Question about Plumbing
I have a Shur-dri SD-106 pump. I am looking for a source to purchase replacement impellers. Please advise
Call 888-987-8677 this a division of pentair they make shur-dri pumps
Posted on Jan 10, 2011
I have a Shur-Dri 1 HP above ground pump, Model No. SD-100-01. The propeller is cracked and needs to be replaced. I cannot find anyone who sells just the propeller. They say I have to get a new pump. ...
There is a possibility that this model is not supported any longer. What you are needing is an IMPELLOR. The company that makes sure dry has a lot of information here: http://www.pumpproducts.com/myers-m-39.html
Jan 23, 2015 | Pool & Spa
My shur-dri model sd-100-01 well pump will run for a while and then shut off but will restart after an hour or so. What's wrong?
It is a heat sink in the motor. Most all electric motors come with it. Once it cools down, they work again. The heat sink keeps them from burning up.
Oct 26, 2014 | Cars & Trucks
Where can Iget impeller #16622B010 for a shur dri water pump
I can only help on a Honda 50hp 2003. Any Honda center or parts center. That's all I know. JMC
Jun 09, 2014 | Honda Water Pump Impeller Outboard 35, 40,...
Shur dri sdss5
Replace it! It will only get worse and destroy the shaft. If you replace the seal be sure to clean and polish the shaft, it should not be pitted, if so you need to replace it as well.
Mar 15, 2014 | Plumbing
Shur-dri sdts10-01 water leaking from shaft around impeller housing
Mine is too. But I have not had any useful replies to my simple question about "where is the level sensor".
SoI agree FIXYA looks a complete scam!!!
Dec 13, 2012 | Dishwashers
My impeller was clogged and my pump was only humming. so i cleaned the impeller put it back together but it still only hum s its a baqua pure 2 hp pump. any advise
Check to see if the motor spins freely or appears to be dragging or stuck. If it does not spin freely, then you need to overhaul the pump and replace bearings and shaft seal or locate the source of the dragging in the pump housing
Apr 04, 2010 | Pool & Spa
My Shur-Dri Backup Sump Pump does not activate with a power outage.
I presume your pump is having a separate power supply.
It is to operate if and when there is power outage. Am
I right? Check your Shur-Dri backup pump. Plug it to
another power source, and switch it on. If it runs, then
the problem could be power supply. Have this checked
using voltage tester (multitester set at 300 volts) or you
may use an electric bulb.
Dec 03, 2009 | Plumbing
Where can I find a replacement impeller for a Shur-Dri SD-106 pump?
Connect to the internet and type;
http//www.merchantcircle.com/business/Shur.Dri 419-289 1144.
This is where you can find your ShurDri Pump parts.
Oct 25, 2009 | Plumbing
Not draining water!
Some hard object may have damaged the pump impellers. Take the hose off the pump and use a flashlight to look into the suction port on the pump. Look for anything clogging the pump and check the pump impeller for broken/missing blades and make sure that the impeller spins freely. If any blades are missing/broken or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it is just something clogging the pump. Also check the drain line for clogs while it is off the pump. Hope this helped and best wishes.
Aug 17, 2009 | LG WD-16115FD Front Load Washer
Displayed Sd message and won't drain
Look for something clogging the pump, the drain, or a defective pump. Look into the suction port of the pump with a flashlight. Check out the blades on the pump impeller. If any of the blades are broken or missing, or if the pump impeller won't turn freely, the pump must be replaced. Hopefully, there is just something clogging the pump or the drain that is causing the problem. Hope this helped and best wishes.
Jul 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
Plumbing Logo
1,154 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
