Question about Eureka 2961AVZ Bagless Upright Vacuum
I just bought a new belt, put it on, took two swipes, smelled burnt rubber again. My new belt broke. Why?
  • 4,059 Answers
The beater bar is probably not turning. It get's jammed up with hair and strings and Christmas icicles and anything else on the floor. Taking the bar out and cutting all the stuff off is the easiest way to clear it. Make sure it turns freely before you hook the belt to it again and watch it when you turn it on to see if it's turning.
Posted on Sep 15, 2010
Smell of burnt rubber
Hi, the smell of burnt rubber is an indication of a broke or stretched power head belt. The belt can be accessed usually form the bottom. Chrs
Feb 21, 2011 | Bissell 6594 PowerForce Bagless Upright...
Why is my making a really loud noise and smells burnt when I turn it on. I have a new belt on it.
Improper installation of belt can result in a loose or off center belt which will flap and make lots of noise. It can also result in the burning rubber smell. The belt is probably ruined now, and will need to be replaced again. Make sure new ones are installed and centered correctly.
Oct 03, 2010 | Sharp Vacuums
Changed belt in my vacum and it is now smoking and i smell burnt rubber
Check the brush and make sure that it seated correctly...between pulling on the new belt and getting the brush back into the slots sometimes it will bind up...
You also will now want to put a new belt in now... the belt is toast if it smoked...
heatman101
Sep 01, 2010 | Eureka 4467AV Upright Vacuum
Simplicity freedom vacuum has a burnt rubber smell
If the belt is continually wearing out I would think that the brush cylinder is not free to rotate. Take the belt off and ensure that the brush cylinder moves freely. If is does not, then you need to investigate why - probably something wound round it that has jammed it.
Apr 06, 2010 | Simplicity 7250 Deluxe Vacuum
Vacuum smells like rubber burning. Replaced belt. same result
My vacuum's belt fell off, So I fixed it. Two days later my vacuum wouldn't turn on, so I opened it up again and took out a dust ball in between the electrical wires. I turned it on and sparks and snapping sounds came form the motor. Also burning rubber smell, What wrong? Is my vacuum fixable?, or should I buy a new vacuum?
Jan 15, 2010 | Oreck XL2000 Bagged Upright Vacuum
Eureka 2961 BVZ no suction, burning smell
I have the same vacuum. The burning smell is letting you know that your belt is either broken or about to break. I have had mine for a year and have had to replace the belt 5 times. Now I have to replace the brush roller 'cause it broke under normal use. My next vacuum will be a Dyson Ball.
Jul 05, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Rainbow Vacuum smells like something is burning.
Your belt is worn and that is why there is a burnt rubber smell. You need to change your belt. You can find a replacement belt and instructions here:
Rainbow Replacement Belts
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Belt problem
the brush is jammed most likely or not in correctly
Aug 08, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Electrolux Hi-light
Burnt smell is probably the belt slipping. Even though it looks OK, either the belt needs replacement and/or the roller needs cleaning and/or lubrication at the ends. Try cleaning the roller ends first and then light lubrication with WD40. If belt works, you are done. If not, replace belt.
Feb 15, 2008 | Electrolux Central Vacuum
Eureka 2961AVZ Bagless Upright Vacuum Logo
48 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
