Question about Magic Chef CYG2000AWW Gas Dryer
YE225LV will not start after running for a while.
  • Magic Chef Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 21, 2010
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
Tip
Wiring up a compressor + start kit
If there is an identifying mark on one side of the capacitor such as a Dash, Red paint or arrow pointing one direction that will be the run side of the capacitor, if no marks you can use either side for start or run.
If you have three terminals on the capacitor you have a dual capacitor, (C = RUN compressor and fan) (HERM = compressor start) and (FAN is fan start wire).
The Start wire goes to one side of the run capacitor it will be the only wire on that side of the capacitor.
The Run wire goes to the terminal side (T2) of the contactor, it will have another
wire from that terminal to the run capacitor which is the opposite side of the start wire.
The Common wire will go to the other side of the contactor (T1).
Start Kit
Start from the capacitor to terminal #1 on start relay There should be another wire from
here to start on the compressor.
Common from contactor (T1) to terminal #5 on start relay. There should be a wire from this terminal to the Common terminal on the compressor.(there will not be a capacitor in this circuit)
Run from the other side of the contactor (T2) to the start capacitor and from the other
Side of the start capacitor to terminal #2 on the start relay. There should also be a wire from this
Terminal to Run on the compressor.
on Jan 24, 2010 | Heating & Cooling
Car wont start
Run and start are two different things, if it starts and runs from a jump it might just need a new battery. While running, the car stops running and wont start, then I would check the alternator by removing the negative cable while the car is running, and if it shuts off then the alternator is the problem.
Nov 30, 2013 | Saturn 2002 VUE 4 CYL
My 2004 Chevolet Cavalier was running and started yesterday, but the next day would not start. It would turn over, but not start or run. Just run my battery down, started over, over
Spray a bit of carb cleaner in the air boot, off air filter housing to check if fuel pump went dead. Would be a good idea to check all fuses.
Nov 16, 2013 | 2004 Chevrolet Cavalier
Model rs1200 w/791 bypass hit start button runs 3 minutes then dies,starts by it self runs 3 minutes dies, starts by its self runs 3 minutes dies, use key starts & runs fine
check your documentation on adjusting the runtime for the unit. Normally they will run 15min. shutdown then restart run 15min. ect. also check the settings for use of a tach wire.
Dec 29, 2009 | Bulldog Remote Starter & T-Harness Kit for...
Engine cut out after running o.k for 1/2hour hard to start
I would start with the Fuel Pump Relay. Check the Fuel Pump, Fuel Filter and Belt Tension.
Jan 25, 2009 | 1999 Daewoo Lanos
DELL DIMENSIONS 2300 COOLING FAN
Your system will run fine until the processor starts overheating... why not just replace the fan?
Oct 26, 2008 | Dell Mini Fan. Dimension (W x H x D) in....
Kenmore Electric Dryer Will not Run
there is a centrifugal switch on the dryer motor. pressing start energizes the start winding and the motor runs. when the motor is up to proper rpm the start switch is supposed to kick out and the motor runs on its run winding.
Sep 21, 2007 | Dryers
Magic Chef CYG2000AWW Gas Dryer Logo
Top Magic Chef Dryers Experts
Tim Whalen
Wayne Fellows
Wayne Fellows
Craig Butler
Craig Butler
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
