Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Whirlpool stacked washer dryer LTE 5243DQ6
My contractor just hooked this unit up and when the dryer is turned on it is extremely noisy. It turns and heats up but the noise is unbearable. If it helps figure out what is wrong, it was shipped on its side (not upright). Could something be mis-aligned?
Thank you in advance.
Bob
email: kastner51@aol.com
  • Kastner May 25, 2008
    Thank you for reply. If is helps, this W/D is brand new and has never been used. Unfortunately it is out of the warranty perior coverage. Nothing should be worn since it is NEW.
I got anothe solution.
First turn the power off than open the back panel of the dryer.you will need to open the blower assembly cover on the left and you will notice the cove has weather strip all around it.
Make sure the weather strip doesn't touch the blower wheel than put it back together.Good luck
Posted on Jun 07, 2008
    Genius:
  • 1,122 Answers
MAKE SURE NO SHIPPING BLOCKS WERE LEFT ON ALSO TURN THE INSIDE DRUM BY HAND TO SEE IF IT TURNS SMOOTH,YOUR BACK DRUM ROLLERS MIGTH BE OFF,THANKS-MIKE
Posted on May 29, 2008
Open dryer door, and reach up to the top of drum and push on it very gently. If it moves more than 1/4 inch or more, the dryer guides needs to be replaced. Sadly the guides are for front and rear so that means the drum has to be removed and the guides in the rear has to be changed first.
It will involve some time so be very careful! Another thing is to check for the dryer idler arm pully. if this pully is squealing/worn out, it will also need to be replaced at the same time you replace the guides.
My suggestion is to call your contractor and make them come out to see if they damaged it. Your local appliance repair store can also sometimes help.
Posted on May 19, 2008
We just purchased a stack unit and the space is confined so during instalation into a cove we will have to stack the units hook them up to electrical water and exhaust and slide them in.How long is the...
I think you have to but them separate from a hardware store. They come in dirrerent lengths. If you purchased one it seems that you would know that by reading the instructions.
Jan 12, 2011 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LTE 5243DQ stacked washer-dryer: water
Dirt or wear is at the shutoff valve. It will need to get to it and clean it out and check its seat condition.
Nov 04, 2009 | Whirlpool LTE5243D Top Load Stacked...
Whirpool Thin twin with noisy dryer?
You could have a wore out dryer belt wich could cause the drum to feel lose, Also you could try checking the glides underneath the front of the drum to make sure they did'nt slip out of position. This helps the drum turn with little or no friction.
Mar 11, 2009 | Whirlpool LTE5243D Top Load Stacked...
Washer noisy while spinning
You probably have a balance problem. You will have to get a service tech to replace the shock absorber/stabilizers (there are 3) in the unit.
Jan 31, 2009 | Kenmore 98702 Stacked Washer/Dryer
Thin twin stacked washer/dryer...dryer won't stay on
My twin stacking whirlpool washer/dry. The timer switch kicks on but does not dry clothes kicks off after 5 mins but, clothes still wet.
Nov 12, 2008 | Whirlpool LTE5243D Top Load Stacked...
Repair manual for Whirlpool twin thin stackable LTE 6234?
Hello BUNNYLIB5
Welcome to Fixya
You said, Great website. Thanks so much for all the info. Where can you download a user manual for my Whirlpool LTE 6234? Mahalo, Lee.
Here is the whirlppool site
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm
=LTE6234DQ&siteCd=WHRCOM
Sep 25, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washer doesn't work, dryer does- HELP!
  • check your breaker, one side of the 220v circuit breaker may have tripped causing only one of the units to work.
  •  turn your breaker off then back on.
Jun 28, 2008 | Frigidaire FLEB8200DS Top Load Stacked...
Whirlpool stacked washer and dryer
unplug unit then wait 1 minute and replug..if still lock out replace control board
Jun 27, 2008 | Whirlpool LTE5243D Top Load Stacked...
Agitator very noisy while washing
There is a small roller that tightens the drive belt for the drum inside this unit. If it is loose it makes a squeaking noise. Tightening this may solve your problem. You will have to take off the back panel to do this repair
Jan 28, 2008 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
121 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
