Question about Texas Instruments TI-84 Plus Calculator
What can i do about a calculator that is frozen? even if i take that batteries out it still has the same screen when i put them back in. none of the buttons work and all it says is " Ans>>cos((,log(1n(>+" my kids got ahold of it, its been like this for a week, is there a way to re set it?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
To reset the calculator: Remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries.
Posted on Sep 15, 2010
My TI-84 Plus Silver Edition is frozen. I can't clear the screen or enter in another problem. What do I do?
If the TI-84 SE does not function even though you are sure that the
batteries are fresh, you can try manually resetting it by following steps:
1. Remove all of the AAA batteries from the graphing handheld
2. Press and hold the ON key for ten seconds
3. Replace the batteries
4. Turn on the unit
When you reset your graphing handheld, the contrast sometimes
changes. If the screen is faded or blank, adjust the contrast by
pressing 2nd and releasing up-arrow or down-arrow keys.
Aug 27, 2012 | Texas Instruments TI-84 Plus Calculator
My ti-89 is frozen, no matter what keys i press.and although i took off 4 batteries, but when i put batteries back, it is still same, menu screen.
First try the reset code which is pressing Left-Right-Shift and On at the same time. If that doesn't work you can try removing the batteries and putting them back in while holding the (-) and ) buttons.
If those don't work, there is a back-up battery located under a panel just above the four normal batteries underneath the battery cover. Removing this in addition to the four normal batteries should reset your calculator entirely.
If none of these work then there may be a short in the circuits of your calculator which could have been caused by leaking batteries. In this case you can try disassembling the calculator (being careful to remember how it goes back together) and cleaning the circuit board with circuit cleaner.
Jun 03, 2011 | Texas Instruments TI-89 Calculator
Hello, my name is Lucas Matthews and I have a TI-89 that is frozen. The home screen is frozen and wont change. I have tried taking out the batteries and replacing them. Also, I have tried holding the ON...
There is a backup battery hidden under a cover in the battery compartment. Try removing all the batteries, including that one. Wait a little while, then put them back in. While you're waiting, apparently dust in the usb connector can cause problems. I don't know why, but it can't hurt to clean it out if it's dirty. If that fails, you can plug it into your computer, download the necessary software from the TI website, and reinstall the OS. If all that doesn't work, there might be a hardware problem.
Mar 02, 2011 | Texas Instruments TI-89 Calculator
My ti-89 screen is frozen and wont accept input
Remove the batteries and wait a minute or two. Put them back in and turn the calc back on and it should function normally. Check for stuck buttons as well, as sometimes they will cause the calc to appear "frozen".
Sep 30, 2010 | Texas Instruments TI-89 Calculator
How do I reset a TI-84 SIlver Edition graphing calcultor when the screen is frozen and none of the keys are working?
Remove all four AAA batteries. Press and hold down the ON key for at least ten seconds. Replace the batteries and turn the calculator on.
May 05, 2010 | Texas Instruments TI-84 Plus Silver...
My TI-84 Plus Silver Edition is completely frozen up.
A possible solution is to reset the calculator. It's worth a try.
Take out the backup battery above the regular batteries behind a little door with a screw. Leave it out for about 8 hours along with the 4 AAA batteries. Put it all back together and see if this works. Not sure but it is worth a try.
Jul 03, 2009 | Texas Instruments TI-84 Plus Silver...
My TI-84 silver edition has frozen, It is stuck on the same screen and nothing appears when I hit buttons, it wont even turn off. When I remove the batteries and place them back in the same screen appears....
I had the same problem. I remove all four batteries and the battery backup that is underneath the little phillips screw in the battery compartment. I immediately replaced it and the other batteries and everything worked. FYI, others have called for keeping the batteries out for 8 hours.
Apr 06, 2009 | Texas Instruments TI-84 Plus Silver...
Frozen screen
Believe it or not I banged it hard on the bench which seem to unlock it and than once I was able, I could then use the keys to reset it. I did however loose a lot of the formulars but have since re-entered them.
Thanks guys for your help
Mar 31, 2009 | Texas Instruments TI-84 Plus Calculator
Illegal instruction
try to take all the battries out including the back up battery and put them all back in and turn it on and see if that fxes it
Apr 10, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments TI-84 Plus Calculator Logo
139 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
