Question about Vanguard International Vanguard 82V66-2T Electric Water Heater
I need to find out the year of manufacture of my Vanguard electric hot water heater. Model #6E717 Serial # VG1296C06976 Can you refer me to a website where I can find out the age of this hot water heater? Thanks. Evelyn Haught evelynlhaught@yahoo.com
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
Need to find heater elements for a vanguard water heater model 6e746a
Hello abcd. Vanguard appears to be manufactured by Rjheem
Rheem promotes that their products require specialized 'resistorized' elements or 'all copper' elements to portion larger brand-specific sales in their pocket and for no other reason.
1) Buy 3600 watt element. Nothing special needed:
Copy following link to identify type of element:
http://waterheatertimer.org/How-to-replace-water-heater-element.html
2) March 2013: Add a comment and describe the water heater and the element.
Mar 12, 2013 | Vanguard International Water Heaters
I have a Rheem PG50T9A hot water heater that is leaking. It seems to be spraying water from the vent tube in the heater. I shut the gas and water off and am now dealing with the damage done to my kitchen...
Tank rusted out because anode rod depleted because water heater was not maintained according to product manual, and industry standard and water heater was not inspected each 6 months by homeowner.
http://waterheatertimer.org/How-to-maintain-water-heater.html
Rheem makes GE heaters.
Look at label for serial number. 3rd and 4th digit are year of manufacture.
Since this model is no longer manufactured, I suspect that 6-year warranty is expired. So ruptured tank is not covered.
Call homeowner's insurance for deductible coverage for ruptured water damage.
Buy new heater.
http://waterheatertimer.org/pdf/Which-is-best-gas-water-heater.pdf
Install gas water heater yourself:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Oct 25, 2012 | Rheem 50 Gallon FVR NATGAS Water Heater...
I own a house with an electric GE hot water heater. 8ESOT12AA01 Serial # 090122 5750 I do not know how old the hot water heater is and advice about when it should be replaced. No leaks to date but I...
GE is made by Rheem, but the market is always changing. Rheem-based serial number shows tank was made in 1990.
Tank will last as long as anode rod(s) protects steel tank from rusting.
If your tank has two anode rods, then tanks lasts longer.
That's how companies determine if water heater is '6-year' or '12-year.'
I don't have manual for your product to say if you have 12 year tank. Side of tank might have information blurb besides mandatory label that shows serial number.
You can update your water heater by replacing anode rod(s) assuming they can be loosened and removed after this number of years, which is a big IF with old heaters. Your plumber might have impact wrench he uses to see if anode can come out.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/Leaking-water-heater.html
If the water heater is making gurgling rumbling and/or crackling sounds then tank has sediment build-up.
You can also get a baseline of rust by flushing tank and watching if water is very rusty.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/Water-heater-will-not-drain.html
If you flush tank regularly, and inspect anode every 1-3 years, a tank will last many years longer than manufacturer's label.
http://waterheatertimer.org/Water-heater-manufacturers.html
Apr 20, 2011 | General Electric Water Heaters
I have. A vanguard. Energy efficient water heater in a mobil kitchen I don't. Get any hot water
If your electric hot water heater is not working...check out this tip about electric hot water heater problems
Electric Water Heater not Working
heatman101
Aug 27, 2010 | Vanguard International Vanguard 82V66-2T...
Old Vanguard Water heater not heating.
the top element is energized until the water in the top of the tank is hot enough to satisfy the upper thermostat, then the thermostat switches and sends power to the lower element. This is done to quicken the recovery time.
Mar 05, 2010 | Water Heaters
No hot water. hitting reset button starts it up but keeps tripping breaker
-Did you buy it directly from Grainger? The model # is actually 82SV30-2T. The "model #" you provided is Grainger's product code.
-Is this a new installation or is this an older water heater?
-Is this wired to a 25 amp breaker. (It should be.)
-Did you re-use existing wire? If so, is it at least #10 copper? (It has to be #10 or larger to comply with code) It isn't copper-clad aluminum or cotton over rubber insulated, right? (It should not be)
-Have you re-wired the heating elements? If so, you need to restore the wiring to the way it was configured from the factory.
Let me know if you need further assistance.
V/R
May 24, 2009 | Vanguard International Vanguard 82V66-2T...
Vanguard International Vanguard 82V66-2T Electric Water Heater Logo
239 people viewed this question
Top Vanguard International Water Heaters Experts
David Jewell
Donni Steen
Gene Haynes
Are you a Vanguard International Water Heater Expert? Answer questions, earn points and help others
