Question about Maytag Neptune MDE5500AY Electric Dryer
I need the diagram of the drive belt and how it goes around the drive shaft and pulley
  • Maytag Master
  • 43,501 Answers
Thank for the great rating and I hope by now you are running again...
hewatman101
Posted on Sep 16, 2010
How to change pto belt on club cadet 1046
To replace a transmission drive belt on a Cub Cadet LT1046 you need to remove the deck, preferably put the front wheels up on blocks or stands, unplug the PTO power (directly under the engine, which can be a pain ) You need a 5/8" socket to get the bolt out of the PTO pulley assy.(electric clutch). If you don't have an impact wrench take a spark plug out and push rope into the hole. This will bind the cylinder and keep the drive shaft from turning. Remove rope and replace plug when finished. Battery and/or spark plug wires should be removed for this process for safety.
The PTO may be stuck on there so you may want to tap it with a hammer and a block of wood carefully to release it. Loosen old belt from tensioner pulley. Lower engine pully on drive shaft, below pully "keys". It may be difficult to remove. Spray with "PB Blaster" or similar bolt loosener spray. Remove old belt from engine pulley first, transmission pulley last. Remember how belt goes around pulleys before doing so, make a diagram to help.
You'll need to put the belt on the transmission pulley first then thread the belt up to the engine pulley. Thread your belt back through the pulleys and tensioner (make sure your spring is strong enough to tension the belt or buy a new one).
The PTO pulley is "keyed" on the shaft. Replace bolt and washer. Torque bolt to 38-50 ft. lbs. using the rope meathod as described before. Put your deck back on and you're ready to mow again
May 11, 2017 | Garden
Replacing the drive belt on a hotpoint tdc30p and need a diagram of how the belt goes round the drive and pulley system
wrap the belt around the drum first then the slack at the bottom wraps around the motor shaft. Then it has to go either left or right side of the tensioner wheel, but the flat side must touch the tensioner wheel(not the ribbed side of the belt). You know you got it right when when there is tension on the belt when it is correctly installed. I dont have diagram so this is the most simplistic way of describing how to install it.
Feb 26, 2014 | Dryers
I have a 1989 jeep wrangler it does not have a serpentine belt but rather 3 belts i need a diagram showing how those belts are suposed to be routed
Check with Autozone and discuss your problem. They know what they are talking about and have always come up with the right parts or belts for me. I used to be a mechanic in my youth and I never go anywhere else.........
Sep 01, 2012 | 1989 Jeep Wrangler
Installation of motor drive belt on cub cadet tractor
This one's a PITA. That said, I had to remove the PTO clutch and pulley, the seat, the brake and transmission pedals, and finally the sheet metal that constitutes the fenders and foot plates.
Belt is put over the fan above the transmission and onto the pulley there, then run along bottom of main frame towards the front until it reaches the engine drive shaft.
The belt goes onto a pulley on the engine drive shaft (above the PTO clutch and pulley, which have to come off). I couldn't slide the drive pulley down the shaft, so pulled the 4 engine mounting bolts and move the engine around slightly to allow putting the new belt on between the pulley and it's surrounding sheet metal. Once the belt was on, and before any other steps, I realigned the engine mounting holes and replace the bolts.
The belt is then run around the pulleys under the middle section of the tractor. Leave the spring loaded idler pulley for last. you might need to loosen (not remove) the bolt that goes through the idler pulley in order to get the belt on. The biggest fight is pulling the spring loaded pulley over so that you can put the belt onto it.
Once the belt is fully routed over all pulleys. Reinstall everything that you had to remove - and you should be good-to-go.
ONE LAST COMMENT: Many shops sell belts that DON'T have Kevlar. Make sure you but the one WITH Kevlar. The others rarely last one season.
Aug 31, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Diagram for 5 pulley belt 98 pontiac transport.
start from bottom crankshaft pulley and ac compressor turn belt tensioner counterclockwise or lift forward then run pulley belt around crankshaft pulley and around AC compressor,run pulley belt around power steering pump then around alternator,once drive belt around alternator you done make sure drive is center of crankshaft pulley and AC compressor pulley.and belt back is center against water pump pulley before releasing the belt tensioner.
Aug 27, 2012 | Pontiac Trans Sport Cars & Trucks
Need a diagram for the drive belt on a wheel horse c 100 8 speed
i don't have a diagram but the belt goes around the trans pulley and around the engine pulley and the pulley from the clutch pedal goes under the top section of the belt pulling up in the center hope that helps you
Aug 18, 2012 | Garden
I need the diagram for the serpinetine belt on a 1991 dodge spirit 3.0
The path of pulleys around which the belt goes (beginning with the crankshaft pulley, and moving clockwise around the array of pulleys) is in this order:
tensioner pulley (belt goes around the pulley counter-clockwise)
power steering pulley (belt goes...clockwise)
alternator (belt...clockwise)
idler pulley (belt going under the pulley)
and back to the crank pulley (belt...clockwise).
Feb 28, 2010 | 1993 Dodge Spirit
I am installing a new belt but the pulley that mounts to the ground i found was not attached and i am not posotive of its correct spot i need a diagram
The idler pulley goes in front of motor shaft. There is two slits in sheet metal where it slides in. after pulley is on. put the belt around drum and pinch belt together. put belt under idler wheel then put end on motor shaft. You can push up on idler pulley to get around motor.Make sure grooved side of belt is wrapped around drum. Good Luck!!
Apr 24, 2009 | Dryers
All belts came off , 1986 740 gle 4 cly. with air nedd to know diagram
On the 92, the belt closest to the engine goes around the power steering pump, water pump, and crankshaft pulley.
The second belt goes around the alternator and the crankshaft pulley.
The third belt goes around the a/c and crankshaft pulley.
Jun 26, 2008 | 1991 Volvo 740
Maytag Neptune MDE5500AY Electric Dryer Logo
52 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
