Question about Texas Instruments TI-83 Plus Calculator
If my calculator is not turning on t do you think my calculator problem is?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If that doesn't do it, please reply to this post and we'll go on from there.
Posted on Sep 15, 2010
How to switch off my casio mj-100d calculator
I think this is a solar calculator. On many solar calculators, there isn't an off button. You just stop using it and after a set period of time (6 minutes for this calculator), it turns off by itself.
Good luck.
Paul
Sep 12, 2015 | Casio Office Equipment & Supplies
I press ON, then i press the number. My problem is the number not appear on the screen. i spoiled my sister's calculator. help me, please!
Are you sure the calculator turns on? Try using fresh batteries, or try removing and reinserting the batteries and see if you get the same result.
Do you see anything at all when you turn the calculator on? Try pressing '2nd', then 'QUIT' (MODE) a few times.
Did you do anything that you think might have broken the calculator?
Mar 30, 2011 | Texas Instruments TI-84 Plus Silver...
My calculator suddenly won't turn on anymore and the batteries are fine. I think that someone messed up my calculator so that it won't turn on.
If this doesn't do it, please reply to this post and we'll go on from there.
Nov 12, 2010 | Texas Instruments TI-84 Plus Calculator
My ti-83 stopped working after i used rechargeable battteries. Now i realized I'm not suppose to use them. Now whenever i turn the calculator on, i can't turn it off. I will try to press letters or numbers...
I'm thinking the calculator itself froze (stalled), or the circuit board is taking a long time to process the your command (telling the calculator to turn off). Maybe you should wait a few hours or so and see if it's still on. Did you perhaps take the batteries out while the calculator was still on? You may have damage the circuits inside of the calculator by taking the batteries out while the calculator itself was still on. Maybe if you put some new batteries in the battery compartment and press the "ON" button, it might function properly. This is a suggestion and I hope this works.
Oct 08, 2010 | Texas Instruments TI-83 Plus Calculator
I tried to update my Operating System but it did not work. I think it might be the link that connected my calculator. It isn't the one that came with my calculator, its one that fit that I found around the...
Hi
you need a standard USB cable i do update to all the calculator i fix
its possible that the port on the calculator is not working there is a fuse maybe its burned
ecrdn@yahoo.com
Sep 16, 2010 | Texas Instruments TI-84 Plus Silver...
My TI-83 drains batteries as well. used many different new batteries but it still didn't work. is my calculator permanently damaged or can it still be fixed?
About the only thing that I can can think of is that you may need to replace the internal battery. It is located in a little door with a screw right above the AAA batteries.
Another thought. The calculator may be staying on and not doing an auto shutoff. The calculator should turn itself off if you forget to turn it off. You can check to see if this is happening by leaving the calculator on, going back later and checking to see if it turned itself off.
Aug 12, 2009 | Texas Instruments TI-83 Plus Silver...
Calculator won't turn on
Try changing the batteries, and if that don't work, I think that you should either get professional help or buy a new calculator
Feb 26, 2009 | Texas Instruments TI-83 Plus Calculator
Too few arguments appeat when turn on the HP 48gx calculator
This calculator uses RPN (reverse polish notation) not algebraic notation.
If say you want to calculate 12+13, you proceed as follows
12 [ENTER] 13 + : the claculator displays 25
Similarly
12 [ENTER] 13 x : displays 156
Also if you use a function like sinus or cosinus
12 [ENTER] cos displays the value (depending on the angle unit you are using).
I think you need to read a little more on the RPN before you get accustomed to this way of doing thing. The best reference is your calculator Getting started manual.
Hope it helps.
Jan 18, 2009 | HP 48gx Calculator
Ti-89 wont turn off
I'm having the same problem:(
I need to solve this urgently, i can't stand always being removing the batteries... please help me!!!
Oct 16, 2007 | Texas Instruments TI-89 Calculator
On/off button doesnt turn on
normally if you spill any type of liquid that would certainly affect your calculator from working- i would say that you need to have it replaced
Aug 31, 2007 | Tech Solution TS-900 Calculator
Texas Instruments TI-83 Plus Calculator Logo
22 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
