Question about Sony Handycam DCR-VX1000 Mini DV Digital Camcorder
Can't record image, time code flashing, what does this mean and how do I fix it?
  • kathleenfair Sep 17, 2010
    Great idea - thanks so much!
    Genius:
  • 1,812 Answers
This is most likely caused by a damaged or misaligned video drum and can usually be repaired. The part you need is available. However, it's expensive. About $200.00 and not a user serviceable. It will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Posted on Sep 17, 2010
  • 1 more comment
    Thanks, Rick! This camera is now 15 years-old. Guess with that cost, I could buy a new Sony HD camcorder for under $800. Too bad, the camera was the best low-light camera I've ever had.
  •  Rick J Riggins
    Rick J Riggins Sep 17, 2010
    You could probably sell the camera for parts on EBay for $600.
Daihatsu problem
John the red flashing symbol is your mil lamp that is indicating a misfire condition and is an active code that reqires maintinence have a local parts place scan your obd2 port an run a scan on trouble codes most likely p0300 random misfire most probable cause is burnt out plugs or coil pack bad reccomend plugs an wires should fix that problem unless you have a stretched timing belt causeing misfires have it checked at a repar shop ask for codes an google it an it will tell you what the code means if the repar shop wint tell you. Be prepared for s tuneup
Jun 22, 2014 | 2005 Daihatsu Sirion
I have a 1994 plymouth voyage se and it will not strat. It tell me to check gauge light comes on. what should i do or what does that mean?
Turn key to on ( not start) then off, then on, then off, then on and leave on, and have a pen and paper ready to record flashes of "check engine light". It will flash then pause between second number of 2 digit code. Then a short pause and flash again, pause, then flash. For example: if it flashes 2 times, then pause, then flashes 2 more times, that would be code 22. If it flashes 3 times, pause, then flashes 5 more times, that would be code 35. As I said, there will be a short pause between 2 digits, as well as after number. Write them down as they come up and get back to us with those codes for advice. When you get code 55 ( 5 flashes, pause 5 more ) that means end of message. Those codes should point everyone in right direction of trouble spot.
Jul 31, 2011 | 1991 Plymouth Grand Voyager
Can't erase?
Do you mean it will record new material but not erase the old, or that it will neither record or erase? Can you play old recordings?
Try removing and reinserting the flash card. If that doesn't fix it, try a new flash card. If that doesn't fix it, you need to take it to a qualified technician.
Nov 15, 2009 | Tascam Dp-02cf Digital 8-track Recorder
My 2003 H2 engine light flashes but no trouble code.
When the light flashes it means you have a catalytic damaging misfire happening.. Most likely a coil or spark plug issue but could be something else. Get it fixed ASAP because if you toast your cat its going to get expensive
Aug 10, 2009 | 2003 Hummer H2
Diagnostic Troubleshooting Codes for 1996 Chrysler Sebring Cvtble
FIRST YOU TURN IGNITION SWITCH ON WITH ENGINE OFF.LOOK AT MIL LIGHT IT SHOULD COME ON 3 SECONDS THEN GO OFF IT NOT THEN YOU GOT BURN OUT BULB OR A CIRCUIT PROBLEM.IF ALL IS WELL. ATTEMPT TO START ENGINE.TURN OFF IGNITION. WITH OUT STARTING ENGINE.TURN IGNITION ON OFF ON OFF AND WITHIN 5 SECONDS RECORD 2 DIGIT DIAGNOSTIC TROUBLE CODES.DISPLAYED BY FLASHING MIL LIGHT.YOUR MIL FLASHES WILL BE YOUR CODE LIKE THE MIL LIGHT FLASHES 5 TIMES THEN PAUSE FLASHES 3 TIMES THAT CODE 53 THAT YOUR CODE.IT LIKE MORSE CODE.WHEN DONE TURN OFF IGNITION SWITCH.GO TO AUTO ZONE OR ADVANCE AUTO GET HAYNES COMPUTER CODE BOOK. TO GET CODE MEANING OR WHAT SENSOR GONE BAD.HOPE THIS CAN BE SOME HELP.
Jul 27, 2009 | 1996 Chrysler Sebring
Check engine light flashing a code. what does this mean
Please visit http://www.troublecodes.net/neon/
for clarification of your error code. But I strongly believe you fixed a low rated fuel pump.
also from your explanation you got code 55 which means no error code was recorded.
Rate this please.
May 29, 2009 | 1995 Plymouth Neon
Does not "flash" or produce image on the page
Try unplugging and this may reset it let plug out for 15 min!
Jan 25, 2009 | Sharp AL 800 Copier
Record the image
Full size image: Approximately 48 seconds for Super Fine images, 5 seconds for Fine, 2 seconds for Standard, 1.5 sec for Economy Half size image: Approximately 12 seconds for Super fine images, 1.8 second for Fine, 1.5 second for Standard, 1.3 second for Economy. The recording time may vary according to the scenes.
Sep 19, 2005 | Konica Minolta DiMAGE E201 Digital Camera
Can this model record without a memory card?
This model comes with 8.9MB of flash memory built in, which means you can record without using a memory card. Even when using flash memory, however, you still need to set the correct date before recording. If you do not set the date, certain functions may not operate and proper image recording may be impossible. Also, folders created automatically by the camera will not be named correctly if you do not set the date
Aug 29, 2005 | Casio Exilim EX-P700 Digital Camera
Can I save images I record using an uncompressed (TIFF) format?
Yes. When displayed, an uncompressed (TIFF) digital image is clearer and higher quality than a compressed (JPEG) image. You should remember, however, that it takes longer to save an uncompressed image, which means that the recording interval between images is longer. Recording Interval with JPEG Format (Compressed):?2 seconds (3072 x 2304, Normal) Recording Interval with TIFF Format (Uncompressed):?65 seconds (3072 x 2304, TIFF) • In the TIFF Mode, you cannot record until the save operation of the previous shot is complete. • The above times are based on save operations using a Panasonic 64MB SD memory card. • The above times are approximate and for reference only. They are not guaranteed. • The actual time required to store images depends on shooting conditions and the memory card you are using.
Sony Handycam DCR-VX1000 Mini DV Digital Camcorder Logo
60 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
