Question about Hussmann Freezer 12 Facing Curved Glass Front Ice Cream Dipping Cabinet
Have hussmann curve front glass, deli merchandiser, model number NEGCH-12U, need a condenser for this freezer, or a compressor. What size compressor do i need
    Director Badge:
    Uploaded 100 video answers.
  • Hussmann Master
  • 488 Answers
hussmann deli case, replacing evaporator.
Posted on Nov 06, 2015
  • 32 Answers
Look on Craigs list
Posted on Sep 16, 2010
Why does temperature fluctuate between 30 and 65 degrees all day long?
Check and clean the condenser, set thermostat to 3 or 4. If still problem persists, change thermostat.
Dec 08, 2015 | True Refrigeration Black True GDM-33SSL-54...
Cooler don't keep temperatur at 36 to 38 evaporator frozzted
Your model number on the body of the freezer will have that. You can also get size of comp. and fan and rotation located on the pieces itself.
Feb 13, 2013 | Traulsen ARI332LP-FHS 208 - 3-Section...
How to tell if you have a bad suction valve for ac compressor?
Hey there. First question I have is if you have a heat pump or straight ac. Straight ac is easy to diagnose. Your suction pressure will be high, your head pressure will be lower, not sure how clean your condenser coils are so its hard to say how high. Your amp draw on your compressor will be lower than normal. Also, when looking at the suction pressures, you have to keep in mind what temp the air hitting the evap coil is. If it is warm, that will make your suction pressure go up. Another way to check the vavles is to hold the suction line at the compressor when you shut it off. If the temp goes up the second you shut it off, this tells you the hot gas is leaking through your suction valves. You can also try to pump the system down, then shut it off and see how fast the pressure builds back up, this will give you and idea how fast it is leaking through. Let me know if you need any thing else, I'll be here.
seth
Jun 26, 2009 | Hussmann Freezer 12 Facing Straight Glass...
Defrost circut wired hot nuetral ,should this be d/c with a transformer
Probably uses a Paragon 8145 timer. Wiring as follows
L1 to 1/2 on timer, L2 to 2 on timer, Defrost Heater to 3 on timer,
Compressor to 4 on timer, Klixon to X on timer
May 22, 2009 | Hussmann Commercial Freezer DCCG-8
Problem with hussmann chest freezer
If the freezer is not located in an area where grease vapors are present the unit can be cleaned off using a vacuum cleaner. Then use a flash light to look through the coils. If you see dust embedded deep inside use a small air compressor to blow out the dust. Dirty condenser coils raise the pressures and temperatures in the system. Cleaning the coils and scheduling them to be clean at quarterly intervals should keep it functioning for a long time. Operating with a restricted condenser takes its tole on the compressor life span.
Sep 01, 2008 | Hussmann Freezers
Bedroom door sticking
Did you install the doors or a contractor? Sounds like the doors are not fitting the opening properly
Oct 20, 2007 | Hussmann Freezer 12 Facing Straight Glass...
Freezers Logo
256 people viewed this question
Top Hussmann Freezers Experts
Dennis Boxerman
jasbo
jasbo
John Tripp
John Tripp
Are you a Hussmann Freezer Expert? Answer questions, earn points and help others
