Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Blinking red lights
When I turn on my 37PF7320A, the green ligh comes on but immediately turns into a one red blinking light followed by four consecutive red blinking lights. I do not know if it is the power supply or other component. If it is the power supply, is there a place where I can find the schematics and instructions on how to change the power supply? My set is out of warranty and the local repair shop wants $650 which is way to much money. Thank you in advance for any assistance yo may provide,
  • Sanchofiris May 18, 2008
    Thank you very much for your help. Would you happen to know the power supply part number and a reliable source for purchasing it? After this fiasco, I am not sure I'll ever buy another Philips product again.
    Thanks once again for your help.
Buy a service contract for the money cant beat it.
Posted on Jun 24, 2008
Yes i have had 3 older models that did the same thing it is a 47 ohm resistor on the power supply
Posted on May 18, 2008
    Genius:
  • Philips Master
  • 1,689 Answers
Call the manufacture of the TV set to find out who their authorized service is in your area.
These sets are expensive to service. They are serviced by mainly board replacement. There is very little support for component level service.
The boards use high density SMD technology, and is all uPC controled using firmware.
As for your fault, you would have to determine if the power supply is in the protect mode because of a defect on another board, or if the fault is the power supply only. This is usualy done by doing board swapping to find out which boards are defective.
Some of the manufactures will sell the service manuals for their flat panel sets. Not all the schematics will always be complete. The information is mainly for how to replace the boards, and do the factory level calibrations if necessary. You will need the proper calibration and diagnostic tools to do the tests and adjustments as indicated by the service manual.
Jerry G.
Posted on May 16, 2008
  • Jerry Greenberg
    Jerry Greenberg May 19, 2008
    The only reliable parts support is Philips or one of their authorized parts distributors. They should be able to sell the service manual and circuit boards. Your set is mostly serviced at the board exchange level. There is very little component level service supported for these sets.
    I do not have the service manual for this set, and therefore I cannot tell you the part number, or give any detailed service advice for the particular model. I can give you information genericaly.
    I would not advise changing the the power supply yourself. It is very possible that there is a fault on another board that is causing the power supply fault in the first place. You may change the supply and still not have the total problem fixed. I have had many instances where there were faults on a board that also caused damage on other boards.
    The authorized service center should have access to a full set of boards to use for testing during the diagnistics procedure. This is providing that the model is not obsolete and the parts are still available.
    It can be a very expensive ordeal to try to service a set yourself, unless you have the setup for proper diagnostics, calibration, training, and service information. You may end up buying a number of boards and still not have the set properly fixed, and also require adjustments that you don't have the setup to perform.
    Link For Philips:
    http://www.lighting.philips.com/gl_en/su...
    Jerry G.
I went to turn on my tv tonight and it started to come on - then did not.. a blinking red ligh is where the green light usually is - I tried to unplug it and re plug it in.. no help
When you turn the TV on, does it attempt to come on and then off? Does the light go green when you attempt to power up and then goes red?
Jan 31, 2011 | Philips 37PF9631D 37 in. LCD HDTV
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Mitsubishi Proj. TV,Model VS-50603, S/N 119340, won't turn ''ON'' when pushing TV ''ON'' button or remote. Green ''ON'' light comes on and then immediately off. Whats the problem?
62" mitsuabishi WD62525 had it over 5yrs now, we have been changed lamps three times,(geee lots money!!!)it worked ontill now...
two weeks ago blinking red lamp light was on , i thought lights out again so soon, i order new lamp, i cant turn on TV but blinking green timer light, TV is not working, try reset botton, turn off TV few days.
Please help
Lilly
Dec 06, 2009 | Televison & Video
Philips LCD TV - Red blinking lights
I would check the capacitors on the power pack for failed or blown ones. doing this work will require soldering skills
FYI
Mar 21, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Blinking Red Lights
Sound like an error code 14 (Audio supply) is beeing blinked...
You probably would want a qualified technician to take a look at it.
Jan 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 37PF7320A/37 won't turn on
That blinking led is an error code for the audio standby board in the set. It should not go out this soon and yes it should last longer.
Aug 21, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
TV will not turn
Please unplug the tv for 30 min and then plug it back to power supply and see if the lights are blinking again...
Good luck......
Jul 16, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
TV will not turn on. I get a green light and 6 blinking red lights.
I had the same problem. Red light flashing 6 times over and over. Yes, it turned out to be the power supply board. Cost me $250 to have it repaired! I am very disappointed in Philips quality.
Jun 10, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 37PF7320A 37 will not turn on
moswt of these i have come accross is either an SSB(small signal board) or a logic board. in rear cases it even requires the replacement of the panel unfortunety ther are a number of test that need to be done on the unit to figure which one it is and i dont recomend you try them yourself.
Jan 16, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
209 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
