When i put on the tv there was an upgrade message i clicked the button to upgrade now i have no channels and it wont let me programme them in on the DTV or TV only on Nicam Stereo what do i need to do?
This error shows the TV manufacturer have not secured the digital rights for displaying contents of your required channel. Consult to user manual and if nothing is found then contact the required channel for this issue.
Most U.K channels also provide an on-line streaming service to allow users from within the U.K to watch programmes after they have aired on the channel on digital t.v.
Most popular channels are like BBC1,BBC2,BBC THREE, BBC Four and CBBC can all be accessed at http://www.bbc.co.uk/iplayer/tv
1st click the "mode" button on the TV or remote then use the vol. up and down buttons to scroll around until you get to DTV mode then press "enter" on the remote you should get a message "please run channel auto scan" . click "Menu" on the remote the "Picture" screen will come up, keep clicking the vol. up button to scroll past "Audio" then "Setup" then to "Channel" then use the CH up or down buttons to scroll to "Air" click OK , then use the CH down button to scroll to "Scan all channels" then click the vol. up button. it then should start scanning, FYI you have to be fast!
VCR is analogue, However you can still use it to record digital programmes when connected via a digital set top box. You can only record the channel you have selected on the screen. In other words, you cannot record a channel programme while watching another channel. I use mine on a second TV and when recorded I take the tape out and put it into my main TV for viewing at a later date. I don't watch too much TV so it works fine for me for the odd programme.
1.check the batteries are properly installed with correct polarity.(+ and -)
2.Check weather correct remote operating is set.(TV,VCR etc)
If both are OK then please programm your remote again with the TV.As you removed your battries it might reset the code
When using buttons on TV it says CHILD LOCK is ON.
Child lock fuction is to prevent children operating buttons in TV console. This can be set only by remote. Cannot set by TV console Buttons.If this fuction is activated you cannot use the TV console buttons.
Sounds to me like your hard drive is full. Do you use the topup tv part of the box? If not, deselect all the topup tv channels. This will free up a significant amount of drive. Failing that, you'll have to delete some of your programs, sorry! To deselect topup tv channels; Go into the menu option, Customise Top Up TV Anytime, and de-activate all the selected channels
hi i think you might have the wrong software on the box,turn you tv on and put it on the sky channel take your viewing card out of the stb turn the box off then take the power lead out, wait till the stb powers down then put your finger on the backup button keeping it pressed put the power lead back in and holding the backup button wait till the on screen message comes on your tv, wait till the tv screen goes blank then put your card back in turn your box back on and try to record 2 channels at the same time this should solve the problem. if not it will be the cable or the quad lnb.
I doubt the TV even has a tuner if it is designed for a hotel. It may be a "dumb" receiver, nothing else. Do to channel 2 and then press the down arrow for channel, does it flip to 138 or AV1?
