Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Can i use th5320u1001 on 2 stage compressor and 1 stage heat? tom roll , abe service company , bowling green,ky
  • Honeywell Master
  • 43,501 Answers
Yes, that t-stat has that capability...
http://www.pexsupply.com/Honeywell-TH5320U1001-The-FocusPRO-Non-Programmable-Digital-Thermostat-Premier-White-4956000-p
If you need the manual to get it set up then check out this tip...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Posted on Sep 15, 2010
I'm trying to make egg rolls but I'm not sure what to put in them? Please help
Ingredients
  • 1 pound ground pork
  • 1 teaspoon ground ginger
  • 1 teaspoon garlic powder
  • 1 quart peanut oil for frying
  • 2 tablespoons all-purpose flour
  • 2 tablespoons water
  • 2 cups shredded cabbage
  • 2 ounces shredded carrots
  • 8 (7 inch square) egg roll wrappers
  • 2 tablespoons sesame seeds (optional)
Adjust Servings recipe yields 8 servings Directions
  1. Season pork with ginger and garlic powder and mix thoroughly. Heat mixture in a medium skillet, stirring, until pork is cooked through and no longer pink. Set aside.
  2. In another large skillet heat oil to about 375 degrees F (190 degrees C) or medium high heat. While oil is heating, combine flour and water in a bowl until they form a paste. In a separate bowl combine the cabbage, carrots and reserved pork mixture. Mix all together.
  3. Lay out one egg roll skin with a corner pointed toward you. Place about a 1/4 to 1/3 cup of the cabbage, carrot and pork mixture on egg roll paper and fold corner up over the mixture. Fold left and right corners toward the center and continue to roll. Brush a bit of the flour paste on the final corner to help seal the egg roll.
    1. Place egg rolls into heated oil and fry, turning occasionally, until golden brown. Remove from oil and drain on paper towels or rack. Put on serving plate and top with sesame seeds if desired.
Apr 20, 2014 | Cars & Trucks
My thermostat has both auxillary and emergency light on,both are green,what does that mean?
Aux light; This turns on when the auxiliary (second stage) heating is in operation
It turns on 1-6 F below first stage and is user adjustable
Emergency light; This light turns on whenever the emergency heat is manually selected
(Mode switch is in the EMER position)
While in the emergency Heat mode, the heat pump compressor is off,
and the emergency heat (same as the auxiliary heat) maintains the
set point temperature
Jan 22, 2014 | Computers & Internet
I have 7 wires, how do I wire it Red Green White Black Yellow Orange Blue
Conventional heating, air conditioning and heat pump thermostat wiring labels, wire color codes and the corresponding function description: Terminal
Designation
Wire
Color
Function
Description
Rh Red 24 Volt Hot for Heating Rc Red 24 Volt Hot for Cooling Y1 Yellow First Stage Cooling Y2 Blue Second Stage Cooling G Green
Grey * Energizes Indoor Fan W1 White Energizes First Stage Heat W2 Black Energizes Second Stage Heat O Orange Heat Pump
Reversing Valve
Energized In Cooling B Brown Heat Pump
Reversing Valve
Energized In Heating C Brown** 24 Volt Neutral
(Common) leg
Hope this helps
Tom Miller
Broadcast Eng
Sep 07, 2011 | Hunter Fan Company 5/1/1 Programmable...
Need fan for RGH5500 generator. Part # 27003008. It's on a honda gx270. 9.0 hp.
I did a lot of searching and found these DESA suppliers for generator parts. Also, the fan for the MFD Part number 27003002 might be a substitute. See (http://www.masterparts.net/manuals/105202-01A.pdf then search for fan or 27003002)
Here are the MFD/DESA parts suppliers.
Baltimore Electric
1348 Dixwell Avenue
Hamden, CT 06514
1-800-397-7553
203-248-7553
Parts Company of America
1657 Shermer Road
Northbrook, IL 60062
1-800-323-0620
708-498-5900
Portable Heater Parts
342 N. County Road 400 East
Valparaiso, IN 46383
1-800-362-6951
219-462-7441
F B D
1349 Adams Street
Bowling Green, KY 42103
502-846-1199
1-800-654-8534
Master Parts Dist.
1184 Wilson Ave. NW
Grand Rapids, MI 49544-3458
1-800-446-1446
616-791-0505
Fax: 616-791-8270
Four Flags Power Products
1115 Stateline Road
Niles, MI 49120-4728
1-800-268-4983
616-684-2697
Laportes Parts & Service
2444 N 5th Street
Hartsville, SC 29550
803-332-0191
MTA Distributors
555 Hickory Hills Blvd.
Nashville, TN 37189-9244
1-800-264-0225
615-299-8777
Tuco Industrial Products
5223 18th Street SW
Lynwood, WA 98037-4506
425-743-9533
1-800-735-1268
Mar 16, 2011 | Desa International Electrical Supplies
We have bought a home with the wite rodgers thermostat 1f85-275 it doesn't seem to be working. on the top right of the screen it states 1&2 stages? anyway, help would be appriciated
Hi, this thermostat is for central heat and air systems that have more then 1 stage of heating or cooling. For example, your unit may have 2 stages of cooling, as in 2 compressors, or 1 stage of cooling and 2 stages of heating as used in commercial heat pumps. This is a multi-stage heat pump thermostat. It may be just a matter of programming the stat. If you can find a manual on it, this would help. If you open the cover, it should have directions on how to program it.Make sure you have power to everything, check all breakers to see if they may be shut of, even if you have a display, doesn't mean you have high voltage to run the unit. Make sure fan is in auto, and on heat or cool, and temperature set for it to come on. Please keep me posted.
Sincerely,
Shastalaker7
A/C, Heating Contractor
PS Your unit has 1 stage of cooling, and 2 stages of heating.
Nov 05, 2010 | Heating & Cooling
Im replacing my honeywell with a hunter 44110 the honeywell has 6 wires w1 to white, w2 to blk, G to green, RH to Red, Y2 to yellow and Y1 to orange, the hunter only has G RH RC Y W
I hate to tell you this but that thermostat will not work with your system.
The system you have is a 2 stage system and the thermostat you got will only do one stage.
You will need to get a thermostat theat is compatible with stage heating and cooling.
The W1 is the first stage heating, the W2 is second heating. The same is true for Y1 and Y2 on cooling
You could double them up, but it would defeat the encomoy reasons for having a 2 stage unit.
Wish I could give you better news..
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 05, 2009 | Hunter Fan Company 5/1/1 Programmable...
No heat, got great a/c....
W1 and W2 are the differences from the single stage to the two stage. Im thinking its your thermostat is not programed for 1 heat / 1 cool. You probably had 2 heat / 1 cool before.
Oct 17, 2009 | Goodman Heating & Cooling
Need a new window kit adaptor for 9000ah
you should be able to find that through a heating and air condition company they should with all the model and searial numbers be able to order it for you
Aug 23, 2009 | Soleus KY-34 Portable Air Conditioner
Compressor is Down
It depends on how old your system is. A heat pump that is 7 years or older I would recommend replacing the system and not just the compressor. Yes the first company is right in saying that you have to install a higher S.E.E.R. system (assuming yours is less then a 13) that is an EPA law. You can replace just the compressor however, if the system is older then 7 years you will start to have other parts breakdown soon. It's less expensive to replace the compressor but in the long run it is more cost effective to replace the system for both future repair and operating cost reasons. Good luck and don't forget to give me a Fixya rating.
Mar 10, 2009 | Weather King 10PJA2501AH Air Conditioner
When going to destination it takes you around to get to the street when the street is in front of you
We have several problems with our Tom Tom One XLS.
1st problem in the town we live in Russell Springs, Ky. 42642 we have a Big Kmart,Kroger Grocery store, Kroger Gas station,Rite-Aide Pharmacy,McDonalds and several other businesses all in Northridge Shopping Center basic address for the area would be:
Hwy S 127
Russell Springs Ky. 42642
we can put exact address and business name and the only one Tom Tom can find is Rite-Aide Pharmacy. This businesses have been there for 10 - 20 years why can Tom Tom not find them.
We have a Keyvillage Shopping Center and it can locate that one. We would like this problem solved it is annoying.
2nd problem Tom tom calls a 45 degree curve a turn.what is up with that.
3rd problem is in other town s in ky and other states tom tom will take u to the old building instead of the new location why is that.
4th problem Tom Tom sometimes fails to tell you to turn when its to late to turn at the right turn another words Tom Tom waits till you get right on the road or just past it then tells you to turn. Why isw that?and we update Tom Tom at least 2 Times aweek if not 3. please help us in a few months we r fixing to take a long trip we r both retired and we definintly don't need these problems then.
Thank You
Dale and Sherri George
Nickname is Dale 845
p.s hope to here from you soon with the answers.
Nov 09, 2008 | Tomtom GPS
Heating & Cooling Logo
129 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
