Question about LG LRFD22850 Bottom Freezer Refrigerator French Door
Motor noise and flashing light
The icemaker wont drop ice and it has a loud hum plus the light in the door flashes. It does make ice but we are afraid the motor is going to burn up. We have switched off the icemaker but it still hums and flashes. Any thoughts on what could be happening?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
The problem you may be having is an ice build up. Defrost the unit and take out the back wall of the freezer. Cut the insulation off as in the picture and it will solve the problem. What happens is a little bit of water gets trapped and then over time it becomes a massive ice ball that can block the fan. First you hear the ticking noise and then you get ER FF error.
Sgt 48
Posted on May 31, 2008
Whirlpool Side by Side. Husband replaced fan motor inside freezer. Ever since it's been replaced, it runs frequently and hums loudly. Any suggestions. He took the interior back out and it doesn't hum.
The fan blade touching the interior back cover????
May be the fan motor shaft is too long or may be he did not push the fan blade well inside into shaft so it is to much out. Thus touching the wall cover plate..????
Sep 24, 2014 | Whirlpool Refrigerators
Loud ticking noise when i close freezer and lights on icemaker flash like a stobe light. fridge and freezer wont hold temp. ice amker and water dispenser dont work?
if your lights burned out recently and the digital temp read-out is now dark also,burned out lights will cause a power surge and will destroy the main-board circuit trace(mother-board), it is located in the back side of the refrigerator, in a small plastic case,when you remove it you will see a burned spot on the circuit board and the loud clicking sound is a relay on the board trying to latch to light the bulbs and operate the unit
Feb 21, 2010 | Frigidaire FRS3R5EMB Side by Side...
Red light flashing on ice control panel in freezer section of my Whirlpool gold GS6NHAXVT02. I have the setting on ''on''.
The red light is supposed to flash. The number and frequency of flashes is a diagnostic tool we use to determine what is wrong if the icemaker is not working. If your icemaker is not working, count how many flashes before it rests, and let us know. Good Luck, Appliance Specialists
Jan 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice is made but dispenser does not spin so ice wont drop
Hi, Remove the ice bin. With the freezer door open, push the door button and then push the ice dispener button to see if the auger motor is turning. If it does turn, check and see if there is something in the ice bn blocking the auger.
Please try this and let me knwo.
Thanks
Vic
May 24, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Humming noise & color changes picture flashes from red to green
our 62hm15 had the same problem and it was the dmd fan, which means the whole light engine needs replacing. this was going to cost us $1600. I hope yours is under warranty
Aug 09, 2008 | Toshiba 62HM95 62" HDTV
Ice maker has ice in it but will not dump in bin!
before i would worry about the lights flashing lets pull the front cover off of the icemaker and verify that the drive gear is not broken.
on the bottom of the icemaker is 1 screw. remove that screw then just slide the entire icemaker out of the refrig so that you can access the front cover. if the gear is broken just replace the front motor module pt# 8201515
if the gear is fine then located in the toe grille of your refrig is a tech sheet that will help you troubleshoot red light blinking.
Dec 17, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Intermittent Loud Whirring Noise
sounds like the evaputaor fan motor.. may need to replace.. check to see if anything maybe hitting fan blades
Sep 30, 2007 | Frigidaire FRS23R4A Side by Side...
LG LRFD22850 Bottom Freezer Refrigerator French Door Logo
143 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
