion. Check the manual to see if you have to specify the battery type in the setup too.
Feb 05, 2014 | Grundig Audio Players & Recorders
My Grundig S350 won't turn on. I have replaced the batteries and hit the reset button and still nothing. Please help.
Its Deluxe Version the S350 DL can use two types of batteries: D-size or AA. Inside the battery compartment there is a switch to select the size in use. If you use the AA sie batteries, they will not hold in their locations unless you lower a flap and secure them.
Have you tried to power the radio with the adaptor?
Aug 27, 2011 | Grundig S350 AM/FM/SW Radio
I have used my Grundig S350 radio almost daily, for the past 6-7 years. I went on vacation for 10 days. When I returned home, I turned on the power, lights light up, etc., but no sound...no matter how...
Hi
Its microcomputer chip may have hanged. Just make a reset ans see whether it helps you. It must help you, i"m sure. To reset it;
S350 incorporates with micro computer chip (the component that
controls how the radio operates). If the radio has been subjected to
abnormal environmental conditions, the micro computer chip may
hang up and the following symptoms may appear
The display shows nothing and the radio cannot be turned on by
pressing POWER & SLEEP button.
The display shows random characters or does not work properly
although the radio can receive stations normally.
In these cases, you might need to reset the radio. To reset the
S350, unplug the external adaptor (if one is being used) and
remove the batteries from the battery compartment. Insert a
pointed object, such as straightened paper clip, into the RESET hole
on the right, front side of the radio and gently press and release the
button inside the hole. Then plug in the AC adaptor or reinstall the
batteries
OK.
Jul 13, 2011 | Grundig S350 AM/FM/SW Radio
Grundig s350, installed new batteries and radio keeps shutting off by itself
When you press the Power/Sleep button the radio turns on and displays a number 90, or some other numbers. This is the play time that the radio will stay on then turns itself off. It could be that yours is configured with a sleep timer set to 01 minute, 10 or 15. You need to set the timer for a longer period. Thus we turn it on by pressing the Power/Sleep button, read the timer length then press again. Keep making short presses: The timer will cycle through all preset sleep timer durations. Select the length you want.
Jun 19, 2011 | Grundig S350 AM/FM/SW Radio
Got the Sony s350. Just bought Avatar Extended Edition and after the start telling about upgrades BUBKIS! Anyone else have this problem?
Just to confirm you are not alone. We have the 3 Disc Blu-ray Extended Edition Collectors Edition and the same Sony bdp-s350. Black screen. I updated the software yesterday directly thru the ethernet connection.
Nov 29, 2010 | Sony BDP-S350 Blu-Ray Player
S350 won't stop scanning on AM/MW mode. Tech support said reset with paper clip but that won't stop it either. Any thoughts? John G. Warren john.g.warren@jci.com
Strange. How can it, since that Radio does not have an Automatic Tuning System. To tune in to any frequency you have to turn one of two knobs. Are you sure about the Model Number?
Oct 06, 2010 | Grundig S350 AM/FM/SW Radio
Dropped my portable grundig s350. Stopped working
Anything could happen in a fall, no telling what needs attention, could be a bad battery connection a cracked circuit board. If it is under warranty send it in if not a good technician is needed.
Jan 24, 2010 | Grundig S350 AM/FM/SW Radio
Failure of radio to turn on
It sounds like a component on the circuit board is heating up. Open the radio up and check if anything is overheating, if so replace the defective part.
Jun 20, 2007 | Grundig S350 AM/FM/SW Radio
Grundig S350 digital display
The radio is analog with a digital display. Mine displays off all the time, you can try turning the other switches on it just slightly. Just move them a tiny amount. This seems to correct my problems. Heat is also another factor with these things, they drift all over the place.
Dec 09, 2006 | Grundig S350 AM/FM/SW Radio
Grundig S350 AM/FM/SW Radio Logo
208 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
