Question about Victor 1220-4 Calculator
How do I set the date/time on a Victor 1220-4 calculator?
drknow
  • 44 Answers
SOURCE: set date
To set the date Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key once and the date will be diplayed, key in the info as follows: 1/1/08 would be keyed in as "1" "." "1" "." "2008", the display will show 1.1-2008 then press the clock/calendar key, the correct date will show up.
To set the time Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key twice and the time will be diplayed, key in the info as follows: 12:00pm would be keyed in as "12". "00", the display will show 12.00 then press the clock/calendar key, the correct date will show up. For 12:00am key in "0",".","00" as it expects to see 24hr time.
Posted on Dec 19, 2007
SOURCE: Setting time & Date
I copied this from another post & it worked for me:
To enter the date
1. Be sure to switch to "rate set" from GT
2. Enter the month
3. Press the decimal point
4. Enter the day
5. Press the decimal point
6. Enter the year
Example 3.09.2007
7. Press the button that look like a clock/calendar
To enter the time
2. Enter the hour (please use military time)
4. Enter the minutes
Example: 13.24 or 9.24
5. Press the button that look like a clock/calendar
Then change the "rate set" back to the GT setting.
Posted on Mar 24, 2008
SOURCE: EL 1801V - how to set time/date?
To change the date, enter the date in MM.DD.YY format, pressing the decimal key between the month and day (will show as a decimal on the display) and the day and year (will show as a dash on the display). Then, press the Time/Date key (the one that looks like a clock and a calendar). The new date will show on the display. Note that if the month is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. To change the time, enter the time in 24-hour HH.MM format, pressing the decimal key between the hour and minute. Then, press the Time/Date key. The new time will show on the display. Note that if the hour is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. Hope this helps! :)
Posted on Dec 04, 2008
SOURCE: Sharp EL-1801P III Calculator Setting Time & Date
1. Switch the GT*RATE SET button to RATE SET.
2. Press the date/clock button to display current time.
3. Enter time wanted using military time. 4:52 p.m would be entered as 16.52 (Note the 16 is followed by . then enter the 52. (ie. 10:45 a.m. would be entered as 10.45)
4. Press the date/clock button again to enter new time.
Just reset mine and is current. If the built in battery needs changed, access panel is on the back. It uses a watch type battery.
~DLS
Posted on Mar 16, 2009
  • 916 Answers
SOURCE: Setting the time & date on model # 2640
Here is the manual: Click Here
You need this program to read it: Click Here
Posted on Mar 24, 2009
How do you set the date on a Victor 1560-6 Calculator. I held down the date button on the unit and the number is flashing. I entered 08232010 for Aug 23rd, 2010 and I am not sure of the sequence to lock...
Immediately after entering the year part of the date, the display should revert back to a blinking first digit (in this case, the 0 to the left of the 8) while retianing all the following digits just entered. Simply press the Time/Date key again to lock in that date and stop the blinking. The same process applies for the time.
To clear the display of the time/date when using the calculator to actually compute something, press the C or CE button. This will result in a 0 appearing on the display. The unit is now ready for data entry.
Aug 24, 2010 | Victor 1560-6 Calculator
How do I set the time on my calculator
To set the time on this calculator, you must press and hold the time key until the display is flashing 0. (Hint: you will want the date displaying when you are going to set the time as when you press the time key to hold it, it will switch over to the time.) Once the display is flashing you type in the time using the keypad. If you were going to set the time for 9:30, you plug in 930 and push the time key again. If you need to set it for a time in the PM you would have to use the 24 hour scale; for example 1:30 PM would be 1330. To set the date, you press and hold the time key with the date displaying until the display begins flashing. Again you would use the numbers on the keypad to enter the date and press the time key again to set it. For 1/20/2011 you would type in 12011.
May 05, 2010 | Victor 1260-2 Calculator
SETTING THE DATE
Below are the steps to assist you in
setting the Date and Time on your calculator.
NOTE: The "Time Set", "AM/PM", "12/24" and "Format" associated keys are
on the faceplate above the respective key. Position the calculator so
that you can look directly over the keypad to see the notations.
Setting the date:
1. Press the CALENDAR/CLOCK Key. The default date will appear.
2. Hold the TIME SET key down for 3 seconds or until you see the first
digit begin to blink in the display.
3. Input the correct date.
4. Firmly press and release the TIME SET key. The first digit should
stop blinking and the date is then set.
Setting the time:
1. Press the CALENDAR/CLOCK key. The default time will appear.
NOTE: The seconds will disappear.
3. Input the correct time. If you need to adjust to AM or PM, press
the AM/PM accordingly.
stop blinking and the time is then set. The seconds will again be
displayed.
Follow by pressing the CLEAR key to return to the calculator mode. To
return to either the TIME or DATE, press the CALENDAR/CLOCK key to
toggle between them.
Jan 22, 2010 | Victor 1210-3A Calculator
I want to set the time and date on my calculator and need help Please give me the directions
1)Press TIME/DATE and then SET (The first digit of the month will flash)2)Enter the month MM using the number keys.
(The first digit of the date will flash)
3)Enter the date DD using the number keys.
(The first digit of the year will flash)
4)Enter the year YYYY using the number keys.
5)Press SET to confirm the date.
6)Press TIME/DATE and then SET. Enter the time using the number keys and press 12/24 to switch between 12-hour or 24-hour clock.
7)Press AM/PM to toggle morning or afternoon and press SET to confirm the time.
Oct 24, 2009 | Victor 1208-2 Calculator
I just purchased a new Victor 1220-3 Calculator. There were no istructions in the box. Can you email me the instructions or how can I obtain a copy of the manual? I can download from the internet. Jim
I couldn't find a manual for your calculator model .
It is a basic model though.
I suggest you check VICTOR TECHONOLOGY calculators page:
http://www.victortech.com/productLine.asp
Look for a calculator model that looks like yours, click on "Details" and you'll reach another page from where you can download its manual.
They are selling a refurbished 1220-3 calculator, but they don't give any link to the manual.
You might also find that other manufacturers calculators look and function like yours.
Aug 03, 2009 | Office Equipment & Supplies
Is there a way to get the time/day from being displayed? I just want 0.00 on the display. Also, I can get the time correct, but not the date. This machine does not have a time/date button, just a time...
press the CA button to get your time/day from being displayed. For your date... whenever you press the time button to edit your time, press it again & your date shouold come up. the time/date button are both done with the TIME key.
Jul 30, 2009 | Victor 1260-2 Calculator
Mar 24, 2009 | Victor 2640 Calculator
Setting date and time
Turn the calculator on.
Hit the "C/CE" button and 0. will display.
Hit the "TIME" button so that the date displays.
Hit and hold "=" button until the month flashes. Now put in your date such as 11182008.
Hit the "TIME" button again so that the time displays.
Hit and hold "=" button until the time flashes. Now put in your time such as 1254. (12:54pm)
Hit "=" button to end.
Oct 14, 2008 | Victor 1212-2 Calculator
Change time & date on the victor 1530-5 adding machine
I recently solved this issue with my calculator
Press and hold the time key when the date is dispalyed. When the display flashes enter the date as a six digit date (example 110608 for November 6, 2008) Time needs to be entered in military time when changing time.
Aug 15, 2008 | Office Equipment & Supplies
Date and Time Setting
You can download the manual for the 1260-3 which I guess is very similar from the link below: http://www.victortech.com/admin/images/products/1260-3%20manual.pdf Here are examples of the date & time setting: Set DATE to September 14, 2004 (09-14-04) 1. Depress the C or C/CE key.Your display with show 0. and the tape will read 0.C. 2. Depress the TIME/DATE key and hold until the display is flashing. 3. Enter the month, in our example, 09. Your display will show 9. 4. Enter the day, in our example, 14. Your display will show 914. 5. Enter the year, in our example 2004, as 04. Your display will show 91404. 6. Tap the TIME/DATE key to set the DATE. Your display will now show 09-14-2004. 7. To PRINT the DATE, depress the (#/S) key, your tape will show # 9.14.2004. Set TIME to 4:37 PM 1. Depress the C or C/CE key. Your display with show 0. and the tape will read 0.C. 2. Depress the TIME/DATE key and hold until the display is flashing. 3. Tap the TIME/DATE key to go to Time Mode. 4. Enter the hour, in our example 16 in military time. Your display will show 16. 5. Enter the minutes, in our example 37. Your display will show 1637. 6. Tap the TIME/DATE key to set the TIME. Your display will now show P 04-37-00 and the seconds will begin counting. 7. To PRINT the TIME, depress the (#/S) key, your tape will show #?04?37. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 17, 2007 | Victor 1260-2 Calculator
Victor 1220-4 Calculator Logo
112 people viewed this question
Top Victor Office Equipment & Supplies Experts
Greg Cann
Greg Cann
D. E. Hev
Are you a Victor Office Equipment and Supply Expert? Answer questions, earn points and help others
