Question about Kitchen Ranges
I have a hubbell cat. # PVL-150S-521-L outdoor fixture on a wall that lights up when it is initially powered up but goes off after a couple of minutes then cools off and restarts again. Is this a bad xmfr? or cap?
Thats a bad bulb
Posted on Jun 27, 2013
How to check for short in a 24 volt outdoor lights. Without a volt meter
Kill the power at the fuse box, remove the light fixture and make sure your wires are not shorted behind the fixture... usually happens when they are bunched up in the electrical box and squeezed.... could be a fire hazzard
Oct 16, 2014 | Malibu Boats Malibu Outdoor Lighting. Low...
How to wire a Hubbell HBL26CM23 230V 16A shore power plug
Black wire goes to brass screw
White wire goes to screw with white finish
Green wire goes to ground.
Product Datasheet HBL26CM23
Sep 25, 2014 | Hubbell Boating
NEED REMOTE CONTROL FOR MODEL MC42-1012H M-1178 2-2007
I have the information on the wireless remote if you need it.
Aug 04, 2013 | Hubbell Electrical Products Hubbell...
How to wire this fan
The wiring on most paddle / ceiling fans id such:
White = Fan and Light neutral or "common"
Black = Fan line voltage or "hot"
Blue = Light line voltage or "hot"
Green = safety ground
If you are replacing an existing light fixture - be sure to replace the ceiling box with one designed for use with a fan - as per electrical code. If the existing box had only 2 wires (or 3 counting the ground) that connected to the old light fixture and it was controlled from a wall switch, the wiring would be fixture white to ceiling white, fixture black and fixture blue to ceiling black (or red) and fixture green to ceiling bare ground or connected to the metal box. This would power both the fan and light whenever the wall switch was on and the pull chains for each were also on. This is also the preferred wiring for replacement of a pull chain type light fixture (no wall switch present).
If there are other wires in the box that previously were not connected to the old light fixture, using a meter or tester - determine if there is constant power between the ceiling white wire and any of the these other wires (test with the wall switch on and off to be sure). If you do have constant power available, you might consider using the wall switch to control only the light, and using the pull chain to operate the fan (or vice-versa). Simply connect the black (for fan) or the blue (for light) to the "constant power on" wire and that part of the fixture will work by pull chain only - regardless of the wall switch position. If the fan can be shut off by the wall switch, it is very important that the wall switch remain a toggle (or on / off switch), do NOT replace with a dimmer type switch.
If you'd prefer to operate the fan and light completely independently of each other - you can purchase a 3rd party fan & light remote control device for between $30 - $50.
I hope this helps and good luck! Please rate my reply. Thanks!
Apr 22, 2011 | Aloha Housewares (93645) Ceiling Fan
Does this switch wire like a normal single pole switch ? Why does it look like a three way switch? and why is the so called ground screw silver like the nuteral
I am not sure which switch you have. The Hubbell HBL 1281 is shown in the catalog as a single pole switch. It comes in several models. One model has a single lever that goes up (ON) and goes down (OFF).
Another model is a push button. Push once and it is ON, push again and it is OFF.
The above two switches are to be wired to break the hot (black) wire going to the controlled device. Hot should be connected to the bottom, generally, load should be connected to the top.
There is no NEUTRAL wire location. If there is a ground screw, it should be green.
There is also a three position model that operates two circuits, the middle position is OFF for both circuits, the top is ON for one circuit and the bottom is ON for the second circuit.
Gary
Feb 15, 2011 | Hubbell HBL1281 Industrial Grade Wall...
I bought a place with intermatic malibu outdoor lighting. The wire on the light fixture was broken when bushes were taken out. I can't find any instructions on how to connect a new fixture to the...
Malibu low-voltage light fixtures come equipped with a quick-connect that is pressed onto the power cable to make connection to the wires within it. These quick-connects are handy, but they are also relatively fragile, subject to shorting/disconnections, and nearly impossible to repair. I have spliced a replacement connector's wire leads onto the wire leads from a broken fixture, but the connectors are nearly impossible to find (I remove mine from fixtures that are beyond repair). Perhaps the simplest and most effective repair is to strip small sections of the power cable, splice the fixture wire leads onto the cable (don't be overly concerned about matching polarity), and seal the splice with electrical tape and a silicone sealant.
I hope this information helps.
Bill B.
Nov 23, 2010 | Home
Hubbell Special Products bed control
The only thing I can say is to either contact Hubbell Special Products, or contact Invacare and see what they say. I am looking for the same thing. Check all the **** on it and found out the remote is shot... Now have to work with them to get the right one now.
Aug 01, 2010 | Hubbell Electrical Products Hubbell...
Wiring an inwall timer
The white goes to the white, the black power wire to the black and the red wire to the black going to to the lights...
heatman101
Nov 25, 2009 | Garden
Kitchen Ranges Logo
97 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
