Question about Whirlpool Dryers
Stopped heating. worked on two loads just before.
  • Whirlpool Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Sep 15, 2010
Why does the blower motor stop going a steep grade on a.c. or heat setting ?
The blower stops during steep grades when AC or defrost is on to lighten the load on the engine
Mar 18, 2015 | Cars & Trucks
I have a 2 year old LG DLE5001w dryer. It stoped heating heater element replaced on 11/21/14. Worked 2 loads stopped heating, replaced switch, worked 3 loads stopped heating replaced thermostats. Did
Most Dryers has a thermal switch that when the air flow gets so hot it will shut down the dryer until it cools down or on some models the thermal switch has to be replaced .. The most common problem to cause this is a restricted air flow somewhere in the exhaust of the heated air causing the dryer to reach too high of temp, which could cause a fire .. Hope this information is help full......
Dec 29, 2014 | LG DLE5001W Dryer
My dryer has stopped heating completely. Worked fine for six years and stopped heating four days ago.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Nov 06, 2010 | Frigidaire FLEB8200DS Top Load Stacked...
Our top load washer washes a couple of loads fine
Sounds like the thermal breaker inside the motor is heating up and triping it resets when it cools either the motor it's self is geting hot or something is causing it to over heat. Just a guess hope this helps
Apr 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Heat is sporadic. model DDE5900RALWH erial G246248G
Make sure lint filter is clean also frre airflow from Exhaust, if tisis ok could be thermostat or element, try basic stuff 1st...
Feb 22, 2010 | Dryers
Dryer stopped heating
this is likley to be the heat seconsers or its the heater/s burnd out if one of the elements have died on you it will only partly dry the washing,, not a hard job to fix but still a bit pricy,
Oct 24, 2009 | Kenmore 88732 Top Load Stacked Washer /...
No heat after drying several loads
the vent in your house may be stop up in the wall.
Jun 15, 2009 | LG DLG3788W Gas Dryer
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Amana electric dryer will not heat....LEA60AW
check your wall vent to make sure it's not clogged,also check the fuse on the heater box it may have blown,without the fuse the heater will not work,you can check it with an omns meter-mike
Feb 23, 2009 | Dryers
Dryers Logo
27 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
