FixYa.com
Tags:
Intel Motherboard
Intel D955XBX-WB motherboard
posted by progster on May 16, 2008
I just installed this motherboard and it came with no diagram, I am trying to match up the front panel header with the case wiring, I did get the power switch hooked up right or at least the unit powers up but the rest of the wiring does not work. I don't want to experiment cause I could cause other problems. Any help on this?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 03, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
the XBX is a BTX form factor and the XBK is an ATX Form factor
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 17, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
sandeep m mangle
Solution #3
posted on May 16, 2008
Not Rated (0)
Kidyubyub
Rank:Guru Guru
Rating: 86%, 66 votes
Are you sure that it is the D955XBX and not the D955XBK? I did not find a XBX on Intel's site... I did find the XBK, and here is the link to the manual (located at bottom of download page):
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2070&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
The only XBX I found was the D975.
Can you Help with these Motherboards problems?
Motherboards
which mother board to go with
i'm buying 2 visiontek radeon... Answer This...
Motherboards
fredy
nesecito el driver del sonido... Answer This...
Intel Motherboard
how can i get pass cold
how do i get the passcode to... Answer This...
Intel Motherboard
system shutdown
when I start the system. it... Answer This...
Intel Motherboard
Recivers prices
what do you think is the best... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
