Question about Whirlpool LEW0050P Electric Dryer
My dryer(LEW0050PQ2) power button appears to operate and red button comes on when power button is pressed. But when the start button is pressed-there is a high pitched tone and the red light starts to flash, but dryer does not operate. Do you think this is a starter switch problem or a door switch problem?
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 15, 2010
Power button is pushed in and appears broken. drum light is on, but cannot operate power button.
Giving Brand and Model Number of this unit will get you better results. The Start Button seldom fails. The problem is generally elsewhere preventing the Start Switch from getting power. Dryer Model Number are generally inside the door.
Nov 23, 2015 | Dryers
Whirlpool lew0050pq2 electric dryer
very good chance that is it
Apr 06, 2014 | Whirlpool Dryers
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
My Asko W6021 won't start and the door won't open when buttons are pressed, although the power appears to be on (the red light comes on after power button has been pressed)..
Open the drain hatch at the bottom left of the machine. Open drain pump and check to make sure tat there are no foreign objects in drain pump. Object in the drain pump will prevent the unit from operating properly. If there is water still in the unit, you can use the drain hose to drain the washing machine. If you would like to open the door manually, disconnect power, remove screws holding red plastic handle in place. pull handle.
Mar 15, 2011 | Asko W6021 Front Load Washer
My Fisher paykel dryer does not heat
Thermostat Cutout – Manual Reset (Electrical)
Type SPST 30 Amps/240 Volts AC
Trip Temperature 212°F (100°C)
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs
Conductivity Contact Impedance Check
To enter the conductivity contact impedance check, enter the diagnostic mode
as described above, then press the Auto Dry up button five times. In this
mode, touching damp clothes or fingers across the conductivity contacts will
cause the LED display to change. If the contacts, or the harness to them,
have gone open circuit, no change will occur in the LED display. This is a
useful method of checking the integrity of the sensor circuits.
To exit the diagnostic mode, press any cycle button.
Entering the Data Download Mode
button. This enters the diagnostic mode.
(c) Press the Regular button.
Encoded data is transmitted serially out the red Auto LED, and is be captured
by an optical download pen attached to a PC where “Smart Tool” software
interprets the data to aid servicing.
To exit, press the Regular button.
Entering the Showroom Mode
(b) Press and hold the Air Dry button, then press the Power button.
The LEDs will flash in a random sequence.
To exit, turn off the power supply to the dryer at the wall.
Tell me what sort of faults codes you can come up with and I will tell you what it means but in the meantime reset the limit and clean out the lint problem, open the stopped up vent. That dryer has to breath or that safety will kick out again. I have the manual
Sep 05, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Dryer won't start when start button is pressed and held
check door "close"contact button/switch usually the culprit..
Aug 02, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Dryer will not start
Forgot to check the thermal fuse. Now working after changing fuse.
Mar 21, 2009 | Kenmore Dryers
Start Button will start dryer but won't stay on!
pull end caps off just grab at top of plastic and pull towards you remove the 2 screws underneath lift console up and roll back next to timer is a small control bd to right of that are 2 relays 1 with red wires for element and 1 with blue wires for motor first try switching the relays they are identical and will work for either 1 ..try if works replace relay ..if still not working suspect control bd
Jul 01, 2008 | Kenmore 63952 Electric Dryer
I NEED FAULT CODES FOR DRYERS
PF Power Failure
“PF”
flashes to indicate that a power failure occurred while the dryer was
running. Press START to continue the cycle, or press PAUSE/CANCEL to
clear the display.
F-01 Primary Control Failure “F-01” flashes when there is a primary control failure. Replace the machine
control electronics. See Accessing & Removing the Electronic Assemblies.
F-02 Keypad/User Interface
Failure
“F-02”
flashes when there is a stuck button or user interface mismatch. This
fault code will ONLY appear when in the diagnostic test mode. See TEST #5.
F-22 Exhaust Thermistor Open “F-22” flashes if the thermistor is open. See TEST #3a.
F-23 Exhaust Thermistor Shorted “F-23” flashes if the thermistor has shorted. See TEST #3a.
F-26 Motor Drive System Failure “F-26” flashes if there is a motor drive system failure. See TEST #2.
F-28 Moisture Sensor Open “F-28” flashes if the moisture sensor strip is open. This fault code will ONLY
appear when in the diagnostic test mode. See TEST #4.
F-29 Moisture Sensor Shorted “F-29” flashes if the moisture sensor strip has shorted. This fault code will
ONLY appear when in the diagnostic test mode. See TEST #4.
1M 2M 3M 5M 6M
= Contacts closed
Contacts
Function
Start
Run Red
Lt. Blue
Blue-White (Elec)
White (Gas)
Green-Yellow
Red
Black-White
BLACK
BLUE
WHITE BLUE
WHITE
WHITE
Pluggable Drive Motor Switch Gas Valve - Gas Dryer
Centrifugal Switch (Motor)
Gas Valve this is about close as i can come its matag electronic but not comercial should be about the same software though some where on or in the dryer should be a tech sheet with codes
May 21, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool LEW0050P Electric Dryer Logo
277 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
