Question about Garmin GPSMAP 295 GPS Receiver
My gps 295 shuts down during the satellite acquisition sequence
2 Suggested Answers
SOURCE: Garmin GPSMAP 172C - cannot find satellites (WAAS)?
WAAS is a seperate service from GPS. It provides GPS corrections so if you can not get WAAS there is no big problems. you unit just wont be as accurate as normal. WAAS only is for North America and EGNOS for Europe. You may want to turn WAAS off for now. I suggest trying a update for the unit. You will need a memory card and Garmin USB programmer. Then just go to garmins site to get the latest update. If you need a USB programmer feel free to Contact GPSCity.ca or GPSCity.com. They are the leading experts in Garmin GPS.
Posted on Jul 12, 2010
How due i get my gps to load
A GPS may not act normally if it has too few satellite signals available.
You may have to have a clear view of the sky for acquisition of several satellites.
Jan 09, 2015 | Nextar GPS
How to set time and date on GPSMAP 295
Set the time zone and daylight savings according to the instructions on page 76 of this manual. The time and date are automatically set from the information received from the GPS satellites.
Jan 28, 2013 | Garmin GPSMAP 295 GPS Receiver
My gps172c fails to receive any sats...same problem last year,boat laid up over winter and in spring when set switched on no sats picked up .Garmin sent me software update and problem solved. Unfortunately...
Similar problem with a Garmin finding current position taking very long time every spring after boat being laid up in winter.
See page 4 and 5 to speed up the process.
When Garmin does a power-up the current version is revealed during the boot. This will ID the update!
The at home(current position) delay maybe due to satellite re-position during the winter and has been the only problem. Once acquired have little or no problem rest of season.
See page 6 on link manual where you can observe the satellite acquisition. During the initial acquisition process it seems to start over many times and eventually locks them in one at a time!
http://static.garmin.com/pumac/GPSMAP172C_OwnersManual.pdf
Hope this helps?
Jul 04, 2017 | GPS
Jul 12, 2010 | Garmin GPSMAP 172C GPS Receiver
GPSmap 296 doesn't show any satellite signal
Check that the date shown on the unit is correct. If not, choose autolocate and allow about 10 minutes for the unit to find satellites. If this works, then the internal lithium ion battery is defective.
Jun 02, 2010 | Garmin GPSMAP 295 GPS Receiver
Just opened up a new magellan roadmate 1412 and can't get a satelite signal.
satellite acquisition takes several minutes with good line of sight to the sky, assuming the unit dose see at least 1 satellite in the sky this would mean theirs issues with the internal antenna or the receiver is malfunctioning, when you said opened up the new unit i assume you disconnected the small connectors, maybe one is not fully conencted or the wire became disconnected during reasembly. theirs alsoa chance the unit has to be reset.
Dec 21, 2009 | Magellan RoadMate 1412 Car GPS Receiver
Can't find any satellites
If you don't use it very often it can take time to find its location. Have you tried using the 'set initial location' option? Once it knows roughly where it is and what time it is it can then work out which satellites it should be looking for instead of searching for any/all of them. The manual does say that it will take time if it has no initial clue as to where on the planet it is, and if you're on the move while it's trying to work that out then it may take even longer. Obviously, if it has a poor view of the sky, or if most of the satellites are behind you and you have a tin roofed aircraft then that will probably not help either.
How do you know the antenna is OK?
Do you have the remote antenna to try?
Mar 18, 2009 | Garmin GPSMAP 295 GPS Receiver
My Garmin Nuvi 360 lost satellites during use and can't locate
I had the same problem with mine...I shut it down and left it off while giving it a full charge...
Jan 14, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
My Garmin Nuvi was working fine, but then lost satellite reception during use. Since then it has been unable to locate any satellites and therefore find a GPS signal. Any ideas?
Here is an email received directly from Garmin: I have tried this myself on several units and it worked. I can't gurantee it will work for all cases. In some cases the antenna may be defective. Also, click on the "wrench" symbol, then the "gear" symbol and then "about". Look at the number after the text "GPS S/W:" It should be a number like 2.9 or 3. If its 0.0, then the antenna is not communicating with the main board.
"Thank you for contacting Garmin International, I am happy
to help you with this.
Sometimes the almanac data that your nüvi stores for satellite acquisition becomes corrupted. This causes acquisition to become slow. To correct this we need to perform a master reset. This procedure will erase all user data.
With your nüvi powered off, press and hold the lower left corner of the screen. Next, turn the power on. Continue to hold the screen until it asks if you really want to enter maintenance mode. Next, choose clear user data. The screen will flicker a bit and then start up like it did when it was first turned on. Follow the directions to set time and location. You will have to reacquire satellites by turning on your nüvi with the antenna up outside in full view of the sky. This one time
acquisition may take up to 30 minutes. "
- Jim
Sep 24, 2008 | GPS
No GPS fix
Had same problem on trip down the pacific west coast. Best solution is to replace your GPS antenna to the 175 ( It is a problem on the 120)and upgrade the software. If this is not feasible, shutting the unit down for about 10 to 15 mins. sometimes dumps the GPS data overload. and allows FIX re-acquisition.
Jun 09, 2007 | Raymarine E120 GPS Receiver
Garmin GPSMAP 295 GPS Receiver Logo
27 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
