Question about Hoover Elite Rewind Bagless Upright VacuumVacuum
I can't use the hose
Every time I attempt to use the hose, I don't really get any...suckage. the regular floor rollers keep going and almost no power is directed to the hose. Do I need to have it on a certain setting? am I forgetting a step (I have just been pulling the hose out by the handle, leaving one end hooked into the bagless container.) And no, I cannot find my manual.
  • Anonymous May 21, 2008
    My hose has minimal suckage as well, even after cleaning everything out, new belt etc...I also have noticed things are not being sucked into the cup like they should.
  • Foggysummers May 26, 2008
    Was the hose not designed to **** up cat hair? It seems to clog the hose on a regular basis. Can the hose be disconnected from the vacuum to clean it out?
    How do I clean the filter?
    Problem Solver:
I had a similar problem with my Hoover Elite and just resolved it today. Mine was also picking up with the beater bar, but not as good as it should and it had very little suction at the hose, so little that the powered hand tool brush would not spin at all.
I did everything it said to do in my owners manual...
I looked into every entry to the dirt cup.
I checked for blockages into the bottom of the vacuum.
I cleaned the HEPA and regular filters and dirt cup - still no success.
I made sure the belt was working properly.
I finally sat and looked at how things should get into the clear dirt cup (bagless model).
I finally realized it had to be a blockage in the hose.
I completely detached the hose from the vacuum - this took some muscle, but there is the word "LOCK" where the hose attaches near the dirt cup. Turn it counter clockwise or to the left and with some umph it will unlock and detach from the vacuum.
Then I took the hose outside and used my high pressure nozzle on my garden hose to spray out the hose. It took a few seconds before a pretty large & stiff piece of paper (2"x2") and much more very dirty stuff finally blew out...
No wonder the vacuum had no suction!!!
The paper that was blocking the hose reminds me of a piece found under a Reese's Peanut Butter Cup! YIKES, it was probably candy causing yet more problems besides the extra pounds!!!
Hope this helps - I'm not an expert, just a frustrated cleaning fanatic who hates it when mechanical things don't work right!
Good LUCK from Henderson, NV!!!
Posted on May 27, 2009
  • 72 Answers
Clean the filters there are two one on top one on bottom of canister chamber
Posted on Mar 27, 2009
  • gretta32174 Mar 05, 2011
    Thank you! There was debris stuck in the hose of my vacuum which was totally preventing the suction to work! Your tips led to me finding the problem! I used the water from the kitchen faucet. Thanks :)
Canister vacuum Sears model 116.59229210. The suction is coming through the vac for the hardwood floor setting, but the light on the power head will not work and the roller is not turning. I have...
Kenmore canisters are famous for melting the connection between the hose handle and the upper wand. They also sometimes melt between the lower wand and the power nozzle neck. Take it to your local vacuum repair center and get a diagnosis.
Dec 19, 2014 | Vacuums
Will not dry or suck up water at all...BRAND NEW
If it's brand new your best bet might be taking it to a Hoover service center. That'll have a year warranty on it so the fix would be free.
Apr 06, 2013 | Hoover H3044 FloorMate SpinScrub Wide-Path...
I don't seem to get suction on the bare floor mode
There are several things that this could be. Probably the most common problem that we see when customers come in with this problem is actually a fairly simple problem to fix. Here are just a few things that this could be.
The fist possible problem is a VERY common problem actually.
Possible Problem #1. The first problem is extremely common. In fact, we probably see between 2-3 of these problems every week. It mostly happens after people take the bottom plate off the vacuum in order to clean the roller brush. What happens is when they reinstall the bottom plate, they put it on on incorrectly. It's actually very easy to do. When the bottom plate (soleplate) is installed wrong, there will be a gap between the bottom plate, and the agitator housing, or the purple tray the roller brush sits in. This will cause the soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to the user that vacuum has lost suction power because without the brushes hitting the carpet, the machine will not pick up very well on floors, but when they use the attachment hose there's plenty of suction power.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
Possible Problem # 2. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the reclined position. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
This would also explain why the vacuum works fine when using the attachments, but not on the floors. The attachment hose uses a different suction channel, and when the machine is in the upright position, no suction goes through this hose. If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. I would suspect that this may not be the problem, but if neither of the solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
If you are getting suction power from the hose, but the vacuum still doesn't pick up on the floors, I think that these solutions should fix your problem. If you just replaced the clutch mechanism, the roller brush should be fine, but turn the vacuum over on it's side and make sure that the roller brush is actually spinning while it's on carpet mode. If none of these problems fixed your Dyson, please use the Clarification Request, or leave another comment here on the Fixya repair page, and I'll be happy to further diagnosis the vacuum cleaner with you.
I hope this was helpful to you. If so, please be sure to rate the repair as helpful by clicking the thumbs up icon in the top of the repair page. This is what keeps Fixya repair professionals like myself continue posting these detailed repair solutions for free. We really do appreciate when someone recognizes the work you've done. Thank you very much,
Chris J.
GoVacuum.com
May 07, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Loss of bare floor pick up
The fist possible problem sounds like the most probable to me, just because of the fact that you said you had just replaced the clutch, and therefore you had to remove the bottom sole plate. This is a VERY common problem actually.
Chris J.
GoVacuum
Apr 03, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Need a filter for rowenta infinium vacuum cleaner
Although it sounds to me like you have a clog in your hose (remove hose and try slipping a heavy butter knife through it, end to end) here is a link to Rowenta manual..lists part numbers for replacement parts.
http://www.rowenta.com/NR/rdonlyres/9A747036-B60E-4F70-96BF-3370EDADAB54/0/Canistervacummcleaners_InfiniumGB.pdf
www.rowenta.com
Sep 13, 2009 | Rowenta RO7011 Bagless Canister Vacuum
Bissell Lift OfF Brush Roller Stops Rotating
They make the worst machines, the rollers are cheap and they make it so you cant take them apart to clean them. You don't want a dyson either, they aren't any better for pets. With all that hardwood floors you should get a good canister vacuum, sebo and miele are the best.
Aug 24, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Jul 05, 2009 | VAX Appliances Vax X5 Bagless Upright...
Eureka 4870: Brush roller turns even in hose setting.
You either have the wrong size belt, most likely too small, or you have installed a new belt incorrectly. When you open the cover on the bottom of your vac, you will see the pulley that moves as you flip the switch from floors to carpet. The belt does not go around this pulley. When activated(carpet) the pulley puts tension on the belt causing it to turn the roller. When switched back to hard floors, the belt looses tension allowing motor to cause suction but disabling roller. Also, the dial on top of vac is only to direct suction, not for disabling roller
Jun 21, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Hoover Elite Rewind Bagless Upright VacuumVacuum Logo
387 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
