Question about Dishwashers
I have a mh65m2 moyer diebel dishwasher at the resturant and some days it works great and other days it doesnt but here in the past two weeks it hasnt been going threw all the cycles one day it stays in the rinse cycle and other days it stay in the soap cycle is there anything i could do to restart the machine or fix it because it is really starting to cause the restuarant trouble? please help me if you can.
jonniewalker
  • 1031 Answers
SOURCE: Dishwasher does not clean dishes, soap does not fully go away
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
  • filter
  • . Detergent or Detergent Cup
    It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
    Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, My dishwasher detergent cup won't open.
    Cycle Selector Switch
    Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
    Posted on Mar 29, 2009
    SOURCE: Bosch SHU5300
    If your heat cycle is not coming on, which it sounds like it is not, then you may have a problem with the heating system. There is a well known issue with many of the Bosch dishwashers that use the (266746) control module. Basically, there is a relay (which is a kind of electro-mechanical switch) that is used to turn on the built-in heater. There is a solder joint on the main Printer Circuit Board (PCB) that allow electricity to flow to the heater, that joint often will melt away and burn the surrounding area of the PCB. This is most likely a design flaw and appears to occur at about the 4-5 year mark. One way you can test for this is to run the onboard diagnostics routine that is programmed into the firmware of the micro-controller (brain) of the dishwasher. The way to do so it to press and hold the (Scrub Wash & Delicate/Econo) buttons at he same time and then press the on/off power switch to the on position. The LED lights above both those buttons should begin to flash, when they do, press them both again and the diagnostics program will start. It is a multi-phase program that will run for quite a while. Once it finishes, if it is a heating problem, it will end with a number 2 code in the display. If this is so, then it very well maybe the solder-joint issue on the control module and it will need to be replaced. It runs $128.10 US directly from www.bosch-appliances.com. Good luck.
    Posted on Jun 30, 2009
    • 86 Answers
    SOURCE: Need operating instructions
    Hello Bob
    You can phone Moyer Diebel and talk to Manfled in the service Dept and request a copy their phone # in Canada 1- 800 263 - 5798 if you need further assisstance please email me at dickson@lau.com and I'll email you a copy or else.
    God Bless and have a nice day.
    Dickson
    Posted on Jul 02, 2009
    • 86 Answers
    SOURCE: moyer diebel 500ht manual
    Hello there
    Are you ok now , or still looking for the manual if you are then send me a message to my email address and I'll tell you how to get an manual for you machine. if not I'll send you one , God Bless have a nice day Dickson
    • 86 Answers
    SOURCE: Moyer Diebel Dishwasher arms are not spinning and doing lousy
    Hello there
    First to check is the water level is it just cover the round filter and no more, or is it much lower from the filter. It seem you have not enough water in the tank to do the washing that is why you have a lousy washing job, not enough water to spray upwards don;t talk about the top spray arm , the water doesn't reach there at all.
    You can check it out by manually fill the machine with water up to the filter and start the machine up when the machine is running open the door and you can see the water spray up to the top be careful the water will spray out to your face too.
    This is only to check to see the motor is running normally.
    If the water level is good ( that is just touch the filter) and the problem still there, then the other cause the problem will be inside the pump motor the part call the impeller may need changing.
    Do you have the manual book so I can show you which part we're talking about and let me know where your district so I can tell you where to get the parts from . My email address is dickson@lau.com God Bless Have a nice day, Dickson
    Moyer diebel 401 ht not reaching temperature ????
    could be a number of problems. Checking with an ohm meter would determine the problem. Could be the booster high limit thermostat, a burnt wire, booster thermostat, or a heater element.
    Oct 11, 2009 | Moyer Diebel 401HT Dishwasher
    Hello Bob
    Dickson
    Apr 13, 2009 | Moyer Diebel 26 in. MDM-1000 Free-Standing...
    Need parts manual for a Moyer Diebel MH65-70
    In USA try 1-800-858-4477 In Canada dial 1 - 800-263-5798 and they will send you a copy of your machine. Dickson
    Mar 17, 2009 | Moyer Diebel 28 in. MH65-70 Free-standing...
    Moyer diebel 500ht manual
    Hello there
    Jul 16, 2008 | Moyer Diebel 24 in. 501HT Built-in...
    Moyer diebel - manual
    In USA try 1-800-858-4477 In Canada dial 1-800-263-5798. God Bless Dickson
    Oct 16, 2007 | Moyer Diebel 48 in. SW400 Dishwasher
    Dishwashers Logo
    56 people viewed this question
    Top Dishwashers Experts
