Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Water Uptake Hose Split
How do you remove and replace the Water Uptake Hose Assembly?
  • Anonymous Mar 28, 2014
    Hose is split
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=40471&thid=602269
Posted by jre8655 on May 16, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Floormate H3000 Upright Wet/Dry Vacuum. You can down load the owner manual from the Hoover website www.hoover.com . I looked 2 the owner’s manual and it does not show the clear tube but the vacuum does come apart and just back track the clear tube and mark the screws when you disassemble the unit. Other wise , please call the factory or a local Hoover warranty station in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on May 29, 2008
  • Steve Hryb
    Steve Hryb May 15, 2011
    your answer is usless
How to replace a belt?
first of all take off front assembly. turn over front assembly and then undo clips on the bottom, then turn top knob on front of assembly which hold up the belt, and it will come free then you need to pop out either side of the brushes to take off old belt and re-install new and then turn know to uptake the belt and replace back on the main vacuum body.
Jun 28, 2014 | Kirby Vacuums
Hoover Floormate--Does not pick up water.
First make sure that you are getting suction from the bottom of he machine. Most of the time the squeegee is worn out which does not allow it to pick up the water like it use to. Turn over the machine and inspect the squeegee. If it looks worn or bent then it may be time to replace it. You may also consider replacing the filter. These are the two most common parts that wear out.
here is a link the parts for your a h3000 floormate
H3000 Parts
Feb 07, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
My floormate isn't picking up the wet water
Check the uptake tube. When you push the release button and bend the top of the unit towards you, you can see the tube coming out of the floor assembly. Mine split right there.
Jul 10, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Floormate will not **** dirty water.
Check the hose coming out of the floor assembly. It tends to split, keeping it from picking up the water
Apr 20, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Where is schematics online to replace lower hose assembly part
There is no schematic that I am aware of. I can tell you that from experience that this repair is very difficult. Basicaly the upper and lower handle unscrew along with the tank base, the hood comes off. the lower handle will split but not comes completely apart to remove the hose section. When reassembling, be sure to put the back hose gasket in the correct position. Look at it (take a picture) prior to repair first.
Feb 02, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Main unit wont **** up water but hose does, is there a clog some where and if so how do i fix it.
hello your problem could that you have a clog in the front of the machine take the screws loose that hold the front cover on and check to see if the uptake sceen is clear.
Jan 24, 2009 | Bissell 8910 ProHeat Clear View Upright...
Hoover floor mate stopped picking up the water
Usually when this happens, it has to do with a dirty or bad filter(#45, 40112050). Or the recovery tank isn't seating like it should. Maybe this picture will help.
Feb 24, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Won't suck up water from floor
1. Check all the tubes from the nozzle to the collection tank and make sure they are not clogged up. I've had tht happen pretty bad before. 2. Check the squeegee. If it is damaged or torn, replace it.
Aug 27, 2006 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
401 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
