Question about Zanussi ZWF10070W Front Load Washer
Installation question: We have just received delivery of a new washing machine - ZWG1120M. The instructions told me to remove the four transit bolts from the back of the machine, which I did, including the washer. There are now black rubber plugs with white hard plastic inside still in place. I am not clear whether to remove these as well. If I don't remove them, I can't manage to fit the 'plastic plug caps' that the instructions tell me to use to fill the holes left by the transit bolt removal. The black rubber plugs are very tight - do I yank hard to get them out or are they supposed to remain? thanks!
    Sergeant:
  • 215 Answers
Normally you should remove these parts also, they often drop inside the machine. this will not harm the machine.
Posted on Sep 15, 2010
What does error code F7 E1 mean on a whirlpool VMW washing machine
This code indicates a motor speed sensing error, the motor can not achieve the correct speed for the cycle selection.
Have the shipping bolts been removed?
This error code indicates that the motor is having difficulty turning.
All four (4) shipping bolts and the plastic spacers must be removed from the rear of the washer before you operate it. Each unit is shipped from the factory with four bolts, which are designed to secure the washer during shipping. Failure to remove all of the shipping bolts, and the four plastic spacers that are with them, can result in noise, vibration or error codes. See your Installation Instructions for details on how to remove the shipping bolts.
Dec 27, 2016 | Whirlpool Washing Machines
Why is my new Bosch Varioperfect Washing Machine with EcoSilence is jumping around when the spin cycle is active
Sounds like you have not removed the transit bolts. Read the installation section of your instruction manual
Aug 25, 2016 | Bosch Washing Machines
Vibrates real hard during spin cycle,tub moves real far from side to side
Is it new? Did you remove the stabilisation bar from inside the top after it was delivered? This is to protect the drum during transit and delivery. Sometimes there is a second removable bracket on the motor as well. Refer to the instruction book.
If it is older and was working fine. There are two possibilities.
1. the machine is not level and sitting FIRMLY on all FOUR feet.
2. The machine is unevenly loaded with laundry. One item perhaps, or say 2 bath towels, which are sticking to just one side of the drum.
Oct 04, 2015 | Kenmore Washing Machines
Day old washer bangs and is extremely loud. How do I balance it?
Hi karaloye, Did you remove the Transit bolts? An easy mistake by most people who purchase a new washing machine. The Drum is held together with 2 to 4 bolts for transporting reasons, and most people forget to take them out. Please consult your manual you received with the machine. Kind Regards JEDEMEYER1 * If this solution helped you, please rate it
Aug 18, 2011 | Washing Machines
I left the transit bolts in our "brand new" zanussi washing machine and am afraid to use it as I do not know what damage might have been done.
Highly unlikely any damage will have been done so long as it hasnt been in use for a long time (weeks).
In a front loading washing machine, most of the mechanicals inside are held between springs at the top and dampers at the bottom. The transit bolts are used to minimse how much movement can ocour whilst the machine is in transit as excessive movement could damage the springs/dampers. When they are removed, normal movement of the mechanicals helps keep the machine stable and minmises vibration.
So, the worst that happens when the machine is used with the transit bolts in place is it vibrates alot, and possible moves about.
Remove the bolts as soon as possible and it should be fine.
Oct 04, 2009 | Zanussi ZWF12070 Front Load Washer
Forgot to remove shippping bolts before using machine.
I would take out the shipping bolts and then run a prgram such as Spin.with no clothes in
If that sounds ok, wet a few towels and spin them dry
If that works put a full load in and go for it
Unless your machine was way out of balance you should not really have damaged anything.
The transit bolts are there to stop the drum from banging around during transit and unless they have torn free or have bent you should be ok
Jul 11, 2009 | Amana Washing Machines
AEG OKO LAVAMAT - BROKEN BOLT - WHAT DOES IT DO?
The bolt you described is indeed a transit bolt and should be removed. I believe that the current UK agents for aeg are service force. Check their website for your nearest branch.
Hope this helps & thanks for using Fixya
Dec 23, 2008 | Washing Machines
Hotpoint washing machine vibrate/oscillates violently when on spin mode. Installation instructions tell you to adjust the feet, which I have done. I have also tried different sizes of load - no difference...
have you removed the transit bolts? this is the usual cause of violent vibration. if not, do not use the machine till this is done as you can cause a lot of damage
Sep 03, 2008 | Washing Machines
Transit brackets
Hiya .. the transit bolts are located under the lid at either side ..or at the rear... they are fairly long bolts which hold the drum and balance in place.. until installation. they will be sheathed in fairly hefty rubber grommets.
Screws for removal of lid located at the rear..2- or 4.. remove these slide lid front to back.. remove bolts if they are they are present... refit lid... note uneven siting of an appliance can cause excessive vibration as well!
Let me know if this sorts your prob
Regards Faggly
Mar 20, 2008 | Washing Machines
New Bosch Front loader washer Maxx Classic WAE18060AU
Remove the 4 transit bolts from the back of the washing machine. These are supposed to be remove during installation. If they are not removed the machine jumps around like crazy on the spin cycle and the machine is almost unusable.
Jan 12, 2008 | Bosch Classixx WFO 2466 Front Load Washer
Zanussi ZWF10070W Front Load Washer Logo
476 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
