Question about VillaWare Mickey Mornin' 5555-11 2-Slice Toaster
Toast lever won't stay down - is solenoid to blame?
Repair of model 553 krups toaster over. Lever will not stay down to toast
if there is a open circuit the lever will not stay down. hold the lever down check if the elements glow , most times it costs more to fix then a new one.
May 05, 2018 | Krups Toaster Ovens
Control lever will not stay down
Unless you have power switch on to the toaster, the level will not stay down. Ensure you have main power available!
If the unit is powered, check that the 'toast darkeness' level is set accordingly - it is this 'thermostat' that determines when to eject the toast: if you checked that you have power and that the darkness level is not set to zero and it still does not work, then it is time to get a new toaster! If not under warranty, it is probably not worth trying to get it repaired.
Apr 08, 2014 | Bodum 10709 Toaster
GE toaster model 169100. : the lever to toast won't stay down. I researched removing the base to clean the magnets, but not regular Phillips screws. Suggestions??
I have the same GE toaster and now my lever won\'t lock in place when I push it down to cook my toast. The handle does not pull off and when you turn the toaster over there are no screws to take the toaster apart. So I guess I have to say this is a disposable toaster but I am extremely bummed because it is beautiful and match decor and microwave that has the same color scheme as my toaster.
I wish companies would stop making cheap junk that doesn\'t last more then a few years.
Sep 06, 2013 | GE small appliance toasters 169100 User...
My toast lever wont stay down-I've loosened the cover and cleaned as best I can. How can I take the lever off so that I can fully remove the cover? It is a Cuisinart two slice black toaster.
On most appliances the knob on the lever pulls off and the cover is then lifted off the lever. Check that the bi-metal strip that latches the toast ejector has not been bent or damaged. Once you have the cover you will be able ot see the whole mechanism.
Jan 26, 2011 | Cuisinart Kitchen Appliances - Others
The lever won't stay down
The lever will not stay down. Sometimes the lever will catch and other times it takes 6-8 times befroe it will stay down and toast the bread. Thanks....
Oct 16, 2010 | KitchenAid KTT570 4-Slice Toaster
Lever on toaster will not stay down
For what it might cost to fix it buy a better brand of toaster for about 10% of the cost of this horrible brand.
You'll notice their new ones are "smart" toasters with NO LEVER. You push a button and the electronics takes care of the rest (and blow up quickly.)
$15 to $25 at Walmart.. instead of $100 to $200.
Dec 13, 2017 | Breville Kitchen Appliances - Others
Lever will not stay down on Krups 155 ToastControl Compact
No promises, but I had a similar problem with a Breville Clasic. Toasters these days use a solenoid (electromagnet) to hold down the toast carriage. This solenoid is usually soldered to the circuit board, and is reasonably big, i.e. 1/3 a cigarette pack.. on mine, because of repeated impact when the carriage is pushed down, one solder connection developed a haiirline fracture. This meant that most of the time it wouldn't stay down. I resoldered the connections and all ok.
Oct 02, 2008 | Kitchen Appliances - Others
When i push the lever down to make toast, it does not stay
This is a problem, our old toaster had this problem, and it would only work if we jammed the handle down, but don't try this, only because ours broke after we tried this, but if you can send it to the manufacturure, they should be able to fix this. If you don't what to do this, please phone me at 505 9181, but please call me from 8:00-10:00, 2:30-8:00.
Oct 21, 2007 | Cuisinart CPT-60 Custom Control Total...
Toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Oct 11, 2007 | Waring WCT708 4-Slice Toaster
VillaWare Mickey Mornin' 5555-11 2-Slice Toaster Logo
65 people viewed this question
Top VillaWare Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
Angel Joseph Jr.
Angel Joseph Jr.
Stan Ford
Are you a VillaWare Kitchen Appliances - Other Expert? Answer questions, earn points and help others
