SOURCE: Player unable to load discs when inserted
http://forum.videohelp.com/topic350059.html
I think I found these adjustments! There are two tiny surface-mount potentiometers (could be capacitors also) sitting in the small circuit on laser assembly.
this is exactly response I would like to hear - an expert opinion!
What I did with help of 1mm-wide screwdriver:
1) There were two surface-mount potentiometers marked with C1 and D. I tried first D. Turned it clock- and counterclockwise by about 45 degrees.
2) After each turn I opened and closed tray to force the player read DVD disc.
3) It did not help, "NO DISC", then I tried the same with C1, and again, no luck.
4) Finally, I came back to D and turned it by about 180 degrees in one direction. IT WORKED!!!
Moreover, seem that now player reads content of the DVD discs faster then before. Probably manufacturer did not really adjust it properly and upon the time something has degraded, so it failed eventually.
SOURCE: Sony SLV-D350P DVD/VCR
try cleaning the lens as if its been sitting it could have a layer dust or dirt film that may need to be taken apart to clean properly. Good luck
SOURCE: Bad disc or insert disc problem
If you are using a copied disc try a real one. But this model of DVD Player is made so cheap. it sound like the laser assembly is bad or the motor that spins the disc is stuck or going out. If you are good at electroninics you could take the lid off load a disc and see if it spins if not give it a spin clockwise and see if it takes off. You probably should replace unit for price of a new one.
SOURCE: dvd player makes noise, doesn't read discs
mine did the same thing it just kept ticking when i wanted to play a disk, id take to top off with the four tiny little screws and hoover it, mine still makes a bit of noise but works x
SOURCE: Our DVD player just quit playing. Nothing works in
If it doesnt "spin up",it is probably knackered,best you buy a new one
