posted by driller170 on May 16, 2008
jumped time do i need anything oter than timeing belt to repair it
Solution #1
posted on Jun 27, 2008
IF YOUR TIMING BELT BROKE OFF BEFORE YOU CHANGED THE TIMING BELT DO YOU HAVE TO TAKE THE COVER OFF OF THE HEAD VALVE LOOK AT THE CAMS AND YOU WILL SEE THAT THE VALVES ARE BENT IF THE CAM IS NOT TOUCHING THE VALVES ARE BENT BEFORE YOU ALINE THE CAM GEARS YOU HAVE TO PUT THE CRANK SHAFT GEAR IT HAS A MARK AT THE BOTTOM OF THE OIL PEN MAKE SURE THAT WHEN YOU GET IT ALL SET UP RETURN THE GEAR TO THE MARK ON PULLY ALSO THE TIMING MARKS ON THE CAMS HAS TO MARKS ON THE COVER THE LEFT CAM GOES AT 12:00 THE RIGHT CAM MAKE SURE THE EXHAUST LINE LINES UP AT 12:00 OTHERWISE IT WONT START BECAUSE YOU DONT HAVE NO COMPRESSION I HOPE THIS IS HELPFUL FOR ANYBODY THAT NEEDS TO REPAIR THE ENGINE
ALCANTARAMONICO@YAHOO.COM
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 30, 2008
if your car doesnt start after changing the timing belt and you're sure everything has been placed right, you will have to change the valves they tend to get bent when the timing belt snaps .
your best bet is ebay because nobody sells these parts for daewoo
Suggest a new solution for this problem
Post a New problem for 2000 Daewoo Leganza
Email this problem
Email this problem
Can you Help with these Cars problems?
Repair Service
Find Car Repairman Near You:
