Question about Reizen Talking Blood Pressure Monitor Kit w ear piece (BattaryAdaptor I
My consumer has a new Reizen talking B/P unit model # 188310 with an extra large cuff. As soon as it comes on it verbalizes "user 1" and rarely if ever gives a reading. It states "error 2" mostly. After numerous attempts on both arms, she may have gotten 3 actual readings in the meter's memory. We have double checked with other brands and get immediate results. My big concern is that she is very sick, may soon go on dialysis,(also needs a liver transplant) and her B/P is very problematic. I am losing confidence in this unit and fear it needs replacement. I am very concerned your unit does not provide a toll free number or I would have called from the day I first delivered it to her! Please advise what we may be doing wrong or what to do next. Thank you D.Potts, RN, CDE , Phone 903-597-8485. I am located in Tyler Texas.
I need to order the arm cuff for model 1086CVS
What you show is a model number for a B/P cuff that is not one
shown for CVS. You also do not mention a size for the needed cuff.
Cuffs come in different sizes from Infant, Pediatric, Small Adult, Adult, Large Adult, Thigh.
CVS, and all the different manufacturers sell cuffs to fit monitors. Only the size of the cuff needed matters, and possibly the end fitting if something more is used other than just the rubber hose.
Look up any online company, or your local pharmacy and look for the replacement cuffs for monitors.
Apr 19, 2017 | The Health & Beauty
Why does my Walgreens digital blood pressure monitor keep giving an ERR4 message?
Here are the top 3 reasons for getting errors: 1. You're using the wrong-sized cuff. If you are extra large, you need a larger cuff. 2. You've incorrectly positioned your body. Ideally, your arm should be at the level of your heart. 3. You've placed the cuff incorrectly. Make sure the cuff is on your upper arm and the stethescope is placed over the place you feel the strongest pulse. I hope that helps!
Mar 30, 2017 | Walgreens Health & Beauty
Have a CVS blood pressure unit BP3MU1-1E. The cuff is too large for my 95 yr. old mother. How do I get a smaller cuff? The stores have none!!
Switch to the leg. You can take the pressure on the calf or the thigh. The thigh is easier. Place the cuff closer to the knee and if the sensor can be seen on the units cuff put that under the leg close to the knee joint. Inflate as normal. The reading may be higher than you expect by 10% So if it says 140/80 it would be 126/72
Sep 21, 2014 | Health & Beauty
Nned a larger cuff for taking blood pressure.
a standard cuff is at the size of 22 - 32mm, and a large cuff is at the size of 22- 36mm, there is also a extra large cuff size too.
Jan 11, 2011 | Homedics Health & Beauty
We have a large adult cuff. The index is in the "select adult cuff" zone. Is there an adult cuff for this unit that is interchangeable ( so we don't have to purchase a whole new unit...just a...
If your arm circumference suit this "large adult cuff" and the machine give good result, you dont need to change the cuff. Otherwise, you can just ask for replace with just a regular size cuff 22 - 32 or 36mm
Jan 06, 2011 | Mabis Health & Beauty
Digital wrist model # SR303S, shows error 3, has new batteries
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..contact the manufacturer for service..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Jan 04, 2011 | Samsung Health & Beauty
Where can i find an extra large cuff for my digital homedics blood pressure monitor
just go onto the homemedics site and take a look they probably do an extra large one ok good luck.
Apr 18, 2010 | Homedics Bpa-300 Deluxe Auto Blood...
The voice stopped working on the talking blood
something had got out of it place go and get a new thing
Jul 04, 2009 | Omron Healthcare Omron Hem 711DLX...
Reizen Talking Blood Pressure Monitor Kit w ear piece (BattaryAdaptor  I Logo
66 people viewed this question
Top Reizen Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Reizen Health and Beauty Expert? Answer questions, earn points and help others
