This problem should be removed because:
Problem with Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
How to replace batteries on CMM1000 (diagram?)
I bought new batteries for my CMM1000 and I have no idea how to replace them. Is there some sort of diagram detailing the process? The manual doesn't cover battery replacement.
Thanks!
Solutions (5)
Best Solution
I have a CMM1000 which needs new batteries. I have pretty much figured out how to replace them, but I haven't found replacements yet. Please let me know where you found them! You need to remove the (black) top cover - there are 6 screws involved. 2 screws are in recesses toward the front on top. You will probably need to remove debris to access these. They are Torx type, but if you don't have Torx bits, they have a slot which works with a flat head screwdriver if you're careful. The next 2 screws are toward the back down at either side. These are also the Torx type and they have star washers. The last 2 screws are up in the charging area. They are regular phillips and they attach to the circuit board. With all screws removed the top cover will come free. Be gentle though - there are wires from the charging meter that are still attached. You have to maneuver the cover over the height adjustment handle, then flip it up to reveal the circuit board. Disconnect the red and black wires from the terminals marked "TB2 Fuel Gauge Red" and "TB3 Fuel Gauge Blk" The top is now free and can be set aside. There is a push-fit block of styrofoam which can be removed and set aside. You should now be able access the battery terminals which can be removed with a nut driver or socket wrench. There is a jumper wire also. Make a note of the polarity of all connections. At this point the old batteries should slide out from their styrofoam cradle (I haven't actually tried this yet). From this point you will reverse the steps to install your new batteries. Hope this helps.
I ordered batteries from www.batterysolutionsinc.com for a great price
and they arrived quickly as promised. Thanks Sportster640.
Then I followed mongodaddy's great instructions for installing the new
batteries. I have two point to add that may be of interest to others.
First, the connecting posts on the replacement batteries are different
from the originals. The work just fine, but be mindful of the
direction the cables are attached because when you turn the pair on its
side to strap it down, if the cables aren't screwed down in the right
position, it can make them too short to reach the circuit board. I had
to reposition mine to make them work.
Second, the circuit board hangs off of two slots on the back of the
housing. I found that it tended to droop on the front edge enough that
when I replaced the mower's top, the screws that go through the top and
connect to the circuit board weren't long enough to engage. My
solution was to cut a 3" piece of styrofoam to prop up the left edge of
the circuit board. That' exactly the same material that's already
inside securing the battery, so I figured one more piece couldn't
hurt. It worked like a charm and I was able to tighten all the screws.
The new battery is currently charging, but it looks like all is well
and I saved more than $100 over lugging the mower to a B&D service
center. Thanks for the great advice.
You can purchase the original black & decter batteries here:
http://www.acehardwareoutlet.com/productDetails.aspx?SKU=296040001
Aftermarket batteries will not be the same quality.
I'm grateful to everyone who posted information on buying and installing a new battery. I ordered mine from Battery Solutions and it came in a few days. Great price! We'll see how long it lasts. I only had some problems with the two smaller white foam inserts. One fell out when I lifted the black top and don't know where it was supposed to go; and I couldn't get the second one wedged back in between the motor and the battery after I put the new batteries in. So I positioned them to support the lid and still close it - and hope that's enough! I did use double sided stick foam tape to join the two batteries together. It worked very well.
Grateful,
Sandy
guy's there a recall on this mower better see service center. a board recall & upgrade lead wire recall.
I need to replace a
I need to replace a battery in the Black & Decker CMM1000 cordless lawn mover but I can't find any directions. Can someone help...
b&d cmm1000
the key won't insert all the way. will go in if i engage bail handle and switch but still won't run.
Black & Decker Cordless lawnmore CMM 1200 -...
Do I need to take the battery out of the lawnmore for winter storage. I live in Windsor, Ontario and the winters are very cold. I was told...
wiring diagram for a cordless Black & Decker...
I am looking for a wiring diagram for a cordless 24V Black & Decker CMM1000 type 2 Lawn Mower. I've purchased a new battery and...
Add Your Solution
I put in new batteries and my B&D cmm1200...
I put in new batteries and my B&D cmm1200 won't start
See all Black & Decker 19" Electric Lawnhog Mulching Mower Problems
Fix-O-Meter
2,878
2,878 people viewed this problem
- 15 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Black & Decker Riding Mower and Garden Tractor Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
