Question about Vacuums
How do we change a belt on a euro pre shark no bag vacuum
  • Vacuums Master
  • 17,970 Answers
Try this procedure for Euro-Pro Shark...
A.- Instructions
1. Lower handle of vacuum and flip over so that it lies flat on floor upside down.
2. Twist 3 plastic securing latches with large flathead screwdriver or a coin.
3. Remove black plastic roller brush assembly cover.
At this point, you should see the motor shaft it wraps around (it's metal and as big around as a pencil, buried fairly deep in the now exposed well, you'll also see two white plastic wheels that are part of the roller brush. One is an "idle" wheel that spins freely, and the other wheel is part of the roller brush and turning it turns the roller brush.
4. Remove the roller brush assembly by pulling upward on it. You may need to "walk" the brush assembly out one end at a time a little bit at a time.
5. Loop the new belt over the two wheels of the roller brush assembly and replace it back into the vacuum.
6. If you can manage it, stretch the belt over the end of the motor shaft, making sure the belt is running between the two prongs of the belt guide operating by the carpet/bare floors switch.
B.- If successful, perform steps 1-5 in reverse order to reassemble the vacuum. If you cannot stretch it over the motor shaft, you'll have to continue with step 7 to get a better grip and angle on the belt.
C.- Then, continue...
7. Remove two screws next to rear wheels nested deep in screw socket holes.
8. Remove 2 screws at front of corners of vacuum previously hidden by roller brush assembly cover.
9. Remove 2 screws sunk in hole sockets next to flat holes that accommodate the coin screw latches.
10. Remove 1 short screw from slightly behind roller brush in center of top assembly. (It is easily visible and you need not remove the brush assembly again to get it out with a screwdriver.)
11. Remove the 2 screws holding down the metal brackets (1 screw per bracket) that hold down the carpet adjustment wheel assembly.
12. Remove the brackets and the carpet adjustment wheel assembly.
13. Remove carpet height adjustment lever by removing the single screw buried deep in the center of the plastic height adjustment cylinder. (a hollow cylinder with ratcheted teeth spiral gently down into the well.)
14. Turn Vacuum right side up.
15. Remove blue/green top assembly that fits over the start button and "Full" light indicator.
16, Making sure belt is still looped over white plastic wheels of roller brush assembly, pull belt onto motor shaft.
17. Replace top assembly, it snaps into place.
18. Turn vacuum upside down and flat on floor.
19. Make sure belt is running between prongs of guide operated by carpet / bare floors switch.
Perform steps 1-13 in reverse order to reassemble vacuum.
Hope this helps.
Posted on Sep 15, 2010
How do you change a belt on the shark Euro Pro Roadster model
https://www.hunker.com/12172999/how-to-change-the-belt-on-a-shark-vacuum-cleaner
Above, Click an x to get rid of the ad to see the info.
https://www.youtube.com/watch?v=Jr5xSpomTYc
And here is the manual:
https://www.manualslib.com/manual/783661/Shark-Uv208.html
Jun 14, 2017 | Shark Vacuums
Tip
Also you can check out GoVacuum.com's wide selection of Euro-Pro shark...
There seems to be many people that are looking for parts and accessories for their Shark products. Shark does have a website where they sell parts and accessories for their products.
Whether you are looking for parts for you Steam product, Upright vacuum, Garment care product, or your hand or cordless vacuum, you can find any of the available parts here.
Go to http://www.sharkclean.com
Then at the top right under the search box, hover over the parts and accessories tab.
A drop down menu will appear and you can choose which product you want to see the parts for.
Click on that product and you will then see separate boxes for parts and accessories for all of the products in that category.
Click on the product you have and then you will see a list of parts or a list of accessories available for that product.
There are many parts available for their products, but I would not say that they have available every part that could possibly break.
There no parts that pertain to the heating function, so if your product stops making steam for instance, there are no parts that can help you fix that.
Broken handles are fixable and are there. Replacement heads and replacement head coverings are there as would be expected.
If you are in need of parts to fix a product that is not heating, I would suggest looking for used products on Ebay or something like that. Also advertising for a used product may also get you the parts you need...unless of course they are selling it because of the same problem that you had...make sure to check that out first.
heatman101
Also checkout these other related tips...
http://www.fixya.com/support/r5859780-euro_pro_shark_steam_mop_problem
http://www.fixya.com/support/r6740629-shark_steam_pocket_mop_cleaning_problems
on Jan 08, 2011 | Vacuums
Parts for ep703c
Find them here at Canadian Tire
http://www.canadiantire.ca/en/pdp/shark-plus-replacement-vacuum-bags-0436372p.html
Nov 05, 2013 | Euro-Pro Shark EP703C Vacuum Cleaner Bags...
Need bags for the euro pro x ep 238
Needed bags for this vacuum and FINALLY found them at http://www.totalvac.com/parts/X10-3005.html?zmam=6843742&zmas=1&zmac=6&zmap=X10-3005. Ten bags and two filters for $10.95 plus shipping. Hope this does it for you and anyone needing bags for this vacuum..
Aug 06, 2012 | Euro-Pro HEPA Shark EP238 Bagged Canister...
Shark model uv208 upright, How to I change the belt? Thanks
How do I replace a Shark Euro-Pro NV208 vacuum cleaner belt?
Nov 15, 2010 | Euro-Pro UV209 Upright Vacuum
How to change a belt on a shark v15z vac. tks john t
John -
Your vacuum doesn't have a belt - only vacuums with rotating brushes use drive belts.
What problem are you having - why do you think you need to change the belt?
Please rate my solution if you find it helpful.
Oct 14, 2010 | Euro-Pro HEPA Shark EP035 Bagless Handheld...
I need a belt. Where do I get one for a EURO-PRO Shark vacuum Model # UV210CN. Belt # YMH 29438-49/06
Here is the toll free customer service number for your Euro-pro shark vacuum.
800-798-7398
Sep 09, 2009 | Vacuums
Changing A Belt on Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=656349
Generic problem for all Vacuums
Changing a Belt on Vacuum
Posted by cnjk on Jun 08, 2008
Can you give me directions on changing a shark Euro-Pro UV219CS vacuum belt?
Thank you.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Shark vacuum cleaner belt is a side driven belt and you need to remove the bottom plate and remove the belt and place the new belt on the pulley side of the brushroll and make sure the ends are the same, insert the brushroll and then use a belt puller or screwdriver with a bend on the end and then stretch the belt onto the motor pulley and the track it in a straight line, replace the bottom plate. If you need further assistance please fee free to contact your local vacuum cleaner dealer in your area. So feel free to contact your local vacuum cleaner dealer with questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sharkvac.com/ Customer Tech Support 1-800-798-7398
These are the other brands that use the same tech support line
Shark / Euro-Pro / Infinity / Bravetti / and Fantom
http://www.fantom.com/ Customer Tech Support 1-800-798-7398
Hours are Monday thru Saturday from 9:00 AM to 6:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 08, 2008 | Vacuums
Euro-Pro head cranky
The air driven head is probably bond up and needs to be cleaned. Alot of the air driven ones have a belt that may be broken or stretched.
Jan 10, 2008 | Euro-Pro HEPA Shark EP238 Bagged Canister...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
