Question about Microwave Ovens
My GE Microwave Encore first gave an F10 error code, saying there was a short in the control panel. After unplugging and then restoring power, all appeared fine. Microwave worked fine. A while later, it just started up and began cooking all on its own, counting down a phantom hot beverage cooking time. The spontaneous turning on has occurred a few more times. Ever hear of this sort of short? What parts should the technician bring to replace? I have owned the microwave less than 4 months.
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Spacemaker XL 1400 Microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 28, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic Model NN T964SF inverter
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Aug 02, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Spacemaker Microwave Clock inop
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
You can download GE owner's manuals and installation instructions here.
Posted on Oct 21, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave Oven Does Not Start Cooking
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If yours is not shown at the parts site or manual site linked above, Please reply back with your brand and model number so we can help you.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Dec 25, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE microwave (jvm1740dm1bb) - Control panel inop
That model number is not quite right. I'm going to assume it's JVM1740DMBB01.
(If that's not right, please check the tag inside the oven & reply back)
The membrane keypad is not available as a separate part, so you would have to order the control panel frame which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
The part number you need is WB07X11040 and you can find helpful exploded view diagrams and order this part here for $107.00 (compared to $164.75 from GE!)
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jun 02, 2009
How to fix GE OTR microwave F10 error.
The GE F10 error code for a microwave oven indicates a Shorted Touch Screen.
Mar 23, 2015 | GE Microwave Ovens
GE JVM1440SH001 f3 error
see the commentaries and repair:
F3--Shorted key panel(touch pad), will occur if a shorted key panel is detected continuously over 60 seconds.
test the following:
1. Door is not closed (some models).
2. You waited to long (open and close door to wake it up).
3. Controller is confused (pull plug for a minute or two to reset).
4. Defective interlock switches.
5. Faulty controller or its power supply.
6. Touchpad or controller board contaminated by overenthusiastic cleaning.
7. Defective/damaged touchpad.
Jul 31, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
F3 Message on microwave
Hello
GE microwaves with a digital display will show an error code when there is a problem or malfunction with the unit. One type of error code that will be displayed on a GE oven and require troubleshooting is a code F3. An F3 error code indicates that the keypad for the control panel is bad or has a short. This will cause the microwave to beep continuously after the set clock message appears.
Unplug the power cord for the microwave from the electrical outlet. Pull the microwave out from the wall and set it on a table or the counter.
Find and remove the two screws from the top of the grille, on the font of the unit, with the Phillips-head screwdriver. Pull the grille off of the microwave.
Find and remove the screws that are used to secure the control panel to the microwave frame. Lift the control panel unit up and away from the microwave.
Find and remove the screw that is used to secure the green ground wire. Pull out all of the connectors and ribbon cables from the control board.
Apply heat from a hair dryer to the front of the control board for at least 30 seconds. Make sure the hair dryer is at the low setting. Pull up on one corner of the top membrane, then peel it off of the control board.
Repeat Step 5 for the other membrane that is on the control board.
Insert the pliable circuit of the new membrane through the opening in the control board. Remove the wax backing to expose the adhesive for the membrane. Place the membrane onto the control board.
Peel the wax backing off of the top membrane, then place it on the control board.
Place the control board back on the microwave and secure it with the screwdriver. Reattach the grille, and set the microwave back in place.
Plug the microwave back into the power outlet and reset the clock.
Oct 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave/convection oven (a GE unit model JES1290SK) started beeping every few seconds and displaying F6 on the control panel. I unplugged it and waited several minutes and when plugged in it displays...
The technical sheets in my files do not list F6 on the error code chart for GE microwaves.
Generally, these are the error codes possible on GE microwaves:
F1 open thermal sensor (convection models)
F2 shorted thermal sensor (convection models)
F3 key panel shorted for more than 60 seconds
F4 open humidity sensor
F5 shorted humidity sensor
There should be a "mini-manual" (technical sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
Jan 15, 2011 | GE JES1290 Convection/Microwave Oven
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
Key panel (touch pad) shorted This code will occur if a shorted key panel is detected
continuously over 60 seconds. Replace key panel (also called touch
pad).
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
F3 error code ge microwave
No, unfortunately the membrane keypad is not available as a separate part on this model.
You would have to order the control panel frame, which comes with a new keypad already installed.
The part number is WB07X10883 and you can get it for $86.82 here.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Nov 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Have a GE model JVM1430 that has error code of F-3
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
So until it is repaired, please leave it unplugged or leave the door open.
On these models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
It is usually called the "Control panel asm" in the parts list (ref # 105 on the exploded view) .
You simply move your circuit board into the new frame. That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Sep 25, 2009 | GE Microwave Ovens
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 17, 2009 | GE JVM1430 Microwave Oven
Works for approx 30 secs then it cuts off with a error Code F7 message.
Assuming yours is a model KHMS2050SSS0, here is what the technical sheet says about the F7 error code:
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check the magnetron.
6. Check P65 connection on the relay control board.
7. Check the P56/P66 connection between relay board and relay control board.
8. Check wiring to the 1200W inverter and control system. See “Checking Inverters.”
9. Check operation of all interlock switches.
10. Replace all parts and panels before operating.
11. Plug in microwave oven or reconnect power.
12. Check voltage at 4903-1 on relay board. If it is 120, unplug microwave oven or disconnect power.
13. Replace inverter.
14. Replace all parts and panels before operating.
15. Plug in microwave oven or reconnect power.
16. If problem persists, unplug microwave oven or disconnect power.
17. Replace relay control board.
18. Replace all parts and panels before operating.
19. Plug in microwave oven or reconnect power.
20. If problem persists, unplug microwave oven or disconnect power.
21. Check for reversed plug connection on controls or loose wiring.
22. Replace all parts and panels before operating.
23. Plug in microwave oven or reconnect power.
(This troubleshooting guide presumes one does not know how to test electronic components. That's why they say to replace and part and check it again.)
If yours is a different model number, please reply back.
May 26, 2009 | KitchenAid KHMS2050SSS Microwave Oven
Ge microwave spacemaker xl1800
F-3 means shorted touch panel pad. In order to attempt clearing the code yourself, please follow the steps below:
  1. Press CLEAR/OFF or CANCEL.
  2. Program control again.
  3. If the fault code appears again, disconnect power to the microwave for 30 seconds.
  4. Program the cooking function again.
  5. IF it comes back up you should change out the panel hope that helps, good luck
Dec 12, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
264 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
