Question about Minolta Office Equipment & Supplies
We have a Minolta CS Pro that is displaying a trouble code of C00 70. We are a not-for-profit school and wanting to find out what is the problem.
  • 1,110 Answers
This service code C0070 is a universal code used by Minolta to indicate a toner bottle rotation failure. These machines add toner by rotating the toner bottle that you install in the machine. Most of the time this code is caused by a toner cartridge that has been installed incorrectly or has become dislodged from it's holder. To clear the code open the front door or toner door and remove the toner cartridge/bottle from the machine. Close the toner door and if needed open then close the front door to reset the code. Let the machine run. This may take several minutes and will allow the machine to bring the toner bottle receptacle into it's home position. Once the machine stops running completely, then you can re-install the toner cartridge. If the code does not come back you are ready to go. If the code came back after removing the toner but before you re-installed it then you have either a dirty rotation sensor or a bad toner drive motor and will need service.
If the code comes back after the cartridge is re-installed then there is either a priblem with the cartridge or with the toner bottle drive.
Most of the time though the problem will be resolved by the outlined procedure.
Posted on Sep 15, 2010
Testimonial: "I was able to fix the problem and one other glitch and get our copy back up and running without a service call. Great job! Thanks!!!"
Display error co500. Please help?
Open the front door, with power on. upper left small access cover remove and press trouble reset switch if the code comes back DO NOT RESET means a problem with the fuser (The hot Part) it can catch on fire that will ruin a perfectly good day. Have a tech come out look at it. He need to be old school that is a legacy Minolta machine, Now KonicaMinolta. For parts try this site.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Parts such as fuser lamp, thermistor and thermostat
Jun 17, 2015 | Konica Minolta 1149-0291-01 Minolta Cs Pro...
Display malfunction
sir,
Open the front door, upper left small access cover remove and depress the trouble reset, if the code comes back replace the exposure lamp bright light under the big glass
try this site for starters Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jan 26, 2014 | Konica Minolta Copier Toner EP6001 CS Pro...
WHY IS CODE C05/00 DISPLAYING ON MY MINOLITER PHOTOCOPIER MACHINE AND WHAT IS THE SOLUTION
The problem is in the Fusing unit.Open the front cover,move the upper half release lever,remove 3 screws the rear cover and the PWB boars is located 1 RESET(trouble) microswitch.Turn ON the copier press the microswithc and the trouble is reseted.
Dec 17, 2012 | Minolta EP1083 CS/PRO Copier
Minolta CS/Pro 1031 Refuse to work and display PC
Check your paper supply in the paper tray. PC means the machine thinks it has no paper or the paper did not feed. If making sure the paper is good and loaded properly does not solve the problem then pull out the tray completely and clean the rubber feed rollers inside of the port where the tray came out off. They should be about half way to the back and over to the right side. Most common cause of this problem is dirty/dusty feed rollers that are not pulling the paper up into the machine. Just wipe them down with glass cleaner of even a cloth dampened with water.
Good Luck and Thank You for using Fixya.
Jul 14, 2010 | Minolta EP1031/1031F CS/PRO Copier
Error code of C-50 showing in my CS/PRO Copier
C-05 Error code occurs on fuser unite.
When it display open back cover and press reset button.
Machine ready.If are not fix this problem.May be change or replace thermostat or lamp fuse.
Apr 06, 2010 | Minolta EP4000/5000 CS/PRO Copier
Cs pro minolta copier displays a code co6
Open close the front door if that does not work and the code comes back check you scanner cable underneath the large glass for the documents
Jul 16, 2009 | Minolta Office Equipment & Supplies
Code c40
I believe a c40 is the trans port sucation fan.... It is under the trans port belts. Did you try to reset the code? The Trouble rest botton is behind the display pannel control for brightness. Inside left side above the fixing unit.
Feb 03, 2009 | Minolta EP4000/5000 CS/PRO Copier
ERROR CODE CO5OO FOR MINOLTA CS/PRO 2080 ????
This is a lamp error, check that is not burned, or the thermal fuse.
1. Press the soft initialization on the right side of the control panel.
2. When the dot appears on the LCD after reboot, press the number 3 key.
3. The mode will change to the initialization screen.
4. Choose the selection for trouble reset.
5. After reboot the code will be cleared.
Warning: Be advised that with fuser codes, some RISKS are involved, PLEASE SEEK PROFESSIONAL HELP to reduce these risks.
Thank you and good luck!
Jun 18, 2008 | Minolta EP4000/5000 CS/PRO Copier
156 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
