Question about Refrigerators
VERY LOUD KNOCKING NOISE THAT GOES AWAY AND THEN COMES BACK SEVERAL MINUTES LATER-SOUNDS LIKE A FAN HITTING AGAINST SOMETHING-VERY VERY LOUD!!!!
    Problem Solver:
  • 10 Answers
Defrost the fridge for 24 hrs. If this works it was an ice build up.
Posted on Sep 15, 2010
Loud Noise in Central Dash area, 2000, F-150,,Sounds like a fan hitting against a heavy plastic part.Starts around 45MPH.. I think its either air flow or speed causing it.
Have you checked to see if the heater motor is ok. Sometimes the newer ones have a bearing in the end by the plastic fan and the bearing will allow the fan to drop down and cause a loud noise when running. To check turn off the heater motor fan on the dash and see if the noise goes away.
Apr 18, 2017 | Ford F-150 Cars & Trucks
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
Fan makes a loud noise i tap on the top then it goes away . Or if I blow in to the vents it goes away then comes back later? let me know
Sounds like filter is clogged or dirty. Take a vac cleaner to the vents. If that doesn't cure it, then disassemble and clean thoroughly.
Jan 07, 2011 | Optoma HD20 DLP Projector
My frigerator is making a very loud noise coming from the ice maker area. It sound like a airplaine engine getting ready to take off. Sometimes it gets louder and louder. If I turn the switch to off then...
the noise is the evap fan hitting . now either its comming off the motor shaft or its hitting ice build up caused by incomplete defrost . It's time to call the repair man . as the noise will quit and the cold will too . mm
Jul 06, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Kitchenaid refrigerator / freezer knocking noise
Hmmm. Makes sure it is not the fan inside the freezer. The compressor is not capable of loud noise since it is sealed and sits on rubber mount. The knocking might be due to the fan blade hitting ice build up. You should not see any frost in a freezer. If there is frost, you can defrost completely then set the fridge to a lower setting.
Feb 11, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Knocking sound from wheel well
it sounds like you have a bad cv axle on the drivers side.
May 14, 2009 | 2006 Chevrolet Impala
Knocking Noise
you have a rod going out on the car
Feb 05, 2009 | 1996 Dodge Caravan
Fan making loud noise like its hitting against something
take and defrost the unit and make sure that the drain line is clear. this should solve it. Thanks for using FixYa.
Dec 25, 2008 | Freezers
Samsung HLN5065W, SVC#HLN5056WX/XAA - Made 12/2003
check the color wheel in front of the lamp
May 25, 2008 | LG 42LC7D-UB Television
Refrigerators Logo
164 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
