Question about Samsung LE40R74BDX 40 in. LCD Television
My Samsung LE40R73BDX/XEU does not receive digital channels, only analogue. The picture has frozen on the digital mode & will not alter when the remote buttons are pressed?
SOURCE: No Analogue or digital channels!
On the TV remote: 1. press MENU external entry is highlight 2. right press outer circle scroll down to video 4 (satellite entry assignment _ it could be video 3 or another number selected depending of your configuration) 3. right press outer circle if you on TV is settle on an HD channel, on the left corner of your screen you will see 1080i _ hope it will fix your problem. It could be helpful to read your manual. 1431
Posted on May 30, 2007
  • 11 Answers
SOURCE: Digital tuning
You'll need to go into service mode and do a factory reset.
To enter service mode you'll need to press these buttons on your remote in the following order:-
Standby-info-menu-mute-standby.You'll need to do it fairly quickly and be patient it doesn't always go into it first time,don't press and hold the buttons.
The service menu should appear on the screen.Use the up /down cursor to scan down to option number 12 (factory reset)and then press the right cursor wait will appear on the screen and the set will go to standby(don't worry this is normal)
Reboot the set and retune and all should be well
Posted on Nov 04, 2007
  • 4 Answers
SOURCE: Samsung LE26R Digital Frozen
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Posted on Jun 10, 2008
  • 4 Answers
SOURCE: Cannot change channels in digital mode
  • 6 Answers
SOURCE: no digital yet tried to retune but greyed out.
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Posted on Oct 05, 2009
How do I remove the decoder off from the tuner? I can not get audio.
Hi, Not sure what exactly you mean.
Try turning input knob on Receiver or press equipment button like Sat/cable or DVD on remote.
If still no sound look for a button "Input mode" or "6 Channel" eg on receiver and select analogue, digital etc or disable 6 channel mode.
Make sure speaker wires are connected and not short circuit. Also look for speaker button, On some receivers you can disable speakers.or select A & B
If sound was working before you probably just press or disable sound settings on receiver.
Sep 24, 2014 | Yamaha RXV367 5.1-Channel Black Digital...
I have a samsung LE40R73BDX/XEU LCD TV which continually clicks and eventually switches on. The time it takes to function is getting longer. can you help?
the power supply board is going bad. sorry! if you google "samsung power click capacitor" you will see just what is wrong. Next time buy american, wait, there is no american made TV's
Aug 14, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
SAMSUNG LE32R73BDX/XEU TV Digital TV Stuck on bbc1, no access to DTV menu to reset or retune. Sometimes picture is frozen, always it shows BBC banner and Mono. Standby - Info - menu - Mute - Power is not...
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Sep 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
My Phillips SLC4 flat screen TV has suddenly
The problem has cleared itself a day later after being switched on/off a few times.I suspect the 'computer part' of the TV (channel processor, instruction decoder etc) received maybe a power glitch or an illegal infrared instruction (2 remotes used at once for example) and 'locked up' leaving just the analogue side operating.
I was going to continue happily using it with just the analogue side slaved to my Hd recorder for digital signals but it seems to have got over whatever it was that upset it.
Sep 07, 2009 | Philips Televison & Video
Le40r73bdx/xeu samsung tv clicks for about an hour before it comes on
the power supply board is the fault!stop work the tv before ruin the main board!try a good technician to change the 1000mf 10v caps in the secondary smps and check all the others!check for cold soldering joints will be good!
Jun 21, 2009 | Samsung DLP HL-P5663W 56" TV
No digital yet tried to retune but greyed out.
Jun 03, 2009 | Samsung LE32R73BD 32 in. HD-Ready LCD...
WHARFEDALE LCD2610AF WHEN I TURN ON DIGITAL I HAVE PERFECT PICTURE &SOUND.AFTER 10 TO 30 MINUTES THE PICTURE FREEZES AND THEN SCREEN TURNS WHITE WITH AGREEN HORIZONTAL BAND LOWER HALF OF SCREEN.WHEN...
Hi.
If the picture & sound are ok in analogue mode then chances are you have problem with digital tuner.
This may be expensive to repair so I would advise connect external freeview box or sky etc to get digi channels using scart to connect to your TV.
Jul 16, 2008 | Televison & Video
Jan 29, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Samsung LE40R74BDX 40 in. LCD Television Logo
177 people viewed this question
Henry  Thomas
Henry Thomas
