Question about Porter Cable Cable 135 PSI, 15 Gal. Oil - Free Horizontal Compressor CPF4515
Heres the probem-when I turn the compressor on,it acts like the motor brushes are bad. It turns about 3 rotations and quits. If I take the outlet line off the head,it runs fine. As soon as I hook the outlet line up,it dies. I have chcked and cleaned the check valve and checked all the lines for restrictions. I have even taken the check valve out,hooked up the line and ran it that way and it worked,it just wont run when everything is re-assembled.
  • 43,501 Answers
It sounds like you have narrowed it down to the check valve...are you sure you are installing the check valve in the correct direction??? Can you blow through the check valve???
Seems like you have a real good handle on everything just need to find out why it won't work with the check...the check seems to be blocking the air flow for some reason...
heatman101
Posted on Sep 15, 2010
My A-9 KA coffee mills are working perfectly. 2003 never quits, 2006 was a royal pain and burrs/pin replaced and working perfectly. Now, I have a 2004 used for decaf, actual use from purchase about
I don't see a question in the paragraph but common problems for the A9 are 1) Shear pin 2) Motor brushes 3) slow motor operation
If shear pin then the grinders won't turn or may intermittently rotate if pin is half broken
If motor brushes worn to nubs then a fast clicking noise and sporadic on off operation followed by no operation
If motor is slow then the commutator may need cleaning requiring removing the rotor
Jul 03, 2014 | KitchenAid A-9 Electric Burr Grinder
Fedders 208/230 split system w/ dual cap , compresser runs but fan wont unless you give it a push , compresser won't restart if relay is hot
All kinds of stutt happens when you dont have a condensor fan motor. You need to change the run cap on the motor.
Aug 06, 2011 | Heating & Cooling
New compressor, when i turn it on it spins fast for 5- 10 seconds then slows down til it stops completely,oil is full,reset button on motor does not trip nor does my 50 amp breaker, i put voltmeter on...
Try tightening the drive belt first. As pressure builds a loose belt will start slipping and slows down . It will eventually stop if not cut off!! If this is not the problem remove the drive belt and run the motor 5 minutes or so and see if it runs OK. While the belt is off and motor not running turn the compressor by hand. If it hard to rotate it may be bad. .I have seen both bad motors and pumps from the factory on new units. It's very seldom it happens but can and has.Also look on the fly wheel. Their should be an arrow showing correct rotation. Make sure rotation is correct. since it is 1 ph it should be. If motor or compressor is bad there should be an 800 # on the tank. Give it a call or call your nearest IR distributor.You can also call the 800 # and talk with someone in tech support.
Jul 07, 2011 | Ingersoll Air Tools & Compressors
Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
  1. Unplug cleaner from electrical outlet.
  2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
  3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
  4. Place ends of Rotating Floor Brush down into slots on sides as shown.
  5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
  6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
  7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
If suggested solutions do not correct the problem, call:
BISSELL Consumer Services 1-800-237-7691
Monday - Friday 8 a.m. - 10 p.m. ET
Saturday 9 a.m. - 8 p.m. ET
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
The brush will not rotate. I thought this was a direct drive system.
Note: The brush will not rotate when the machine is locked in the upright position, because an internal micro-switch turns the brush motor off.
- Check the belt through the clear brush cover. If this appears damaged or broken, please take your machine to a local BISSELL Authorized Service Center to have this replaced. If the belt is intact, please continue checking the following:
- Ensure both power switches are turned on when you check for brush rotation.
- Unplug the power cord and remove the handle completely. Slide handle back into the lower section of handle, ensuring the screw is in tight. If the handle is not aligned properly, this will affect the power of the brush motor.
- Look for debris wrapped around the brush (i.e. string, hair, fibers, etc.). When the machine is unplugged, cut away any visible hair, fibers or debris from the brush roller. This brush is NOT removable from the machine.
- If something has become lodged in the foot and the brush shuts off, turn off the vacuum and unplug this from the outlet. You can now remove the obstruction. The brush will automatically reset when the vacuum is plugged in and turned back on.
If you continue to experience difficulty with this, please take your machine to the following Service Center in your area. The warranty on this machine is five years.
Aug 12, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Beater brush
- Make sure brush switch on the handle is on.
- Check the belt through the clear brush cover. If this appears damaged or broken, take your machine to a local BISSELL Authorized Service Center to have it replaced. If the belt is intact, please continue checking the following:
Jun 15, 2010 | Bissell Healthy Home HEPA Bagless Upright...
The beater brush wont spin because the brush roll is always in the off position. Moving the carpet/hard switch doesn't turn it on.
Hello :
Try this please :
Switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
Or Maybe the belt is broke. You will have to replace the belt before the roller can spin. You must have run over something in the carpeting like string or whatever to have it break. Happens all the time. Get several replacement belts to keep as spares while you're at it as nothing is worse then having to vacuum and no spare belts.
Try this also please :
Things You'll Need: Phillips head #2 screwdriver Replacement belt for your vacuum model Spray lubricant, such as silicone spray or teflon lube.
1: Unplug the vacuum. Never work on an electrical appliance when it is plugged into an electrical outlet.
2: Turn the vacuum over and locate the plastic or metal plate that covers the rotating brush. Remove this plate.
Note: This plate is typically attached by a small number of Phillips head screws or by levers that turn and lock the plate in place. In either case, removing this plate is a simple task.
3:Identify the vacuum's rotating brush. This brush should have a black rubber belt wrapped around it, and stretched around the metal shaft of an electrical motor mounted somewhere toward the back of the vacuum.
4:Verify that the brush will rotate freely. Examine both ends of the brush to ensure that no threads, string, yarn, etc. have become wrapped around the ends and thus inhibited a free rotation.If there is foreign debris, remove the brush by sliding it up, away from the bottom of the vacuum. Remove the debris
5:Lubricate both ends of the rotating brush with the spray lubricant. Replace the brush into the grooves which hold it in place
Replace the existing belt on the brush assembly, or replace a broken belt with a new vacuum belt.
6:Verify that the brushes now turn freely when back in place and that the motor shaft turns as the brush rotor turns.
PLEASE DON'T FORGET TO RATE !
Apr 22, 2010 | Hoover U6630-900 WindTunnel Bagless...
Bravetti Food Processor Model KP80B
That's alot of bad outlets.Are you sure there's nothing wrong withe the processor? Just kidding. How long have you had this processor? Any chance of taking it back?
If not, try this. With the unit unpluggedput an attachment on that you can hold onto and try to rotate the motor. Not all are tested and sometimes the motor brushes are not making good contact. If you turn it manually you may get lucky and set them to work. If you get it running, chk with power after several turns, run it constantly for abot 5 minutes to seat the the brushes. Remember to have it unplugged when you have your hand on the attach ment. Good luck. Ned
Aug 24, 2009 | Bravetti Quad Blade Food Processor
Aquabot T2 moving in circle
The T2 has one set of belts and a single drive motor. Since one side must be rotating to be moving in a circle, we can then assume that the motor and belts are not the issue here. The two halves of the brushes are connected by a mechanism that allows them to turn independently of the other half. They can rotate about 3 times before they “lock” and act as it were one (not split) brush. This “slippage” is how the cleaner turns. Make sure that they do lock by manually rotating one side. If not, you will need new brush/wheel tubes.
A parts diagram can be found here:
Aquabot Parts and Repair
Jan 09, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
Brush won't rotate when pushed forward
I had the same problem . The reason it acts like that is due to the cable that runs from the vacuum motor to the brush assembly has an intermittent open. My fix was to find the small cable that was causing my troubles and splice it. Making sure that I recovered the insulation. Of course my local repair station wanted to replace it for $75 labor plus parts and keep it for 3 days. I took it home and did it in 30 minutes .
Dec 12, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Porter Cable Cable 135 PSI, 15 Gal. Oil - Free Horizontal Compressor CPF4515 Logo
160 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
