Question about Lexmark X2600 InkJet Printer
Just bought new Lexmark 14 & 15 ink cartridges for the 2600 series and keep getting a C2E error message....what is this?
My Lexmark Z2300 is giving me an error msg that the cartridge is in compatible. The cartridge is actually a Lexmark 14. Once I took the cartridge out and powered off, then powered back on and added th
were they 'refilled' cartridges ? Lexmarks are sensitive to that...they have a chip in their tanks that you have to change/reset....you can't just refill them with ink.
Tallon41
Sep 06, 2012 | Lexmark Z2300 InkJet Printer
Installed new black cartridge - had ink
A firmware update for your model addresses the print quality problem that you're currently experiencing. Please visit the Lexmark website to download and install the Lexmark S400 Series Firmware Update. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct.
Should the error continue to display even after successfully updating your printer, please contact Lexmark Technical Support Center for additional assistance. Your printhead itself might be the cause of the problem.
Feb 17, 2012 | Lexmark Interpret S405 Wireless All-in-One...
I get a message that the printer cartidge is not compatible, but it is the correct one for the 2600 printer
The cartridges for the Lexmark X2600 are 14 and 15. Try to insert your old cartridge and see if the comes up. Wiping the nozzles on the cartridges with a moistened soft cloth might help get rid of the error too. Make sure to properly insert the cartridges in the carrier.
Mar 23, 2011 | Lexmark X2600 InkJet Printer
Cartridge Error message on our Lexmark X5150
The Lexmark machines are designed to kick out anything it suspects may be refilled. If your old cartridge has bad print nozzles this may be tripping the error. Printers are typically for sensitive with their color cartridges anyway because the manufacturers make more money on the color ones. You can try looking around the settings on the machine and in the printer preferences to see if you can tell it to ignore the ink levels and see if you can continue to print.
Dec 19, 2009 | Lexmark X5150 All-In-One InkJet Printer
I put in a new color cartridge and my printer, not compatible..
Consider this: Using name brand cartridges is more expensive... but works. If you're using the name brand replacements... good. If you've chosen to use refilled ink, some of the features do not work as well as the original replacements. I used refilled cartridges in my Lexmark All-In-One and the "Ink needs refill" applet did not work correctly... so I turned it off...
Oct 25, 2009 | Office Equipment & Supplies
Refilled my lexmark cartridges but still dont work
14 and 15 won't work after refill. You can only refill 14A and 15A.
But even when you refill those, the printer will keep telling you they are empty, which is normal, neither the printer nor the computer can know that you have refilled your cartridges. The devices see cartridges by their serial number, so it resets the counter only when you pop in a new cartridge. They are ways to bypass that by resetting the ink level: use clear tape over the left hand row of sensors on the front of the cartridge and re-insert it. The ink now shows with question mark but reads as full and prints fine. You actually "fool" the printer into thinking you have put a different cartridge. This works with some printers, so I am not 100% sure it will work with yours.
Oct 23, 2009 | Lexmark X2690 All-In-One InkJet Printer
Lexmark x2500 printer ink cartridge
OMG! The cartridges are so expensive. I've tried to refill the cartridge myself and it put up an error message too. The only thing i did was splurge and bought a new cartridge!! Sorry.
Jan 20, 2009 | Lexmark X2500 All-In-One Printer
Lexmark X2600 InkJet Printer Logo
77 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
