Question about Lexmark X2350 All-In-One InkJet Printer
How to install a new ink cartridge in Lexmark 2350 printer/scanner
  • Official Brand Answer
  • 3,344 Answers
Perhaps the Lexmark X2350 User's Guide will be able to help you. Just click on this link to download: http://bit.ly/bNOTdZ. Scroll to Replacing the print cartridge, Page 52, for the instructions on how to install your new ink cartridge.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source.
Posted on Sep 15, 2010
How do i replace my ink cartages
Removing a used print cartridge:
  1. Make sure the printer is on.
  2. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the lever to raise the cartridge lid.
  4. Remove the used print cartridge.
To install a new cartridge, remove the sticker from the back and bottom of cartridge. Insert the new cartridge in the slot. Close the lid. Lift the scanner unit, press the scanner support back until it slides into the slot, and close the scanner unit.
Source: Lexmark X2400 Series User's Guide
May 18, 2011 | Lexmark X2470 All-In-One InkJet Printer
I refilled my Lexmark cartridge but it continues to say I need to install a new cartridge. The printer model is x2670.
Hello there,
The reason why your Lexmark printer keeps on telling you to install new cartridge because the printer have ink cartridge detection. Meaning it will detect whether that particular cartridge is an old one or not.
Each Ink Cartridges have its code and it will be registered to the printer once you have connected it. The printer will assume the ink level and once it is empty, that particular Lexmark Ink Cartridge will be registered to your printer as an empty ink cartridge and needed to be replace with a new one.
I would suggest getting a genuine new cartridge instead of refilling the ink cartridges.
Feb 17, 2011 | Lexmark X2670 All-In-One Printer
How to replace the ink cartridge
1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
4. Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
Nov 26, 2010 | Lexmark X1240 All-In-One InkJet Printer
How to install ink
Here's a link to the Lexmark website to guide you on how to install/replace the cartridges on your Lexmark printer. http://bit.ly/cevMS4. The printer shown may not look exactly like your printer, however, the steps are the same. But, there are cases that the cartridge carrier doesn't move to the center when you lift the scanner unit. If that happens, unplug the printer from the power source. With the scanner unit lifted, hold the solid white tape you see inside the printer. The other end is connected to the ink cartridge carrier. Slowly drag the carrier to the center to remove the cartridges and install the new ones. Close the covers. Close the scanner unit. Plug printer back to power source. Let it print the alignment page to align the cartridges. Hope this helps.
Apr 27, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
Lost my manual, need to change the ink cartridge, help
  3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
  4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
  5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
Apr 24, 2010 | Lexmark C533DN InkJet Printer
Lexmark 6170 Cartridge Error 50C How to resolve?
"Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Apr 17, 2010 | Lexmark X6170 All-In-One InkJet Printer
Where is the ink cartridge on the lexmark x2350
open the cover while power is on. the cartridges will slide to the middle where you can reach them
Jul 13, 2009 | Lexmark X2350 All-In-One InkJet Printer
Lexmark X2600 refill problem
many printer manufacturers put something (a chip?) in the circuit of the cartridge to prevent refilled ones from being recognized by the printer....when the "factory" cartridge is empty, the only way for the printer to see a full cartridge again is by using a "new" factory one, ...i guess it's the big name brands way of making sure you buy "their" ink and not use refulls.
Oct 22, 2008 | Nukote Nu-kote RF196 Black Refill Kit
Lexmark 2350 all in one printer
yeah thats the problem when you do refill the ink most of the time is not compatible so get new one
Oct 28, 2007 | Lexmark X2470 All-In-One InkJet Printer
Lexmark X2350 All-In-One InkJet Printer Logo
268 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
