Question about Texas Instruments TI-30XA Calculator
TI-30XIIS: Cannot remove back cover. We removed the 4 screws from the case and have been trying to pry it open and slide it open with no success and using a few of different screwdrivers. Please help. Carl
4 Suggested Answers
vladp995
  • 81 Answers
SOURCE: TI-30xiis calculator
Press [2nd][FIX][.] the FIX is the rounding function.
Rate me, thanks.
Posted on Jul 08, 2009
vladp995
  • 81 Answers
SOURCE: TI-30xIIs calculator
This function is FIX or FSE near the dot [.] or above it, so press [2nd] the the [FIX] where it located button [.] for example then the dot [.] him self: [2nd] [FIX] [.]
Rate me, thanks.
vladp995
  • 81 Answers
SOURCE: rounding function on my TI-30xIIs calculator, it won't turn off.
Rate me, thanks.
How do I remove the "Slide Cover"?
First remove the six screws on the back cover. The top of the calculator will be still attached by three clips. Twist the calculator slightly to make the lower end of the gray part of the calculator pop up from the black base. Pry the base off by applying gentle pressure or by prying the sides outward. Be sure to short out the "reset" button after changing the batteries, by rubbing a coin over it.
Dec 27, 2014 | Texas Instruments TI-30XA Calculator
How to open an APC BX900R so I can replace the fan ?
slide the front bezel there is still 2 screws holding in there
Dec 16, 2012 | APC Back-UPSĀ® XS 900 (BX900R) UPS System
How do I open a TI-30XIIS?
It isn't glued, it just has a couple of tight clips there. Take a tiny flat screw driver and gently pry it open. It will pop open. I just finished changing my battery and that's what I had to do. It came apart and went back together just fine.
Nov 18, 2012 | Texas Instruments TI 30XIIS Scientific...
Change batteries
1. Remove slide cover. Place calculator face down.
2. Using a small Phillips screwdriver, remove screws
from back case.
3. Remove back case.
4. Remove discharged batteries.
Caution: Avoid contact with other calculator
components while changing batteries.
5. Install new batteries positive side up, as shown on
diagram inside case.
6. Replace back case, and then replace screws.
7. Press OFF ON ON.
Caution: Dispose of old batteries properly. Do not
incinerate batteries or leave where a child can find
them.
Your calculator cannot hold data in memory when
batteries are removed or become discharged.
Feb 02, 2011 | Texas Instruments TI-30XA Calculator
Directions for changing battery
2. Using a small Phillips screwdriver, remove screws from back case.
Caution: Avoid contact with other calculator components while changing batteries.
5. Install new batteries positive side up, as shown on diagram inside case.
7. Press: [OFF] [ON] [ON].
Caution: Dispose of old batteries properly. Do not incinerate batteries or leave where a child can find them.
Your calculator cannot hold data in memory when batteries are removed or become discharged.
Nov 27, 2010 | Texas Instruments TI-30XA Calculator
How to replace a battery on a TI-30XA calculator
7. Press off on on.
Nov 16, 2010 | Texas Instruments TI-30XA Calculator
How do you open a TI-30Xa in order to replace the battery?
To replace the batteries:
• Remove slide cover. Place calculator face down.
• Using a small Phillips screwdriver, remove screws from back case.
• Remove back case.
• Remove discharged batteries.
• Install new batteries positive side up, as shown on diagram inside case.
• Run a coin across the reset pad on the upper right hand corner of the printed circuit board.
• Replace back case, and then replace screws.
• Press [OFF], [ON/C], [ON/C].
Note: The calculator cannot hold data in memory when batteries are removed or become discharged.
Oct 07, 2010 | Texas Instruments TI-30XA Calculator
LCD Monitor
1st remove the base cover by by squeezing to release the clips and remove the 6 base mounting screws. 2nd remove the 5 screws in the back cover. 3rd push and pry at the parting line to release the clips. 4th remove the base mount by removing the two attaching screws and sliding it down about a quarter inch. 5th remove the steel cover by removing the 4 wires, two screws from power outlet, two bolts from vga plug, and the other screw in the cover. and there you have it.
Oct 26, 2008 | Acer AL1717 17" LCD Monitor
Want to open my maxtor one touch, any idea of the best way, and what is that small openning at the back
It's a pain but you can do it if you are careful. Remove 2 screws on back panel, then gently remove back panel. Now work on side/front panel (one piece) GENTLY. They have little plastic clips that will pop out if you are careful. The you can remove 2 more screws on side that hold metal halves together. Top comes of clamshell style. Good luck !
Mar 30, 2008 | Maxtor OneTouch II external hard drive...
Scratched audiovox screen
You just need the touch screen (digitizer). There are actually 2 pieces that are mistaken to be the screen. The other piece is the touch screen and beneath that is the LCD display. The outer scratched screen is the touch screen.
Ebay, and various online retailers have them for around $40. You can do it yourself if you try.
To replace, you need a micro phillips head screw driver and a T-6 torx screw driver. Also patience, and a steady hand.
You must start at the back of the device, through the battery door. Remove the 2 micro phillips at the top of the battery opening (one is covered with a tamper evidence sticker). Then carefully, starting at the bottom of the camera plate, pry upwards and to the speaker to unsnap the smaller facing. Remove the camera by gentally pulling up to unplug, then unscrew the circuitry and remove. This will expose the 4 torxs (2 in batt opening) to remove the back cover. After screws are removed, gentally work the covers snaps loose around perimeter and remove (pay attention to the speaker wire) unplug it from the circuitboard. Pull the antenna nub to detach.
Remove the screws holding the circuitboard, unpluging the keyboard and slider ribbon cable. Gentally hold the ribbon cable and remove the securing tape. (dont pull too hard!) Pulling the circuitboard exposes the 4 micro phillips screws (2 each side) to detach the slider.
Remove the 4 torx screws on the back of the LCD slider, then gentally pry around to separate the housing.
To remove the LCD / Touch screen you must unplug the ribbon cables. To do this you need to open the connector's trap (black bar). It hinges. Just pry upwards from the ribbon side. Once bar is lifted ribbon will slide out. Be careful if you need to remove the gold foil tape. Remove the single screw holding the ear speaker, and the ribbon should come out. The screen will not come out after gentally prying it free of the holding snaps in the casing.
Installation is simply the reserve. Hope this helps....
Dec 07, 2007 | Audiovox PPC 6700
Texas Instruments TI-30XA Calculator Logo
190 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
