Adapter I have an older tv with only one connection on the back. is there a 3 pronged adapter i can buy to make this work?
Is the inside of the plug on your tv yellow? If so, then you can only connect the tv using a composite cable, which means it needs to receive a composite connection. In your case, you've probably got a dvd player that you're trying to hook up using component (red green and blue cable). Unfortunately, you can't just reduce a component to composite, so there aren't any plain old adapters that will work and converters are pricey.
Do you have a composite (single yellow connector) or your dvd player? If you're not sure, post the Manufacturer and Model # of your dvd player.
If you have composite out on the player, that's how you will have to hook it up. if you don't have a single composite cable, just use one of the connections from the component cable. Just remember to use the same color on both ends.
Posted on May 16, 2008
WwWhere do colored plugs attach on back of older tv? Have several plugs
Hello Jessie,
New audio/visual equipment is daily
less compatible with "older" TVs"...
There ARE adapters available to achieve
certain levels of CONNECTIVITY but
Those adapters will seldom give you FULL
FUNCTIONALITY...
"Older" TVs if equipped with "RCA" (PHONO TYPE) jacks
are fairly obvious by the color of the audio...
(usually red & white)
and the video (used to be a single "yellow"
I'm going to keep this short...
Evoltuionary TV connections is a really BIG subject...
You need to disclose more than "OLDER"
But my best advice is to cave in and buy (or borrow)
yourself a MODERN TV that will accept the
"several plugs" you have.
Carnac
Carnac the Magnificent
May 11, 2017 | Televison & Video
Where is the model number and where do I put it in online to get the correct service manual?
If it does not have a regular 3 line cable connector on back of tv screen you need to buy an adapter for it. I know most of the TV's I have including a older flat screen they have the HDMI connection or the 3 cable connection with yellow,white,red connections on back of tv for these older devices. Rich
Jan 13, 2015 | Televison & Video
How do hook my tv to cable
If you don't have the male end on the tv itself, go to radio shack, best buy, etc and pick up an adapter. One end has two prongs that screw to the back of the tv where you would attach the prongs of 'rabbit ears' antenna. The other end of the adapter has the male end that screws into the cable.
Oct 28, 2014 | Televison & Video
I am using the three prong adapter that came with my ps3 but it isn't working on the tv I'm currently using. Does this have something to do with the tv or with the cable?
It could be the adapter, and could very well be the tv. try getting another adapter and if it dose the same thing it the tv and you can just take back the adapter.
Aug 14, 2011 | Sony Playstation 3 (PS3) Console
I am trying to hook up my Philips 19PR19 (made in 1998) tv to the dish network receiver, it has 3 prongs diff. colors attached and the cable cord is already to go in the wall...I don't see anywhere on the...
Because your TV is an older one, it might not have, what they call RCA inputs (the 3 colored cable) Red-audio right, White-audio left, Yellow-video. If I understand you.
You do have the option of using the 75-ohm coaxial cable inputs. Signal comes in from outside to the 722k, Output of the 722k to the 75ohm coax input on the back of the TV. Tune your TV to ch. 3 or 4. Make sure the switch on the back of the 722k is set to the same.
If you really want to use the RCA colored cables, then you need to buy an RF modulator, which integrates older tv's to newer products. But usually dvd players, not necessarily cable boxes, but it would work if hooked up correctly.
You plug the RCA red, white and yellow from the 722k, into the rf modulator, choose channel 3 or 4 on the modulator
Connect 75ohm coax cable from rf modulator to TV 75ohm coax cable input. Choose channel 3 or 4 on the TV.
Hope this helps.
Apr 07, 2010 | Philips 19PR19 19" TV
When playing games the screen on tv has white lines and the screen shakes.
Have you tried this PS3 on another TV?
We've had some older TV's that will do that on their own... that's the only reason I ask.
http://www.gamespot.com/pages/forums/show_msgs.php?topic_id=26081756
Well there are various opinions on this forum, but the one shows up most definitely as a solution is to prevent the ground prong on the PS3 power cord from getting into the socket, something to do with a ground-loop issue. They suggest getting a 2-prong to 3-prong adapter/extension, or, cut off the ground-prong.
Other things mentioned elsewhere include purchasing non-oem video cables... people suggest that the ones which come with the PS3 ****.
I myself have never experienced these issues, so I cannot verify them first-hand.
About the screen shakes... here's a fixya link which seems to get to a successful resolution.. check it out:
http://www.fixya.com/support/t658852-screen_flickering_shaking
Jan 13, 2010 | Sony Playstation 3 (PS3) Console
I do not know how to install my Retro Duo Nintendo to my LG tv. Where do I plug in my S-Visual wires?
Not all new tv's have S-Visual inputs. What you need is an RF Switch. You can find them at any electronics store (even walmart).
Check which one you buy or have a sales associate help you find the right one. Some RF switches (sometimes called modulators) only help you to plug multiple 3-prong av cords to a single av input on a tv. Others will convert your older Coaxel (cable cord) or S-Video (circle with multiple holes) into a 3-prong to the tv.
Also make sure that the RF you buy either comes with a 3-prong AV cord or buy a cheap one (cheapest you find in the store; it doesn't have to be long)
Dec 12, 2009 | Nintendo Super NES Console
Buzzing in speakers of cinema surround
i have the same problem. haven't tried the fix yet, but someone recommend connecting the two pronged power cord to an adapter that switches it to a 3 pronged (adds the ground prong). i guess the adapters are less than a dollar and can be bought at most places.
Dec 04, 2007 | Audio Players & Recorders
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
