Question about Maytag PYE2300AY Electric Dryer
Need electrical drawing - Maytag PYE2300AY Electric Dryer
  • Maytag Master
  • 3,287 Answers
Maytag usually includes a schematic with all of their machines. Many times, it may be found folded up in a small plastic bag taped to the frame, inside the top or side panel or inside the control panel.
This will be your best best as it is for your particular model - and many found on the internet have either been reduced for scanning and don't scale well or are not the exact same model number. Look around your machine for it - and keep it in a safe spot for later.
Make sure you unplug the machine before disassembling.
Posted on Sep 15, 2010
2005 lt got a parasitic draw of 1.02 ma pulled all fuses still shows up. is there anywhere else i could look mebay relay's ?
a 1.02ma draw is nothing, and is the sort of draw your clock and the flashing light would draw.
In that same conversation, it was suggested that a 200-milliamp draw was "acceptable." That is certainly not the case. In fact, we suggest a 25-milliamp draw is normal and anything that exceeds 100-milliamps indicates an electrical issue that needs to be addressed. Although I have checked the parasitic draw on my Excursion in the past, I'd never photographed that test. I did just that today and it indicated a draw of about 60-milliamps. That's not too bad, considering I have some of the newer electrical accessories, like memory seats, mirrors and radio presets.
Diagnostic ideas in the link.
parasitic draw of 1 02 ma Google Search
Dec 14, 2016 | Cars & Trucks
125 electrical drawings
Here's the link and I'm sure you will get the solution of your problem.
John Deere 102 115 125 135 145 155C 190C Lawn Garden Tractor Technical...
Sep 14, 2016 | John Deere Garden
Amp draw on #SMA-64140A
At which voltage?
If you have 120V to it, 4,000 watts is 4000 / 120 = 33.333A.
If you have 240V, 4,000 watts is 4000 / 240 = 16.667A.
Dec 11, 2013 | King Electric Heater. 4,000-Watt Fan...
When heater works electric line trip off
You're drawing more amps than your line is equipped for. Rather than modifying your electric, unplug something on the same line to reduce the current draw.
Dec 18, 2012 | Sunbeam SCH2101UM Ceramic Electric Heater
I have a sakura electric bike and when I use the throttle the battery charge indicator drops to empty and it cuts out, however when I stop the charge indicator rises again. Any suggestions.
Sounds like your batteries are low in capacity and need replacing. The battery indicator is measuring voltage. As you draw power from the battery the voltage is dropping (sagging) because the batteries are weak/old. When you stop drawing power the voltage rises again.
Aug 12, 2012 | Electric Bicycle Motor, Bike,electric...
I would like to know the electrical requirements.( voltage and amperage) Does it plug in or is it hard wired? If the power goes out is the hot water also out? thankyou
Are you asking about tankless gas or tankless electric?
You posted under Tankless gas water heater: gas type tankless plugs into standard 120Volt household outlet to power circuit board. You need larger gas line than used for tank-type gas water heater.
If you are asking about volt and amp draw of Tankless electric, then that depends on specific model number.
For example, if each tankless element draws 3500Watts, and unit has 3 elements, you will need 3 additional 20 amp 240Volt circuit breakers. Volts x amps = watts. 3500 watts divided by 240Volts = 14.58 amps. At full blast, this unit would draw 43.75 amps and will cost more to operate yearly than tank-type electric water heater. If unit has 4500 watts elements, then it will draw 56 amps at full blast, and use a good percentage of household power.
Tankless water heaters have no hot water in power outage. This is true for gas and electric models.
Additional resources:
http://waterheatertimer.org/images/Compare-water-heater-parts-650.jpg
http://waterheatertimer.org/pro-n-con.html
http://waterheatertimer.org/pdf/Bradford-White-on-demand-tankless-service-manual.pdf
Aug 04, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
Heating element drawing lots of power, big bill power
Well a dryer heating element does draw quite a bit of amps(that is why it is 220) but it cycles on and off & it is not an appliance that is used everyday. The first think I would do is read the electric meter and verify that it was not misread before condeming the dryer. If the electric meter reads are correct then it is possible it could be the dryer heating element shorting. How much do you actually use the dryer? Is the heating in your house electric and have you been using it? You could also have your electric company test the meter. Look at your usage of electricity for last year at the same time(it will be on the bill) and see what the number was.
Oct 22, 2009 | Maytag Neptune MDE4000 Electric Dryer
I have a battery draw problem in my 96 eagle talon.It's not the alternator.I've got it narrowed down to 2 fuse's the ignition and engine fuse. when I pull both fuse's I loose the draw. one or the other I...
If you still get current drawing when car is turned off, you will have to start pulling electrical connectors and checking for draw. If no change, connect, and go to next connector, repeating until the draw stops, this is the bad component.
I would start with any aftermarket electrical components. Alarm's, radio's, etc. Then I would disconnect and check for draw on any component that get's power when car is off. Horn, light's, brake light switch (usually located towards top of brake pedal), radio, cigarette lighter, etc...Disconnect each component separately and check for current draw.
May 18, 2009 | 1996 Eagle Talon
Maytag PYE2300AY Electric Dryer Logo
62 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
