Question about HP OfficeJet 6110 All-In-One InkJet Printer
When you lift up the top including the part with all the buttons, not just the scanner cover, you'll see the door which covers the cartridges. The manual can be downloaded in Adobe Reader format from http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
The instructions for changing the ink cartridges complete with pictures are on page 48.
Posted on Sep 15, 2010
SOURCE: hp officejet 6110 all-in-one won't print despite new cartridges
make sure that the housing that holds the cartridges are clean at the contacts, this can be done with the machine turned off and unplugged, clean the contacts with warm water and a damp cotton bud not wet and then dry it with a paper towel.
make sure everything is dry before turning the printer back on, if this doesnt work then it needs a service.
Posted on Nov 28, 2008
SOURCE: where is the ink cartridge located on the HP office jet 6110 prin
if you are to lift the top part of your printer you will see the cartridges inside as shown below:
Lifting the scanner bed exposes the entire paper path and gives your hands plenty of space to replace ink or clear paper jams.
Posted on Apr 11, 2009
SOURCE: Replaced ink cartridge 56 and black print text is
Remove the cartridge and use a damp paper towel, wipe the bottom of the cartridge several times. Each time you wipe you should be getting black streaks on the paper towel. After manually cleaning the cartridge nozzles you will need to use a new tower and wipe the contacts on the back of the cartridge. When this is done reinstall it and run a cleaning and then an alignment procedure from the printer software. You should be printing good again.
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on Apr 13, 2010
SOURCE: I have a HP 6110 officjet printer. I installed a
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa00299&cc=us&lc=en&dlc=en&product=79477
Try with new ink cartrige and check the cartridge.
Posted on Aug 08, 2010
Jan 17, 2015 | HP OfficeJet 6110 All-In-One InkJet...
Mar 18, 2012 | HP OfficeJet 6110 All-In-One InkJet...
Jul 25, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Mar 28, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Nov 06, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Aug 25, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Apr 11, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Sep 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Mar 20, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Mar 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
73 people viewed this question
