Question about Brother Sewing Machines
My Brother LS-2125 keeps having the needles breaking. It was hitting the metal plate but then I tightened it, and it was hitting the bobbin and i took it apart and put it back together and was fine while turning the needle up and down with my hand but then with the fabric there it broke instantely. Could it be the timing? I don't even know what that is or how to fix it but then is the only solution i can find on the internet that i havent tried
    Genius:
  • 1,788 Answers
Call Brother at 1-877-276-8437 and ask them.
Posted on Sep 16, 2010
  • Mary Dunn Sep 16, 2010
    Did you try a new needle? You may have a bent one.
The tread is breaking while sewing with brother ls 2125
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Nov 12, 2012 | Brother LS-2125 Mechanical Sewing Machine
Brother xl-2600I
try changing the needle
try tightening the top tension one number or letter at a time till the stitch look better
take the bobbin out & reinsert the bobbin into the bobbin case, also make sure the bobbin is not damaged
clean under the needle plate & in the bobbin area for loose threads or lint
May 22, 2012 | Brother LS-2125 Mechanical Sewing Machine
Brother se 400
try changing needles
also possible that the machine is out of time
Apr 09, 2012 | Brother SE400 Computerized Sewing Machine
My needle keeps breaking. So I unthreaded everything and cleaned the bobbin area. Per the manual i rethreaded everything but when i get to the part of turning the balance when toward me until the needle...
check to make sure the needle is inserted correctly--flat side to the back of the machine
that the needle is inserted all the way up in the needle shaft
check the needle clamp screw to make sure it's not loose
is the needle correct for the fabric that's being sewn
check to make sure the needle is not hitting the needle plate- if it's hitting the needle plate or the bobbin case then it's possible the machine is out of time & would have to be serviced because they have the proper tools to time it
Aug 26, 2011 | Brother LS-2125 Mechanical Sewing Machine
I have had this machine since i was 10 and im 16 now. i dont remember how to start.. i have the needle loaded and the bobbin loaded, whats next?
Rotate the wheel until the bobbin thread is picked up. Once the bobbin thread is up, you can start sewing. Be sure to turn the machine on.
If the machine is making noise, unscrew the top and/or bottom plates and oil any place where metal rubs on metal.
May 27, 2011 | Brother LS-2125 Mechanical Sewing Machine
My needle keeps hitting the plate and breaking. How do I fix this?
Take the needle plate off and see where it needle is connecting with the bobbin. The bobbin case may not be in place and this is what the needle is hitting.
Feb 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
May 27, 2009 | Brother LS-2125 Mechanical Sewing Machine
Needle hits plate and breaks or bends wont line up
If your needle is hittle the face plate, then it is out of time.. I would take it to your local repair center.
Apr 24, 2009 | Brother LS-2125 Mechanical Sewing Machine
Needle getes broken
Check to see if your needle plate is gouged or signs that the needle is hitting the plate. If so, you may be pulling a little too hard when the fabric is feeding. Sometimes when you pull too hard, it pulls the needle back and it will hit the plate instead of going into the needle hole and you will break needles. Try just letting the fabric feed itself and you simply guide it to make sure it stays in a straight line.
Feb 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
The thread keeps breaking from the needle the bobbin thread is loose
Check to make sure the there is no damage to the needle plate. A gouged plate will rub the thread when it passes and break it. Make sure the tension number is between 3-5. To check your bobbin thread, once you put the bobbin in and have it threaded properly, pull on the thread, if it has a little resistance, it is probably good, if it pulls through too easily, adjust the screw, just a very minor bit until you feel some resistance. Then try again. Sometimes it takes a little back and forth to get it right, better to go in small amounts than large leaps.
Jan 15, 2009 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
52 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
