Question about Car Audio & Video
My amp gets real hot and then turns off, what is the problem? Also If i choose to the setting of "Low Pass" as the filter option, would this blow subs?
    Scholar:
  • 156 Answers
Your amp is getting hot possiblily due to under power? of the amp. First try to turn the gain down (sensitivity) see if that helps, if not then add a fan to the amp to cool it. Also put the amp in an area where air runs freely....
Low pass means that it is allowing low frequency to pass by so No it won't blow your subs but it will hit certain frequencies!
Posted on Sep 19, 2010
Blowing out cold air even when the heater is set to hot setting. Feels like cold air is coming in from the outside. The colder it gets outside the colder it gets inside. 2007 jeep commander
ok,
first the engine gets hot, if not there will no cab hot air.
so if you scan it the PCM shows the ECT reading over 180f,
does it. if not , the thermostat is bad.
in order !!!
blower works so not blower.
leaving dampers, does the HVAC self test pass?
if damper are in heat mode, that leaves only 2 left
(possible air filter there? ,its and option) in the dash HVAC box.
the heater core is packed. (in air side or water side)
Nov 20, 2016 | Jeep Commander Cars & Trucks
My heater do not blow hot
along with what Charlie said I would do a reverse flush on the heater core. junk can build up in the core overtime and reduce if not eliminate the flow of coolant/heat.
flush it with low pressure multiple times in both directions when vehicle is cold.
Feb 24, 2015 | 1998 Honda Accord
I put a sub in my 2002 Altima but when I turn it up the bass cracks on the door speakers??? What do I do to get all the bass on the sub
Hi Ethan,
What you're looking for is called a "crossover". A crossover is an electronic filter for an audio or speaker circuit. In an audio circuit, a crossover is used to prevent or pass certain frequencies or a range of frequencies from passing through it. Since your sub will reproduce the bass or low frequencies, you don't want other speakers to reproduce them. A band pass filter on your door speakers will do this for you. A band pass filter passes only a range or "band" of frequencies and blocks those that are above and below the range or band of frequencies selected. Installing a band pass filter will prevent the very high & very low frequencies from getting to the door /dash speakers. Likewise, you should consider connecting a low pass filter to your subs, too. The low pass filters work a little differently from of the way band pass filters work - they only allow low frequencies to get to the sub - blocking all the other higher frequencies (your other speakers are better suited to reproduce those). Lastly, you would install a high pass filters on tweeters. Tweeters are designed to reproduce only the high frequencies - sending mid and low frequencies to them is wasting power and can cause damage to them.
You purchase the filters for specific crossover points (the block / unblocked point) as determined by the individual speakers. If a sub has a frequency response of 20Hz - 100Hz, a low pass filter of 100Hz would be ideal. Remaining filters would need to begin at 100Hz - assuming the mid-range speakers have a frequency response beginning at 100Hz. A band pass filter of 100Hz - 3KHz would fit the bill nicely if the mid-range speakers go up to 3Khz Match the high end of the band pass to the high end of the frequency response of the mid-range speakers. Next, a high pass filter at 3KHz would allow only the high frequencies to your tweeters. Basically, you want to have the entire audible range 20Hz - 20KHz covered by the speakers and have the crossover points that match the frequency response ranges of the speakers.
I hope this helps & good luck!
Apr 12, 2012 | Pioneer Car Audio & Video
Trying to use apa450 on a pair of 4 ohm jlwo subs front channel has boss boost switch & hi pass switch only?
yes. this is not a jl audio amp. and does not give you the option to choose hi and/or low pass on the front side.
of course, you know the assumption is made that you'll drive the front amp through mid-range and tweets and the rear amp through your W0's.
you can however,
a. turn off the xover so you get the full range sent to your W0's.
b. then it would be easy to place an in-line low-pass coil so your subs only see frequencies below he cutoff range you choose.
its a pretty common electronics store/Radio Shack item, just a few bucks too.
May 06, 2011 | Clarion APA450 Car Audio Amplifier
I have an auto amp with no crossover for subwoofer. i am wanting to know if i can hookup a passive crossover for sub speakers through amp to speakers say from radioshack or other home speaker system? i...
You could go with a type of passive crossover, and that should allow you to also control gain as well as the bass input, and you can also go with a low pass filter as well. These are quite inexpensive at Wal-Mart and other places, and just run in-line with the wiring. There is no real cutomizability with the latter option, but it could be a means to get better sound while you save for a stronger crossover.
Sep 26, 2009 | Car Audio & Video
Volfenhag amp adjustments
Firstly, you will want to set all options to a low pass, so the high frequencies are filtered away from the subs, avoiding damaging the voice coil. Start with the Gain of the amp about 3/4 of the way up, and all other knobs, such as the bass knob to the lowest setting. From there, test your subs for soujnd, and then change the gain and amount of bass for the sound you desire, since each person is different. I have my gain about 1/2 way up and the bass about 1/4 of the way up. If you have a crossover knob, set it to the highest frequency available, since the low pass will filter all the high frequencies out anyway.
Sep 23, 2009 | Volfenhag ZX-5007 Car Audio Amplifier
Bass only going to rear speakers. How do I get
Hello michaelandta,
Check your filter settings on the front channels. It sounds like they may be set to "high pass" which would eliminate the bass frequencies. If you are using the amp to power normal speakers, it's usually best to set the filters for "full range". If the amp only has "low pass" and "high pass" settings, turn them both OFF.
Hope this helps.
Sep 11, 2009 | Zapco I-450 IFORCE SERIES 4 CHANNEL CAR...
Music is coming through my sub as well as bass
your amp might have a low pass filter and a high pass filter make sure it is switched to low pass and that should prevent music from coming out of the subs and just alow the bass too
Jun 11, 2009 | Car Audio & Video
Want too get best low bass i can from this amp
you turn your low pass filter (LPF) on the amp down to your desired frequency, but the box you have it in will drasticly change the sound (if you werent aware) hope this helps!
Mar 22, 2009 | Jl Audio 500/1 Car Audio Amplifier
Amp
I think it's a bad switch
Jul 07, 2007 | Pyle Blue Wave PLA2740 Car Audio Amplifier
Car Audio & Video Logo
108 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
